Question about Sony Handycam DCR-PC110 Mini DV Digital Camcorder
How to connect Sony DCR-PC110 camcorder to Mac Book Pro OSX 10.9.2 for audio/vidio capture
  • 473 Answers
SOURCE: Camcorder to Mac Sony dcr-hc32
Maybe this FAQ will help ya? Problem: Camcorder will not connect to iMovie - No camera attached Possible Solutions: * Are you using a 4 to 6 pin firewire cable? That is the ONLY thing you can use. No USB cables or anything else * Are you using a compatible camera? Still cameras that take movies are NOT a DV camera * How new is the cable? If it is pretty old or you have kinked, it you may need another one * Is the camera in DV mode? It should be. (Usually in the menu options somewhere) * Have read ALL of Apples help topics on this If your good with all the above: 1. Close iMovie 2. Delete all iMovie plist files for iMovie located in Home/Library/Preferences 3. Plug the camera in to the wall (electricity) 4. Make sure you have a good firewire cable and plug it in to the Mac from the camera 5. Turn off your camera 6. Reset your pram 7. When the Mac is booting, power on the camera 8. Start iMovie Sony camcorder special fixs: 1. Turn your camcorder to Play mode. 2. Press menu button (or relevant touch-screen button) 3. Click the 'ETC' item and then to CONTROL. 4. Select i-link (and not IR). or 1. Turn your camcorder to Play mode. 2. Press the Menu button (or relevant touch-screen button) 3. Scroll down the Menu to the 'ETC' option, if there is one 4. Click the 'ETC' item and choose 'VIDEO EDIT' if it's there 5. Click 'VIDEO EDIT' and 'MARK 1 IN' may appear 6. Click on 'MARK 1 IN' and then exit from the Menu options, by pressing the Menu button again Your Sony cam should now work OK with iMovie. * Reason? The camera and Mac can't decide which device is giving the FireWire instructions, and which is supposed to be receiving and acting on them. Using this sequence (above) lets the camera receive instructions from iMovie.
Posted on Sep 14, 2005
SOURCE: Capturing Footage with Camera
USB streaming does not work for Windows Vista. Use the firewire/ilink connection instead.
Roger
Posted on Mar 17, 2008
charcois
  • 763 Answers
SOURCE: Sony DCR-TRV530 firewire connection not recogized on Mac; won't import or capture video
try to use USB wire and then install the driver to your pc. hope that helps you!
CHARCOIS
Posted on Aug 21, 2008
SOURCE: XP Pro w /firewire not recognizing Sony DCR-TRV730
Try a video card that supports current DirectX. Apparently it has an effect even if you capture without previewing the video. (worked for me, anyway).
Posted on Sep 26, 2008
  • 435 Answers
SOURCE: i have a sony dcr-pc110. how can i see it on my
Check if it has the firewire port. If so, you can get a 4 pin firewire cable and connect to the PC.
Switch on the Cam.
Open Windows Movie Maker and import video from device.
4 pin firewire would look like this:
http://www.pcab.co.uk/ebay/firewire%204%20to%204.jpg
You can use the Movie maker to burn it to the Disk
Posted on Mar 10, 2009
Cassette stuck / wont eject from sony handcam DCR PC110
shut it off and than back on. check battery, if that don't work your motor is going out, needs to be service.
Mar 18, 2012 | Sony Handycam DCR-PC110 Mini DV Digital...
I WANT SOFTWARE FOR SONY DIGITAL VIDIO CAMERA RECORDER MODELNO. DCR-TRV285E .. FOR WINDOS 7
the best thing to do is use pinnacle studio 11 with a capture card installed in your pc no drivers required the pc will recognize your camcorders straight wich windows are you using?
Jul 31, 2011 | Sony DCR-TRV285E Digital-8 Digital...
I Have a Sony DCR-HC90 and I'm having trouble connecting my camera into my mac. I Have a usb cable but the camera won't connect to my computer
USB will only download still photos or movie shorts stored on a card. eg memory stick.
If no card is in the camera then no connection.
If you wish to capture movies stored on the tape, you will require a firewire cable to connect.
Use iMovie to capture the footage or another Mac application like Final Cut if availble on your Mac.
Apr 16, 2011 | Sony Handycam DCR-HC90 Mini DV Digital...
I want to transfer video from sony Digital Video Camera Recorder DCR/TRV25E to my Macbook Pro. The camcorder uses Mini DV and I have a USB connection between the camcorder & Mac. Please let me know...
Hi - It's pretty easy. You would use the I.Link (Sony calls it) connector which is actually fire wire. So you would need a fire wire cable (about five dollars or so) between the camera and Mac, load up the built in Imovie software and you'll be ready to go.
Here's a link to a good video tutorial demonstrating the process.
http://video.about.com/desktopvideo/Apple-iMovie-video-capture.htm
Have Fun
Regards, Mikeywaf
Feb 27, 2011 | Sony Handycam DCR-TRV25E Mini DV Digital...
Trying to capture video from a sony dcr-dvd610 to final cut pro. How do I do that?
Connect your camera with the fire wire to your mac and choose easy setup a dv and u shold get the video in to capture
Feb 22, 2010 | Sony DCR-DVD610 DVD Camcorder
DCR-PC330E to MacBook Pro
unfortunatley all sony products only work on pc your best bet would be to transfere to dvd and import that way
May 27, 2009 | Sony Handycam DCR-PC330E Mini DV Digital...
I have a sony dcr-pc110. how can i see it on my
Switch on the Cam.
Mar 10, 2009 | Sony Handycam DCR-PC110 Mini DV Digital...
Sound recording not working
Try to set the "VCR Set" in the middle of the bar
Dec 30, 2008 | Sony Handycam DCR-PC110 Mini DV Digital...
Sony Handycam DCR-PC110 Mini DV Digital Camcorder Logo
182 people viewed this question
Top Sony Video Cameras Experts
Larry Stiles
Larry Stiles
Are you a Sony Video Camera Expert? Answer questions, earn points and help others
