Question about LG LFX25971ST Bottom Freezer French Door Refrigerator
Why won't the Air filter cover turn to allow removal ?
I am needing to change the air filter for the first time. After watching the you tube video, as well as reading and following the written directions I am unable to get the air cover of my French door LG to budge.
SOURCE: Trying to change LG side-by-side fridge filter
I used a strip of Duck Tape to make a handel. Just stick it to the sides with a loop at the bottom. This will allow you to pull with more force...
WARNING, dont break it! I have a small leak now. I have removed the two screws to access the whole receptical that holds the filter. It now leaks a few drops on the left side when water is dispensing or filling ice tray. I need to find a replacement now.
Posted on Sep 11, 2008
MNTECH
  • 1543 Answers
SOURCE: lg french door refrigerator new house no instruction book.
Press and hold the filter indicator pad for at least 3 seconds to reset.
Posted on Dec 11, 2008
  • 864 Answers
SOURCE: Tried to replace the filter and after that the upp
I don't think replacing the filter had anything to do with your problem.  If the ice maker is working then the freezer is OK since they have the same cooling source.  I had the same problem with this model refrigerator six months after I got it (in 2/2007).  The cooling in the refrigerator section failed.  The refrigerator fan and the air duct as well as the mother board were replaced.  A year later the ice-maker fan froze up. It and the housing were replaced with improved models.  The mother board was also replaced again due to software changes related to the ice maker.  This model is also part of an Energy Star/LG case agreement to modify the circuits and provide a lifetime annual rebate payment.  Check it out and register on the LG web site.
Posted on May 20, 2009
SOURCE: how do I reset the lg water filter indicator light
i fixed the problem by asking my son. he has more patience than i and just held down the button longer and it worked.
Posted on Oct 15, 2009
SOURCE: lights stay on inside Sears (really LG) french door refrigerator
That should be a covered repair. There was a safety bulletin on that. Call Sears and complain. Tech should have known that.
Posted on Jan 12, 2010
Testimonial: "Thanks so much I did get a fix for this time but I guess they won't take care of the first time. I appreciate your help."
If the filter is clogged would it quit working
Hi there! If the filter is clogged this will cause the vacuum to lose suction and possibly shut-off. Below are instructions to checking and cleaning your filters.
1. Remove the dirt cup. Twist off the dirt cup lid.
2. Remove the filter cartridge from dirt cup.
3. Separate the foam and cartridge filters. Wash foam filter under running. Allow 24 hours to air dry outside the vacuum.
4. Tap the excess dirt out of Hepa filter. Hepa filter may also be washed. Allow 24 hours to air dry.
5. Check the secondary filter by removing the filter cover from base. Rinse the foam filter under running water until it runs clear. Allow 24 hours to air dry.
6. The red baffle tube inside of the dirt cup is apart of the filtration of the vacuum and needs to be cleaned as well. Twist out the baffle tube by turning 1/4 turn clockwise. Remove any hair or debris wrapped around baffle tube. Baffle tube can be rinsed if needed. Allow to dry thoroughly.
If the filters are too dirty they may need to be replaced. With regular maintenance the filters should be replaced about once a year. Follow the links below to order replacement filters for your UH20020.
Primary Filter
Exhaust Foam Filter
Hope this helps!
Jun 12, 2014 | Hoover Nano Cyclonic Compact Bagless...
No dirt in cup and the red thing does not turn
Hello! It sounds like your vacuum has lost suction. This is caused by either a clog or a filter that needs to be cleaned or replaced. Please try these brief trouble-shooting steps.
7. Remove the hose from both ends. Use a broom stick to loosen and remove any clogs from the main hose.
8. Remove the bottom plate and the brushes as instructed in the owner's manual. Use a wooden spoon or something similar to gently break up and remove any clogs from the lower hose.
Exhaust Foam Filter
Primary Filter
Hope this was helpful!
May 10, 2014 | Hoover Nano Cyclonic Compact Bagless...
Resetting
Hello! The vacuum will reset itself, you only need to allow it time to cool off.This can take up to an hour. Overheating is usually caused by a clog or a filter that needs to be cleaned or replaced. Below are simple instructions for checking your vacuum for clogs.
Primary Filter
Exhaust Foam Filter
Mar 23, 2014 | Hoover Nano Cyclonic Compact Bagless...
How do you change the air filter
This is a fairly simple repair, just follow these instructions below.
  • Turn OFF the ignition.
  • Disconnect the intake air temperature (IAT) sensor.
  • Disconnect the breather tube from the air intake duct.
  • Disconnect the mass air flow (MAF) sensor.
  • Loosen the air intake duct/MAF sensor hose clamps.
