Question about Welding Tools
Saf nertazip wiring diagram - Welding Tools
Nertazip 207 wiring schmatic
Request a wiring diagram directly from Nertazip.
Jan 13, 2015 | Welding Tools
How do i unlok my saf
Saf is best unlokd as follows: place feet 18 inches apart with toes pointed inwards. Bend knees slightly and apply constant pressure on the right front corner of the saf with your left thumb for 14 seconds.... no longer. Then quickly turn on the green light next to the orange one. The saf should them unlok at the stroke of midnight.
Jan 08, 2015 | Cell Phones
Calibrating incline voltage
It sounds like you may have a shorted potentiometer. I would recommend replacing the VR (Potentiometer) Assembly. I have located it on the manufacturers website for $32.50, part number is 1200-28. If the nylon gear is broken, that part number is 6005-37. If you need the diagram, here is the link:
http://sportsartamerica.com/saf/support/technicalsupport/diagrams/1200.pdf
and the link for the parts list/order page: http://sportsartamerica.com/saf/customer_service/CS_pages/PartsList.aspx
Nov 29, 2013 | Nordic Track NordicTrack Treadmill, A2550
Hi help me : beraking video off saf???
For one thing, you need to learn how to spell
Beraking? Video off saf? What do you mean in english, not chineze.
May 11, 2013 | Soundstream VIR8007 Car DVD Player
All warning lights come on in a 2005 sunfire
ther will probably be a wire loom connector under the carpet under your feet and if the water has been getting to it I would saf that it will be correded and rusted . Check the wiring from front to back and check all connections for rust and rot
Jan 29, 2013 | 2005 Pontiac Sunfire
I have a 2002 gmc saf and my battery volt get low i change two alternator and a battery and still battery not charge battery goes dead quick
if you had a check engine light on you need to erase the code or the voltage regulator switch stays turned off and wont let charge
Apr 21, 2010 | 2002 GMC Safari
Looking for parts for saf presto 135 inverter welder
Hi
my name is Rob, I may be able to help
What parts do need?
this link is for the current models
http://www.saf-fro.com/en/saf-fro/plasma-cutting-1.html
Saf have a base here in the UK
SAF WELDING
2 Low March Industrial Estate Low March, Daventry, Northamptonshire NN11 4SD
p: 01327705511
if the parts you need are generic, I can help.
If you need circuit boards repairing or torch parts I can help
Regards
Rob
Feb 07, 2009 | Inverter Welding Tools
The SAF that shows up on the LCD
Dear Morgansha,
SAF is Micro setting of lens for close-up focus. This function can be ON-OFF by cursor button. it has symbol like little flower.
May 23, 2008 | Sony Cyber-shot DSC-W55 Digital Camera
Blurry views and SAF shown at the bottom of the screen
Sony fixed it for free - it was the CCD as posted by t00nz.
Thanks irschilders
Nov 05, 2007 | Sony Cyber-Shot DSC-T1 Digital Camera
Welding Tools Logo
88 people viewed this question
Top Welding Tools Experts
Bill Boyd
Are you a Welding Tool Expert? Answer questions, earn points and help others
