Question about Husqvarna Garden
IS THERE A FUEL VENT?
HUSKY 61 EARLY 90S ,HARD TOMSTART WHEN HOT,ANY SOLUTION,IS THERE A FUEL VENT , CANT SEE ONE ,THANKS
    Cheetah:
    An expert who has answered 20 or more questions within one hour.
  • Husqvarna Expert
  • 188 Answers
IS THERE A FUEL VENT? - afbsa8j0kw+jaaaaaelftksuqmcc
Posted on Jan 15, 2016
There's no power to the fuel pump is there an emergency cutoff
Very few cars had them...mostly ford's from the late 80s and early 90s.
Aug 22, 2016 | Cars & Trucks
Fuel pump relay switch location 2006 toyota corolla
There isn't one. Almost no vehicle has one. They were common only in ford vehicles in the late 80's and early 90s.
Aug 17, 2016 | 2006 Toyota Corolla
I have a Husqvarna 61, it starts fine and will cut wood happily for the first five minutes of use, but then it looses power and stalls. It will start again fine, but then cuts out again soon after....
Start withe the inexpensive stuff first, pull the fuel hose out of the tank and change the filter on the end, by your discription it could also be an electrical issue, the early 61 had a two peice system, an electronic block to the left of the flywheel, and a coil at the right, if you have this system check the where the yellow two wires connect under the head of a self tapping screw under the coil, if the connection is ok it may well be a case of replacing the electronic box. The later 61 has a single peice ignition system, this may be breaking down when it gets hot, and need replacing.
Let me know how it goes, and if you need help with part numbers etc.
Mar 14, 2011 | Husqvarna Garden
When saw is running it dies unless i undo the vented gas cap then the saw will keep going is there any other way on other than the gas cap for it to vent or help breath? on a 372 xp
The vent on the 372 is not in the cat, it is situated on the right hand rear side of the fuel tank, the early vent was a black pipe pressed into the tank with a white ( vion ) plug in it, this can be pulled out by screwing a self tapping screw into the middle of it and pulling out with a pair of pliers, the later breather is in the same place but consist of a green valve pressed into the tank, it then has a black pipe conected to it which comes up into the crankcase and sits onto a nipple under the air filter, this can be pulled out with a pair of pliers and replaced, the later breather is very prone to blocking, due to CE law and gas escape from fuel tanks the breather is very fine.
Jan 25, 2011 | Husqvarna Operator's Manual 365 372xp ...
Carb assembling question
Thanks Jerry.
The only that came to my mind is to try here:
ArboristSite Chainsaw thread (free to join)
http://www.arboristsite.com/forumdisplay.php?f=9
I did a quick search and saw nothing for a 61 carb but it does not mean it is not there. Someone at Arborists has rebuilt your carb. The hard part will be digging them out then dredging up the right memories. Good Luck. HTH Lou
Mar 05, 2010 | Husqvarna Chainsaw Piston Kit for 61...
Fuel leaking at the fuel filter attached to fuel line outside of fuel tank . The little niple that the fuel line connects to, that has a filter at the end. This is on my model 345 HUSQVARNA chain saw....
The fuel tank vent is whats leaking.Some saws that have primer bulb set up were sent from factory with the primer return hose not being long enough so it will either come off or break at the tank vent/filter.I have seen some saws leak around the tank vent when temps are below 10 degrees F due to tank plastic distorting from the cold weather.
Feb 22, 2010 | Garden
Garden Logo
42 people viewed this question
Top Husqvarna Garden Experts
Phil Walker
Phil Walker
Roland W VanLue
Roland W VanLue
Are you a Husqvarna Garden Expert? Answer questions, earn points and help others
