Question about Canon iPF700 InkJet Printer
Ipf700 error code is 03130031-2f16 - Canon iPF700 InkJet Printer
What is Canon ipf700 error code hardware error 03130031-2f1f
I have the same error. I have been told that I need to replace the purge unit. Can I do it myself and save big $.
Jun 23, 2014 | Canon iPF700 InkJet Printer
Erreur E 161 403 E
The error code in the problem statement indicates that the printhead has failed due to overheating. When this occurs, the printer "remembers" the condition, and will not operate until the printhead has been replaced by a technician who knows the service codes to reset the error condition and inform the printer that it has a new printhead.
Mar 04, 2014 | Canon iPF700 InkJet Printer
Canon ipf 750 e161-4050
The error refers to a purge motor failure. Which could explain why the printer is saying that you do not have enough ink. You can solve this error code by removing the purge unit. You have to replace the purge unit with a new one.
Read more: E161-4050 on iPF750. error not in manual. Cleaned print head? - What is this? Not on internet anywhere. I`m sure others have had this issue. :: Ask Me Fast at
Jan 11, 2013 | Canon iPF700 InkJet Printer
WE HAVE A IPF 700 AND IT PRINTS FOR 10 SECOND AND THEN COMES UT WITH HARDWARE ERROR 03130031-2726 CAN YOU HELP
when i start my Canon ipf700 it comes upwith error message hardware error 03130031-2618
Jul 01, 2010 | Canon iPF700 InkJet Printer
Error 3130031 Canon ipf700
we need to post us the 4 last digits of this error code.
The code you are posting is the same for lot of error codes
Dec 10, 2009 | Canon iPF700 InkJet Printer
Canon ipf700 error 03130031-2f13.
if after the code you had to shutter down, and then the plotter made a head cleaning, we fix just putting a little of oil in the band, in the section were the head print moves.
Nov 16, 2009 | Canon imagePROGRAF IPF710 Printer
As to enter SERVICE MODE canon imagePROGRAF iPF700?thanks
Service Mode - With power off, hold paper feed (paper select) button and info button while powering on, release after initializing screen.
Mar 13, 2009 | Canon iPF700 InkJet Printer
Disabling Ink level Detection Canon iPF700
you can disable it only if an error occures at the first in filling, with the latest firmware installed (ver 1.37) if the machine will starts normally then you can't disable it.
Mar 11, 2009 | Canon iPF700 InkJet Printer
Clean printer head for iPF700 instead of replacing
If you have blocked nozzles unfortunatelly you have to replace the print head.
What about the nozzle check pattern?
Jan 28, 2009 | Canon iPF700 InkJet Printer
Loading cut sheets
Try to check the paper media set on the plotter (roll/plain paper). It usually happens if paper media is not the same with the plotter setting. To change it, unload the paper, press the media button on the printer to the right media and load the paper again. It should work now.
Dec 06, 2007 | Canon iPF700 InkJet Printer
Canon iPF700 InkJet Printer Logo
147 people viewed this question
old marine
old marine
