Question about Brother MFC-8460N Laser Printer
How to reset a Brother MFC-J6510dw - Brother MFC-8460N Laser Printer
5 Suggested Answers
SOURCE: reset drum - brother mfc-8860dn
Open front cover
Remove drum unit and toner cartridge assembly
Put drum unit and toner cartridge assembly back in machine, but do no close front cover.
Press Clear/Back
You will get a message "Replace Drum?"
Select Yes to confirm
Posted on Mar 16, 2008
SOURCE: Factory reset Brother MFC-7320
1. Open cartridge cover
2. Press the button Clear / Back
3. Press start button
4. Print number 11
5. Close cartridge cover
Now, your printer is returned to the factory settings.
Posted on Jul 27, 2010
  • 73 Answers
SOURCE: Where do I find information
Download this link
link above is the product manual which might help you!!!!
Posted on Jul 14, 2011
SOURCE: MFC-J6510DW
check cables, ink, and if computer reconize's it.
Posted on May 14, 2012
Brother MFC-J6510DW maintenance mode report
unless you see anything in the report that says, "incompatible ink" then there's nothing else to worry.
Feb 13, 2018 | Office Equipment & Supplies
No station id
Its just to input your info to send it over when you transmit fax. otherwyse you dont need it
Oct 09, 2013 | Brother MFC-J6510DW Multifunction Printer...
Brother mfc-j6510dw will not scan
This may help others with scanning issues:
I just bought this and was nearly driven cracked trying to get the scanner to work as it was not talking to the PC, even though as a printer it was working fine. Realised eventually that it was just the Brother Control Centre 4 it wasn't talking to. After hours of re-installing software and updates, etc, nothing worked.
The solution: I went into Control Panel on my PC (I use Windows XP), to the Scanners and Cameras section, and in there the Brother Scanner was visible and could be used from there, Click on it to open the Windows Scanner and Camera Wizard and use that. Further, by right-clicking on it and going to properties I choose the software to start when it talks to the PC. I abandoned the Brother CC4 and set it up to start the Scanner and Camera Wizard if I choose 'Scan to Image' on the scanner control panel, and to open Photoshop if I 'Scan to File' on the scanner. Works fine either way, just make sure you choose the right dpi setting to suit your needs.
Hope this helps somebody else as frustrated as I was.
Aug 09, 2012 | Brother MFC J6510DW - Multifunction fax /...
The black ink won't work even though its new
check if the noozles are on the catridges or on the independent print head. if the print head is seperate from catridges, them try print head cleaning. if you it cant work. then dip the print head in hot water for 5 to 10 seconds. dont dry it just put it back into the printer and try again immedeately. let me know if your problem is fixed
Jun 24, 2012 | Brother MFC J6510DW - Multifunction fax /...
MFC-J6510DW
May 14, 2012 | Brother MFC-990CW COLOR INK-JET MFC Ink...
Brother MFC-8460N Laser Printer Logo
101 people viewed this question
James Cagle
James Cagle
Samyfam
Samyfam
Victorman
Victorman
