Question about Samsung CLX3185 AllInOne Laser Printer
Reset imaging unit - Samsung CLX3185 AllInOne Laser Printer
How do i reset the trouble code c 2259
Black image unit motor failure. First open the front door remove the black image unit not the black toner!!!. Take the image unit and shake it so as to spread out all of the developer & toner inside the image unit along the whole length of the unit. The reason for this is as not have all of the developer/toner all at one end and the motor trying to turn with all that at one end or the other. Never store image units or toner vertically!!!!!
Now reinstall the image unit. and close the door. Opening and closing the front door will reset the machine . If it comes back good chance bad image unit.
May 13, 2014 | Konica Minolta KONICA BR BIZHUB C451...
I have tried using a new fuse to cause an imaging unit to reset on a Phaser 7400 but the fuse will not blow.
If the unit is remanufactured or if you know how, you will have to disassembly the imaging unit and replace the fuser that blowns or simply just solder it. http://www.uninetimaging.com/downloads/technical/xerox/english/Xerox_Phaser_7400_Reman_Eng.pdf
Graphic 27.
Mar 30, 2014 | Xerox Phaser 7400/DXF Laser Printer
Reset imaging unit of Minolta MagiColor 2210
when you replace the image unit for what ever color is the machine asking for
Feb 11, 2014 | Konica Minolta Minolta MagiColor 2210...
Reset image unit (Magenta) Konica Minolta Bizhub C352
Change the chip or enter in service mode and change the imaging unit life duration to long life.The copier displayed continuosly Please change the image unit,press OK and ignore.
Feb 13, 2013 | Konica Minolta bizhub Office Equipment &...
Where can i find,please, Minolta bizhub c550 imaging unit chip reseter?
Imaging unit reset automaticaly if a new is in copier.If you enter in the service mode you have a posibility to change the image unit life duration standard to long life.
Jan 24, 2013 | Konica Minolta Bizhub C550
How to reset image unit for C350 bizhub?
well there is a chip on the image unit that image unit (all colors) you need special chip writer to reset. you may need to just buy a new unit or drop me a line i may be able to get one...
Oct 27, 2011 | Konica Minolta bizhub C351 All-In-One...
Xerox Imaging Drum reset ? for Xerox Phaser 2135
The only way to reset the image unit drum is installing a new one. The new image unit has a fuse which once blown it resets the counter on the machine. You can call www.iteminconline.com I have their information in my ad place. They are good techs. I once called for a 7300 image unit reset and they said it was almost the same as a 2135 and they gave me this information. well goodluck.
Jul 24, 2009 | Office Equipment & Supplies
Konica Minolta C353 has a C4551 error, how do I fix it?
try replacing the imaging unit with a new one not a reset imaging unit
Mar 10, 2009 | Konica Minolta bizhub 250 All-In-One Laser...
Imaging unit
No, the imaging unit will only reset back to zero if you replaced it.
Feb 22, 2008 | Samsung CLX 3160fn All-In-One Printer
Resetting the imaging unit
How do you reset the imaging unit?
Dec 19, 2007 | Samsung CLP-510 Laser Printer
Samsung CLX3185 AllInOne Laser Printer Logo
32 people viewed this question
Top Samsung Office Equipment & Supplies Experts
mukhtar21 shaikh
mukhtar21 shaikh
HEMANT GROVER
CheckitRight
CheckitRight
Are you a Samsung Office Equipment and Supply Expert? Answer questions, earn points and help others
