Question about Mizco EKU-BLSTY-WHT Blast Bluetooth Speaker White EKUBLSTYWHT
Why won't MZS-SPBL pair with HTC Evo?
Continues to say pairing not allowed
Blueant ni5417 won't pair with htc one xl
Are you sure that's a blueant device? there's no blueant model such as ni5417.
Mar 09, 2013 | Radio Communications
My phone can't find the headset. HTC EVO
Make sure you have your bluetooth device in pairing mode to do this you usually hold the power button down while turning on the blue tooth device,then there should be a light that stays on ,now that u are in pairing mode you need to enter a pairing code most bluetooth manufacturers use a 4 digit pin pairing code they are as follows 0000,1234,9999,or 1111, i hope this helps.
Mar 23, 2011 | Jabra BT4051 Bluetooth Headset
I've tried sending pictures to other phone but they never go trough
I imagine this is through Bluetooth.
You have to pair the two devices first. It should be under your bluetooth settings > Pair devices.
Once you pair the devices it will ask you for a pin. Insert the same pin on both devuices and they will be paired. You should then be able to send pictures and other files via bluetooth.
Mar 01, 2011 | HTC EVO 4G Smartphone
How do I pair my jawbone icon with HTC evo phone
From your main/home screen :
1. Press your "Menu" button. ( located near the bottom of your phone to the left of your home button )
2. Press the "Settings" button.
3. Press the "Wireless and Networks" button.
4. Check the Bluetooth box to turn on bluetooth.
5. Press the Bluetooth Settings button.
6. Put your Jawbone Icon into discoverable mode. Follow this link for instructions if you cant find your manual.
http://www.headsets.com/headsets/resources/jawbone-pairing-guide.html
7. Click "Scan for Devices" on your EVO.
8. When your Jawbone Icon appears in the Devices list click on it and pair the devices. At this point it will ask you to accept pairing. Once you do that you should be good to use your headset.
Feb 28, 2011 | HTC EVO 4G Smartphone
HTC evo will not pair w my jabra stone, says incorrect pass code, how do I re enter the pass code?
By putting the blue tooth device in discovery mode it will reset it then your will have to enter the manufactures factory pin pairing code,Most blue tooth manufactures use a 4 digit pin pairing code,they are as follows0000,1234,1111,or 9999 this should be the code you are looking for i hope this helps
Feb 22, 2011 | Jabra BT350 Bluetooth Headset Headset
Downloading pics from htc evo to my computer
Please install / re install your HTC evo pc suite on your computer and paired them using firewire
Feb 05, 2011 | HTC EVO 4G Smartphone
I am geting really bad staic in my plantronics voyager pro. I have the HTC EVO. Is there any way to get rid of the static?
Try to re-pair the headset to your phone to make sure that it has a good connection. Before running through the pairing process, be sure to totally delete the headset from the Blackberry's menu. You may want the headset turned off for this process.
Once you make your cell phone discoverable, then put the Plantronics Voyager Pro headset into pairing mode by holding the power button until the headset flashes red and blue. Here is the link below for the Voyager Pro pairing instructions.
Plantronics Voyager Pro Pairing Instructions
Good luck from Headsets Direct!
Jan 08, 2011 | Plantronics Voyager PRO Bluetooth Headset
I am unable to pair with my htc evo.... they find each other but go away.
When you put the device into pair mode and find it on your phone. You select the device and what happens, what do you mean go away? Try doing a hard reset on your phone, to do this remove the battery from your phone while it is powered on. Reboot it, when it comes back again re-attempt to pair the device to your phone (make sure it is still in pair mode).
Rylan
Dec 16, 2010 | Cellular Innovations HFBLU-CX1 Wireless...
How to connect jawbone bluetooth device to htc evo 4g
HOW TO CONNECT BLUETOOTH
It all depends. When you want to connect a blue tooth to a phone, You will need to switch on the blue tooth device and the phones blue tooth you are pairing with.
When pairing both device, you will ask for pairing code, You four digit numbers(default code(0000). and pair.
After pairing both device, you detected paired, you can now use the blue tooth device with your phone.
there are no special code for pairing Blue tooth device.
Normal codes used are any four digit, four numbers you want to use.(0000, 1234).
Take care.
Oct 02, 2010 | HTC EVO 4G Smartphone
Mizco EKU-BLSTY-WHT Blast Bluetooth Speaker White EKUBLSTYWHT Logo
Top Mizco Radio Communications Experts
eradiostore
eradiostore
Mike Charette
Are you a Mizco Radio Communication Expert? Answer questions, earn points and help others
