Question about Lionel Train Volkswagon Beetle Flat Car 6-19483 O Scale
What is flashing car symbol mean? - Lionel Train Volkswagon Beetle Flat Car 6-19483 O Scale
The unit keeps flashing
By unit, do you mean the thermostat? And if so, do you mean the whole face is flashing, or just a heat or cool symbol? And if your talking about the heating/cooling unit, are you talking about a flash on the board?
A thermostat face that is flashing is usually batteries.
A symbol that is flashing on a thermostat indicates a call and is in a delay. There will be a 5 minute delay on calls if the call has been short cycled, powered off and on, etc.
If the symbol continues to flash for an extended amount of time, then the problem is in the furnace, air handler, etc.
If the system is working, but flashing, then it could be the programming of the thermostat.
Dec 02, 2013 | Honeywell Heating & Cooling
I changed out my ecu and im getting a car symbol with a key at the bottom of it and it wont stay running what does that symbol mean
You can't just throw a ECU in the car it must be programmed by the dealer or any shop with the right equipment to flash the ECU The ECU also controls the factory secuity system, that is what the symbol means, the secuity system is triggered..
May 06, 2011 | Audi A4 Cars & Trucks
What does car with lock symbol mean
This symbol is usually your security light it flashes when the vehicle is locked. It comes on solid and goes out after it recognizes the key. And it flashes fast when it thinks it's an invalid key
Jan 19, 2011 | 2009 Hummer H3
Have just purchased a 2006 Mazda 6 Atenza and noticed that there is a light on the dashboard that is continually blinking - it is a car with a key symbol in it. I refered to the manual but it is in...
This symbol is normally the car electronic immobiliser symbol and should not be lit once the car is started.
If it keeps on flashing and the electronic immobiliser is installed properly, it will prevent your car from being started.
Flashing symbols means immobiliser code is invalid or uncoded.
Hope the information is useful.
Oct 03, 2010 | 2006 Mazda 6
The second light from the left in the lower left hand corner of my Vostro 1510 is flashing. It looks like it might mean the battery is charging - ie it has a lightening -like symbol in the middle of the...
A flashing orange battery charging light is a failry universal symbol that means the battery is detected, but NOT charging. Usually, this means the battery has gone bad. In some cases, a slow orange flash means bad, a fast flash means very very low charge (or vice versa)
For your laptop in particular, go here for official illustrated documentation on the battery lights and meanings :
http://support.dell.com/support/topics/global.aspx/support/dsn/en/document?c=us&dl=false&l=en&s=gen&docid=12FCCAA558727884E0401E0A55172D6B&doclang=en&cs=
The above url is all one line.
Sep 08, 2010 | Dell Vostro 1510 Laptop
What does the ! in the traingle symbol on printer p2015dn mean as printer not working and this symbol is flashing
If just that light is flashing then it most likely means that the print cartridge door is open
Sep 30, 2009 | HP LaserJet P2015dn Printer
Flashing Battery Symbol on GPX PDL805
The appearance of a battery symbol while you are using just the battery means that you are using just the battery.
That's it.
No Problem.
The flashing battery symbol is a constant reminder to you that a power intensive function is only supported by the battery, and that you should make external power available so as to complete the task without losing power in a battery drain event.
May 07, 2009 | GPX PDL805 Portable DVD Player
Need a guide to dash/warning lamp symbols for my Hilux
well thats the pattern? for example, 4 blinks pause 3 blinks.
Feb 22, 2009 | 1993 Toyota Pickup
FLASHING AMBER UNDER LIGHTNING SYMBOL
Is it an amber lightning bolt? (I am assuming thats what you mean by UNDER lightning symbol)
That is the charging symbol for your battery, it means your battery is being charged by your power adapter.
Jan 29, 2009 | Compaq Presario X1000 Notebook
Lionel Train Volkswagon Beetle Flat Car 6-19483 O Scale Logo
27 people viewed this question
Top Lionel Crafts & Hobbies Experts
Jeff Hogancamp
Jeff Hogancamp
J.D. Browning
J.D. Browning
ray gallant
Are you a Lionel Craft and Hobby Expert? Answer questions, earn points and help others
