Question about Sharp MX-2300N Color Copier
I have a Sharp MX-M283N copier/printer that stopped printing on my PC what can I do
All the other employees in the office can print but her. I've tried rebooting her laptop and turning the copier on and off but it still wont print, what can I do
SOURCE: MX-2300N Sharp Copier will not print
Do you have setup accounts on the copier?
Posted on Apr 02, 2009
SOURCE: SHARP AL-2040CS offline after reboot
Official Sharp driver had set "use printer offline" setting in the printer properties context menu. After unselecting the "use printer offline", printer is printing again, even after reboot...
Posted on Jun 18, 2009
  • 120 Answers
SOURCE: hello i have copier machine sharp mx-450u,with
As a general rule, U machines are not designed to be turned into network printers, that's what the MX-M450N is for. You can put an MX-NBX3 on it, it might work properly and it might not.
The NBX3 can only function properly with a hard drive in the copier, otherwise you're outta luck!!
Your driver type may be wrong. If you are currently using PCL6, try PCL5e.
Other than that, try getting a new driver from the Business Copiers section of sharpusa.com. You may have to see which model will work for you. Look for the PCL driver for MX-NBX3, then look for MX-M450U, then MX-M450N.
Posted on Jul 09, 2009
  • 118 Answers
SOURCE: We have a spooling problem. The sharp mx-2300n
Go into the Job review mode and highlight the pending print job (note: it may be stuck in processing). You should then get the option to delete the job.
Make sure that the pending print job is also cleared from the network print queue. They can sit in the queue and be persistent on processing, even after you've cleared the copier. Clear the queue prior to deleting the job on the copier.
If this doesn't, disconnect the copier from your network and try the above steps again, then reboot the copier and reconnect it to your network.
If you're trying to print out Adobe-based web pages from the internet, this may be what's causing your copier to jam up. There's known coding anomalies with Adobe-embedded documents on web pages. Trying to directly print from the web page can stall or lock up the print process.
Posted on Sep 10, 2009
  • 11 Answers
SOURCE: MX-2300N Color Copier: I have a Sharp MX-2300N that has just suddenly sta...
yes open the front door remove the waste toner and you will see the 4 drum units each with a little green stick pointing out
pull this in and out a few times on each unit ...
hope this helps
Posted on Jul 13, 2010
Secure print
I have a walkthrough on my website on how to secure print.
Check it out here under confidential printing:
How To Sharp Copier Printer Scanner Instructions Troubleshooting...
Jun 24, 2014 | Sharp Mx-5111n Multifunction Copier
A line across the page when printing and coping
try to look for some foreign objects on the scanner area.. a dirt stock on the scanner glass if it has adf and a dirt on the mirror if it soes not have an adf.
Feb 13, 2014 | Sharp MX-M283N Copier
Creates a line when coping and printing on the pages
vertical line or a repetitive horizontal line? Please describe in fullest detail what yo're getting.
Sharp m453n e7-11
This is the white ref strip under the glass.
It may be dirty, dirty optics or dirty lamp or lamp may need to be changed
Feb 05, 2013 | Sharp Toner for MX-M283N, MX-M363N/U,...
Our Data light keeps flashing and the printer won't print. How do we get the data light to stop flashing so we can use our copier again with our computers?
Sounds like a bad print job stuck in a print spooler.
Turn off copier. Go around to all computers that print to it and open the print queue. delete all print jobs. reboot each PC. Power up copier and see if it clears
Jan 15, 2013 | Sharp Mx-M450nb Digital Copier
Sharp MX-2300N - can only print on computer restart
You will have to contact Sharp's service department.
Apr 30, 2012 | Sharp MX-2300N Color Copier
I just installed driver for my mac to mx2300n printer. When I print a page from my computer the printer heats up and acts like it is going to print, but never picks up a page from the tray and never prints...
For a Mac to print to the Sharp MX-2300N the Postscript Kit (MX-PKX1) has to be installed on the copier. If that is not installed you will not get any mac to print to it.
Sep 05, 2011 | Sharp MX-2300N Color Copier
Feb 11, 2009 | Sharp MX-2300N Color Copier
Sharp MX-2300N Color Copier Logo
Top Sharp Office Equipment & Supplies Experts
Anthony Karuku
k24674
jasbo
jasbo
Are you a Sharp Office Equipment and Supply Expert? Answer questions, earn points and help others
