Question about Polk Audio PSW10 Subwoofer
Polkaudio dsw 660 green light no out put
Please resolve my problem
I have the same issue. It started after the phase switch (0 degree or 180 degrees) broke. Light is green but no sound.
Posted on Jul 06, 2015
I need to replace a bulb in ceiling fan.The dead bulb is a 30 Watt Slyvania #FC9T9/DSW/RS I need to know the size as no one carries it.
You should be able to use one of the following as a replacement:
S6505
FC12T9/WW
32W T9 4 Pin Base Warm White Circline Fluorescent Light Bulb
Satco
S6507
FC30/SW FC9T9/SW FCL30LEX
30W T-9 9in 4-Pin
Satco
11085
FC12T9/KB
32W -Bulb: Circline T9 -Base:4-Pin G10q Single-End -
GE
20037
FC12T9/WW/RS
32W -Bulb:Circline T9 -Base:4-Pin
Sylvania
20233
FC12T9/DSW/RP
Sylvania
391227
FC12T9/SOFT WHITE
32W -Bulb:T9 Circline -Base: 4-Pin
Philips
Dec 01, 2014 | Dryers
What could be the issue with my sub woofer power?
Many of these SUB amps ended up with Capacitor failures in the Power supply section . Find someone who works on amps or TVs to have a look see.
May 26, 2014 | Polk Audio Polk DSW PRO 550WI Subwoofer
Why is my embarq 660 series DSL modem box's 1st
Telephone your Internet Service Provider, and have them check that you've paid your monthly fees, and that the DSL-modem at "their" end of your telephone-circuit has not failed.
Try a different DSL-modem, to see if your particular modem has "died".
Check the 2-strand or 4-strand wire from the DSL-modem to the wall-outlet, to make sure that it is properly connected.
Try a different 4-strand wire.
Aug 18, 2011 | Computers & Internet
Polk DSW Pro 600 quit working suddenly. The front LED will not come on. In the AUTO mode the light in continuously orange. In the AUTO and ON modes the light blinks green and you can hear a series of 6...
Hello
There is some short inside its circuit board, and you are seeing the short indication. Usually, the short will be with its output section, especially output to subwoofer. In an output short, we cannot predict the which components have failed, because, modern sets' output section is closley related to its tone amp section, directly coupled with. Therefore, there may be some fault occured to that stage also. Sometime it may not be. But when replacing components in its output section, most of the tonel section components also should be checked, otherwise the replaced output component will fail as soon as you switch on the set. If you have sufficiant knoledge in digital elelctronics, you can do it by yoursef. A good qulaity digital multimeter must be with you to proceed. The more you need is patience and concentration. if you have all, go to its woofer output stage, and check for faulty component. OK.
Mar 15, 2011 | Polk Audio DSW PRO 600 Subwoofer Speaker
Polkaudio psw202 won't turn on
Got the information from Polkaudio customer srevice. IC number is TDA7294.
Dec 14, 2008 | Polk Audio Audio Players & Recorders
Gps garmin nuvi 660
Please read the solution that resolved this problem for someone else. Most likely, you have already tried this. However, the antenna of your Nuvi 660 is the same as the 3xx Nuvi series. I know this because I have worked on them.
http://www.fixya.com/support/t1115882-garmin_nuvi_360
If the above procedure does not work for you, the entire antenna assembly will need to be replaced.
The other option is to purchase an external antenna for your Nuvi and plug it into the external antenna port (gold connector) on the Nuvi antenna assembly.
Best wishes,
- Jim
Oct 26, 2008 | Garmin Nuvi 660 GPS Receiver
Polk Audio PSW10 Subwoofer Logo
246 people viewed this question
Top Polk Audio Audio Players & Recorders Experts
 Grubhead
Grubhead
ed_dantes
Level 1 Expert
Are you a Polk Audio Audio Player and Recorder Expert? Answer questions, earn points and help others
