Question about Birds
Found black bird with orange and yellow strip on the side
5 Suggested Answers
  • 4848 Answers
SOURCE: I have a 1998 ford fiesta and I am trying to
Is this website of any use?
http://www.tehnomagazin.com/Auto-radio-car-connector/FORD-Car-Radio-Wiring-Connector.htm
Posted on Sep 11, 2009
ourhowse
  • 2007 Answers
SOURCE: I have a pre fab wiring harness on my trailer with
I assume you only want lights, brake lights and signals. Your best bet is to plug a wire onto your truck... the flat plug, and turn , first the left signal, on. Use a test light to see which part of the plug in is flashing. Once you have established that, just keep plugging the other end of the wire into the trailer plug, until you get the left turn signal flashing on the trailer. Then repeat the process for lights etc.
You can also take the plug-in apart on the trailer. Inside the plug in it will have l/t, r/t, s, etc. (left turn, right turn, stop, etc.) There will be a very small arrow pointing to the terminal connection that is for each.
Posted on Nov 03, 2009
Testimonial: "Thanks, that should be an easy and sure way."
  • 171 Answers
SOURCE: HAVE A P05091506AE STEREO WANT TO CHANGE TO A JVC
This is the wiring codes
2005 Dodge Ram 1500 Truck Car Radio Stereo Wiring Diagram
Car Radio Battery Constant 12v+ Wire: Pink
Car Radio Accessory Switched 12v+ Wire: Brown/Red
Car Radio Ground Wire: Black/Dark Green
Car Radio Illumination Wire: Orange/Dark Blue
Car Stereo Dimmer Wire: N/A
Car Stereo Antenna Trigger: N/A
Car Stereo Amp Trigger Wire: Dark Green/Red
Car Stereo Amplifier Location: Located behind the glove box.
Car Audio Front Speakers Size: N/A
Car Audio Front Speakers Location: N/A
Left Front Speaker Positive Wire (+): Dark Green
Left Front Speaker Negative Wire (-): Brown/Red
Right Front Speaker Positive Wire (+): Violet
Right Front Speaker Negative Wire (-): Dark Blue/Red
Car Audio Rear Speakers Size: N/A
Car Audio Rear Speakers Location: N/A
Left Rear Speaker Positive Wire (+): Brown/Yellow
Left Rear Speaker Negative Wire (-): Brown/Light Blue
Right Rear Speaker Positive Wire (+): Dark Blue/White
Right Rear Speaker Negative Wire (-): Dark Blue/Orange
Posted on Dec 26, 2010
  • 3 Answers
SOURCE: jeep grand cherokee 2000 rear light wire colours
Hi, You must use a volt meter on D.C. current to identify the hot wire. Car wiring is different than household. Any given color may be hot. So key on, lights on. and use a volt meter. Use voltmeter red probe for hot and touch black to any body ground. If shows voltage in D.C. Volt Meter in this manner that is your hot wire. On my SUV the hot was the white waire at the backup light circuit as the tail lamp.
Posted on Apr 09, 2013
Need a wiring diagram on suzuki raiderj 110. Please. Tnx.
Maybe you can use these codes taken from:
http://www.motorcyclephilippines.com/forums/showthread.php?120554-Motorcycle-Electrical-Wiring-Diagram-Thread
This is a Wiring Harness Guide for Suzuki Smash, Raider J, ShogunR/Pro Motorcycles. It may also be applicable to Hayate, Step, Mola and Raider 150.
CDI
ORANGE - from Ignition +ACC
BLACK/swhite - Ground
WHITE/sblue - to Ignition Coil
BLUE/syellow - to ENGINE Stator side
ENGINE - Stator Single Phase
WHITE/sred - To RECTIFIER
YELLOW/swhite - To RECTIFIER
BLUE/syellow - from CDI sensor
ENGINE - Transmission Gearbox
GREEN/sblue - 1st Gear
YELLOW/sblue - 2nd Gear
WHITE/syellow - 3rd Gear
RED/swhite - 4th Gear
BLUE - Neutral
ENGINE - Rear Side
PINK - Odometer Speed Sensor
ORANGE/sred -
ELECTRIC Start RELAY
YELLOW/sgreen - form Starter Switch
BREAK - Foot pedal
ORANGE - From ignition + ACC
WHITE/sblack - to Break light
BREAK - Hand Lever
ORANGE - from IGNITION + ACC
WHITE/sblack - To BREAK Light
FUEL Sensor
Yellow/sblack - to Console
REAR - Lights
WHITE/sblack - form BREAK foot/hand
GRAY - From Night Switch
BLACK - from Left Turnsignal
LIMEGREEN - from Right TurnSignal
Signal Flasher Relay
ORANGE - from Ignition + ACC
LIGHTBLUE - Signal SW
RECTIFIER
WHITE/sred - From STATOR
YELLOW/swhite - From STATOR
RED/sorange - BATT+/HEAD LIGHT
IGNITION Key
RED - from FUSE
ORANGE - to ACC
HORN Switch
Green - to Horn
HORN
GREEN - from HORN Switch
ORANGE - Ignition + ACC
NIGHT Switch
RED/sorange - From Rectifier
GRAY - To REAR LIGHT/HEADLIGHTThis is a Wiring Harness Guide for Suzuki Smash, Raider J, ShogunR/Pro Motorcycles. It may also be applicable to Hayate, Step, Mola and Raider 150.
