Question about Canon iPF700 InkJet Printer
Ipf700 hardware error
The screen.say hardware error what does that mean
What is Canon ipf700 error code hardware error 03130031-2f1f
I have the same error. I have been told that I need to replace the purge unit. Can I do it myself and save big $.
Jun 23, 2014 | Canon iPF700 InkJet Printer
Hardware error 03800500-2F2F
I had this issue on my IPF700 and called Cannon at 1-800-423-2366 and they were able to walk me through on the phone to fix the issue. I had air in my ink line in C and M and had to take out ink cartridges 10 times and also updated firmware. All fixed now!
Jun 06, 2011 | Canon imagePROGRAF IPF710 Printer
WE HAVE A IPF 700 AND IT PRINTS FOR 10 SECOND AND THEN COMES UT WITH HARDWARE ERROR 03130031-2726 CAN YOU HELP
when i start my Canon ipf700 it comes upwith error message hardware error 03130031-2618
Jul 01, 2010 | Canon iPF700 InkJet Printer
I get an error on Hardware error 03130031-2F26
This is a carriage move error.
Please check visaully if there is any foreign object (like paper) inside the machine that blockes the move of the carriage.
Dec 17, 2009 | Canon iPF700 InkJet Printer
Error 3130031 Canon ipf700
we need to post us the 4 last digits of this error code.
The code you are posting is the same for lot of error codes
Dec 10, 2009 | Canon iPF700 InkJet Printer
Canon IPF 700 with a hardware error 03800500-2f30. Please help
this means that you have no ink flowing from the nozzles.
1.st if possible print a nozzle check from test print menu an see the result.
the other issue i can imagine is that you replace the print head without perform firmware update.
It is very important before replacing the print head to perform firmware upgrade (cd incl. inside the head box)
Also try a head cleaning B twice or more
Oct 29, 2009 | Canon iPF700 InkJet Printer
Hardware error 031300-2f26
check if a foreign material (like paper) is stracked inside the machine.
Usually we find paper on the right side of the machine above the purge unit.
Sep 28, 2009 | Canon iPF700 InkJet Printer
As to enter SERVICE MODE canon imagePROGRAF iPF700?thanks
Service Mode - With power off, hold paper feed (paper select) button and info button while powering on, release after initializing screen.
Mar 13, 2009 | Canon iPF700 InkJet Printer
Disabling Ink level Detection Canon iPF700
you can disable it only if an error occures at the first in filling, with the latest firmware installed (ver 1.37) if the machine will starts normally then you can't disable it.
Mar 11, 2009 | Canon iPF700 InkJet Printer
Canon iPF700 InkJet Printer Logo
19 people viewed this question
old marine
old marine