  • Carefully remove the air inlet hose from the throttle body and air cleaner cover.
  • Remove the 2 housing cover retaining clamps.
  • Remove the air cleaner cover (5) and carefully remove the air filter element (6).
  • Inspect the housing cover (5), seal assembly, and air duct (2) for damage.
    Apr 04, 2011 | 2001 Chevrolet Impala
    How do I change the air filter, not air conditioning filter, for the engine on a 2005 Crossfire?
    The air filter is in the air intake box (usualy square plastic tub) under the hood. A couple of clips unsnap and the top comes off. Replace the element inside.
    Mar 14, 2011 | 2005 Chrysler Crossfire
    How do you change the engine air filter in a 2008 toyota sienna
    REMOVE ENGINE COVER DISCONNECT MASS AIR FLOW SENSOR CONNECTOR.LOOSEN AIRDUCT FLOW TUBE SCREWS THEN REMOVE AIR FILTER COVER HOUSING BOLTS THEN RAISE AIR FILTER COVER UP SLIGHTLY ENOUGH SLIDE IT AWAY FROM AIRFLOW DUCT.THEN REMOVE COVER REPLACE AIR FILTER THEN PUT EVERYTHING BACK UP VISA VERSA DONT FORGET TO TIGHTEN SCREWS TO AIRFLOW DUCT TUBE ONCE AIR FILTER HOUSING BACK IN PLACE.
    Aug 31, 2010 | 2008 Toyota Sienna
    How do you change an air filter on a 2007 chevy malibu?
    TO REMOVE AIR FILTER LOOSEN THE CLAMP SECURING THE INLET TUBE TO THE AIR FILTER COVER.REMOVE THE SCREWS THAT SECURE THE TWO HALVES OF THE AIR CLEANER HOUSING TOGETHER THEN REMOVE TOP COVER AND REMOVE AIR FILTER.
    Jul 03, 2010 | 2007 Chevrolet Malibu SS Sedan New Cars
    Where is the a/c cabin air filter located in a 2005 outlander
    • It is behind the glove box. There is a tab on the inside of the glove box on the left side that needs to be pressed in and then a plug that you slide to remove. The glove box will now pull forward and down exposing the access panel. Now you see the access panel for the cabin air filter. Remove the two Phillips screws and pull the filtyer housing forward and remove and replace the cabin air filter...
    • Here is a video that will help as well.
    http://www.youtube.com/watch?v=qY4MsDlepP8
    • Hope this helps.
    utube.png You-Tube video "qY4MsDlepP8 " placeholder (do not delete) utube.png
    Jan 03, 2010 | 2005 Mitsubishi Outlander
    Removing VW polo 2005 battery?
    Removing a battery from a Beetle is a bit complex and tricky. I just changed the battery in a 2003 2.0 Beetle. However, the process is very similar in a TDI Beetle. You will need more than your standard generic tool set in order to complete this task. Your tool list needs to consist of a pair of pliers (prefer locking type), a # 20 TORX head screwdriver (You will also need this if you ever plan on changing the Beetle's internal dash pollen filter for the A/C. ), a 10 mm and 13 mm sockets, a long extension and a wobble or universal to allow flexibility in tight spaces, an allen socket for removing the power steering reservoir, and a small adjustable wrench or a 10mm to remove the battery cables. If you are changing the battery you might as well buy a new Air filter since you will need to remove the air box in order to replace the battery. If you do change the air filter you will need a phillips head screwdriver.
    1. Pop the hood.
    2. Remove the two 10 mm bolts that hold down the air filter box.
    3. Undo the clamp that holds the large tubing to the air box using your pliers. Move the tubing away from the box.
    4. Unclip hose attached to the back of the air box near the large hose (under it).
    5. remove the small breather hose from the air box.
    6. Pull air box up and out.
    7. Remove snap on cover from top of battery.
    8. Remove small snap on wiring cover from back of the battery covering.
    9. Unbolt power steering reservoir (next to battery case).
    10. Disconnect the battery cables. Positive side first.
    11. Remove the 13 mm bolt at the base of the battery along with the hold down clamp.
    12. Pull the top wiring away from the battery case and then slide the battery towards the engine.
    13. Remove the plastic battery case.
    14. Remove the battery
    Oct 07, 2009 | 1997 Volkswagen Jetta
    LG LFX25971ST Bottom Freezer French Door Refrigerator Logo
    181 people viewed this question
    Top LG Refrigerators Experts
    Charles T Nevin
    Charles T Nevin
    John Tripp
    John Tripp
    Dan Webster
    Dan Webster
    Are you a LG Refrigerator Expert? Answer questions, earn points and help others