CDI
BLUE - Neutral
ENGINE - Rear Side
ORANGE/sred -
BREAK - Foot pedal
BREAK - Hand Lever
FUEL Sensor
REAR - Lights
RECTIFIER
IGNITION Key
RED - from FUSE
ORANGE - to ACC
HORN Switch
Green - to Horn
HORN
NIGHT Switch
CDI
BLUE - Neutral
ENGINE - Rear Side
ORANGE/sred -
BREAK - Foot pedal
BREAK - Hand Lever
FUEL Sensor
REAR - Lights
RECTIFIER
IGNITION Key
RED - from FUSE
ORANGE - to ACC
HORN Switch
Green - to Horn
HORN
NIGHT Switch
Dec 27, 2015 | 2006 Suzuki Stratosphere
Image of orange birf
Ahh the famous Orange Birf! It can be found deep in the forests of the republic of San Seriffe, waking you in the early morning with it's distinctive call...."birf birf birf" Orange Birds Wallpaper
May 12, 2014 | Birds
NEED WIRING DIAGRAM FOR SONY CDX-GT520U
red - ignition switched 12 volt
yellow - constant power 12 volts
black - ground wire
orange - dimmer wire don't use
speaker wires
drive side front
white +
white/black strip -
passanger front
gray +
gray/black strip -
drivers rear
green +
green/black strip -
passanger rear
purple +
purple/black strip -
blue - remote amp turn on wire
blue/white strip - either power antenna or remote amp turn on also
radiorepair@windowtintingin239.com
Oct 30, 2013 | Car Audio & Video
Need the pin positions of the wire harness
  • red is switched ignition 12 volts (only on with cars running)
  • yellow is constant power 12volts ( have voltage at all time even when car off this wire allows you to save station and clock so you are not allway resting the clock and stations)
  • black is ground ( connected to the frame of car or a good metal part that is connected the frame of car with out a good ground the circuit will not be completed and the radio will not power up )
  • white drive side front (+) speaker wire
  • white/black strip driver side front (-) speaker wire
  • gray passanger front (+) speaker wire
  • gray/black strip passanger front (-) speaker wire
  • green driver side rear (+) speaker wire
  • green driver side rear (-) speaker wire
  • purple passanger rear (+) speaker wire
  • purple/black strip passanger rear (-) speaker wire
  • blue or blue/white strip wire is (remote amp turn on or power antenna )
  • orange wire is (dimmer for light in car )99% of all cars these days don't use this wire
have any question email me at radiorepair@windowtintingin239.com
Oct 27, 2013 | BOSS AUDIO SYSTEMS 636CA
I have a jvc kdavx1 trying to hook up to a 2000 buick reagal need to know how the wires hook up
Please let me know if you have questions, and thanks for using FixYa.
2000 Buick Regal Car Stereo Install Diagram jvc kdavx1
Radio Constant 12V+ Wire: Orange yellow
Radio Ignition Switched 12V+ Wire: Yellow red
Radio Ground Wire: Black/White black
Radio Illumination Wire: Gray/Black orange/white
Left Front Speaker Wire (+): Tan white
Left Front Speaker Wire (-): Gray white/black
Right Front Speaker Wire (+): Light Green gray
Right Front Speaker Wire (-): Dark Green gray/black
Left Rear Speaker Wire (+): Brown green
Left Rear Speaker Wire (-): Yellow green/black
Right Rear Speaker Wire (+): Dark Blue purple
Right Rear Speaker Wire (-): Light Blue purple/black
parking brake: blue light green
For this last wire, access the back of the parking brake to find a switch with a blue wire. Peel some insulation from the wire and wrap the stripped end of a 3 foot piece of 16 or 18 gauge wire around the stripped section. Solder and wrap the connection with electrical tape, route the wire to the jvc, then strip and solder the other end to the pigtail of the head unit.
If you are also installing a camera seeing behind you when backing, you will need to run a wire to the back-up light on the driver side reverse light (light green) wire along with your video cable.
May 30, 2011 | JVC Car Audio & Video
HAVE A P05091506AE STEREO WANT TO CHANGE TO A JVC KD-R900 NEED TO KNOW WHAT THE WIRING ON MY 2005 DODGE RAM 1500 PIN CONNECTOR IS. 22 PIN CONNECTOR. COLORS ARE NOT MATCHING ANYTHING I CAN FIND ON...
Dec 25, 2010 | JVC Car Audio & Video
Need a wiring diagram for a radio on a 93 Explorer. The speaker wires in my truck are Green, Purple with white stripe, yellow, blue w/white stripe, Lt. Blue , Orange w/white strip, brown, and red w/white...
Constant 12V+ Green/Yellow
Switched 12V+ Yellow/Black
Ground Black
Illumination Blue/Red
Dimmer n/a
Amplifier Remote Blue
Antenna Right Front
Front Speakers 5" x 7" Doors
Left Front (+) Orange/Green
Left Front (-) Blue/White
Right Front (+) White/Green
Right Front (-) Green/Orange
Rear Speakers 5" x 7" Rear Doors
Left Rear (+) Pink/Green
Left Rear (-) Brown/Yellow
Right Rear (+) Orange/Red
Right Rear (-) Black/White
THanks for using FixYa - a 4 THUMBS rating is appreciated for answering your FREE question.
Sep 08, 2009 | JVC KD-G210 CD Player
I need the wiring diagram for my new Clarion dxz385usb
Brown wire-Phone mute Yellow 3A-Bus power lead Yellow 15A-Memory backup lead Red-Power lead Blue/White-Amp lead Black-Ground Orange/White-Illumination lead Blue-Auto antennae SPEAKERS(black strip is -ive) gray+gray/black-front right white+white/black-front left purple+purple/black-rear right green+green/black-rear left
Jul 02, 2009 | Clarion DXZ385USB Car CD/ MP3 Player
Birds Logo
64 people viewed this question
Top Birds Experts
Tom Chichester
Are you a Bird Expert? Answer questions, earn points and help others
