Question about RIM BlackBerry Pearl 8100
Track ball replaced but still will not go up and down
  • 157 Answers
Try another trackball and clean the trackball pads
Best Regards
Posted on Jun 23, 2009
The ball won't press down anymore.
take a cotton stick and dip it in petrol and then clean ur mouse with that cotton stick hope it would work . . .well mine did !!!
Mar 23, 2010 | RIM BlackBerry Pearl 8100
The track ball on my black berry pearl doesnt scroll down
yes sure!
just take it apart and clean the track ball area with amedical alcohol and brush, remove dirt from it!
plz give a good rate
that happend with mines once!!
Mar 25, 2009 | RIM BlackBerry Pearl 8100
Bernina 1530
You may just need to clean it. Many times when people use hand lotion or other things oil etc. it gets on the ball and interferes with the board. Try cleaning the ball with cottonball and alcohol. It really makes a difference.
Hope this helps.
Rick
Mar 17, 2009 | Bernina 1008
The track ball on my blackberry 8310 stopped working.
No, but fortunately the trackball is not hard or expensive to replace. If you are technically savvy you can do this yourself. Just purchase a trackball on the internet. The trackball easily comes off if you put a small flat screw driver under the outer side of the chrome ring and pull if off. Let me know if you needed more help. Good luck
Mar 13, 2009 | RIM BlackBerry Curve 8310 Smartphone
Blackberry pearl
Common faults with Pearls, do you have warrenty on the Phone?
Send it back for replacement as its hardware fault.
I hope this helps,
Thanks.
Mar 07, 2009 | RIM BlackBerry Pearl 8100
Tracking ball moves but when pushed down nothing happends
you should have the trackball replaced or have the main-board check
Feb 25, 2009 | AT&T Blackberry Curve 8300 Smartphone
The ball won't scroll down
Pop the ring around the track ball out with a small blade or your finger nail. Three double prongs hold it in place (bottom and both sides, none on top). Turn device over and gently tap the back. Track ball will release once ring is removed. At this point you can view the track ball and see exactely what is causing the block. Clean if needed with q-tip or remove lint/debris/etc... Just did this with my 8830. Working perfectly now. - {would not scroll down at all prior to}
Nov 25, 2008 | RIM BlackBerry 8800
Pearl roller ball
It might be a case where the track ball has some dirt or debris underneath it. First, turn the device off. Next, press down firmly on the track ball while at the same time rolling it in every direction. Hopefully that will knock loose any debris. Another tip to try is to wet your thumb with a little water and do the same thing.
If those two options don't work, you may try taking out the track ball and blowing out the slot with some compressed air. Below is a link that shows how to remove and clean the track ball:
http://www.blackberryforums.com/general-8100-series-discussion-pearl/113889-how-clean-trackball-your-pearl-8100-a.html
Oct 03, 2008 | RIM BlackBerry Pearl 8100
Blackberry pearl
First, turn off the device. While pressing down firmly on the track ball roll the ball in all directions.
If that doesn't work, then you may need to take out the track ball and blow it out with compressed air. The link below shows how to disassemble the track ball:
Oct 01, 2008 | RIM BlackBerry 8700c Cellular Phone
Roller ball
Same problem, wouldn't scroll down. Lifted the ring pulled out the rollerball and cleaned it with alchohol. Used a cotton swab, soaked it pretty good and rolled it around a bit. Set it back in and it worked like new. Watch how you take it out so you can put it back in the same way.
Sep 15, 2008 | RIM BlackBerry Curve 8310 Smartphone
RIM BlackBerry  Pearl  8100 Logo
167 people viewed this question
Top RIM Computers & Internet Experts
ismael castillo
David
Jerry Greenberg
Jerry Greenberg
Are you a RIM Computer and Internet Expert? Answer questions, earn points and help others
