Question about Kenwood Breadmaker Kneading Blade Paddle Bm 210 -s
Kenwood bm210 kneeder paddle gets stuck in bread?
Everything else works well, the bread comes out perfectly, but, the kneading paddle ends up in the bread itself ?????
2 Suggested Answers
SOURCE: Kneading Blade Stuck on Kenwood Mixer KM300
Lightly tap out the dough with a piece of wood in the direction you would usualy remove it
Posted on Jan 29, 2007
Bm210 drive belt not available.Can it be replaced with bm250 belt
Your drive
belt has probably either broken or come off. Make sure your machine is
unplugged and turn it on its side and take the bottom panel off. The belt is in
there. If it has snapped or come off you'll need to replace it. I have a few
belts that might fit. Hopefully your
belt will have letter/number code on the smooth side. It will look something like this: STS 80 S3M 561 . If I have it I could sell you the belt. There are several videos
on you tube that show how to put a belt on a bread machine and you could
install it yourself if I have the belt you need.
Sep 27, 2013 | Kenwood Bm250 Bm256 Bm350 Bm366 Bm450...
Can't get knead bar on West Bend automatic bread maker
Was the bar ever installed on your bread maker? Is this a replacement knead bar (paddle)?
Jan 01, 2013 | West Bend Bread Maker Machine Knead Bar...
I have west bend bread maker (new) After 5 perfect loaves, the metal post that the paddle sits on is stuck. It is stuck tight. What happened and how do I get it to move. I turned the pan upside...
we have the same problem with our kenwwod bread machine we was told by kenwood.
you can either buy a new bread pan and bread kneeder or live with it, as in time and use
the new pan and kneeder would do the same agian. the new pan cost around £17.00,
and the bread kneeder around £6.05 from amazon if you do want new parts type in the serch bar at amazon bread maker parts....but if it's not broke don't fix it...........
Feb 22, 2011 | West Bend Kitchen Appliances - Others
I have a Toastmaster bread machine and the paddle is stuck. No matter how hard I try I can't get it out. My machine works perfectly otherwise but I'm afraid my paddle is going to freeze up on me eventually...
Please go to you tube and you will see my video of how to remove a stuck bread machine paddle. Soak your paddle in the pan for about 2 days then do what is in the video. Just go to you tube and type in = how to remove a stuck bread machine paddle or kneading blade
the video lasts about 1 minute 34 seconds....use a shoelace or piece of nylon string narrow enough to slide underneath the paddle....
Dec 12, 2010 | Toastmaster Kitchen Appliances - Others
Re Black & Decker Bread Maker: Most of the time the paddles remains stuck in the pan and the bread sticks to the paddles. As a result, loaves usually have large chunks torn out of them. There are...
Hi, Take the paddle out of the machine at the end of the last kneading cycle and before final rise.. Use pause or take pan out of machine to remove paddle. OR... spray the shaft with a small amount of olive oil. This should allow paddle to come out when bread is done. You will have to fish the paddle out of the bread in this step. Hank
Oct 31, 2010 | Black & Decker B2000 Bread Maker
Kneading paddles dont snap into the spindles .
The situation you speak of is common for ALL bread machines. You want the paddle to come off freely so it won't get stuck on the motor spindle. You can take the paddle out of the machine after the final kneading cycle and before final rise. This will prevent a big hole in the bread. If your machine does not have a pause cycle, take the pan out of the machine to remove the paddle to be safe. Hank
Apr 12, 2010 | Black & Decker B2300 Bread Machine
Panasonic SD-YD205 Bread Maker: Paddle gets stuck then continues.
Take the bread pan out of the machine and run a kneading cycle. If it is noisy with the pan out then you can take the belt off and try a kneading cycle again. If it's quiet, the yep it's the belt. If still noisy its a gear or the motor itself. If everything is quiet with the pan out then it's the pan itself. There is a sealed bearing in the pan that allows the paddle to spin. The seal on the bearing leaks oil and the bearing either freezes or does not let the paddle spin freely. There is no replacement for the sealed bearing ..and a new pan is needed. Good Luck Hank
Dec 10, 2009 | Panasonic SD-YD205 Bread Maker
The knead paddle on my bread machine is stuck, what can I do to remove it. I have tried putting soapy warm water in the bread pan and leaving it sit for 30 minutes, but it did not work. I recieved this...
just go to youtube and type in "how to remove a stuck bread machine paddle or kneading blade" you will see my video of how to remove a severely stuck bread machine paddle.
Apr 20, 2009 | Kitchen Appliances - Others
Blades stuck inside bread
Unfortunately trying to stick the paddles in the pan just tends to leave half the loaf in the bottom with them. The best method i have found is to cut the crust around the outside of the paddles, carefully avoiding the bit where the actual paddle blade is, then you insert a rod into the centre of the paddle and tilt it towards the blade. They normally come free pretty easily. Another method you can use if you are around the machine when it is making bread, is to remove the paddles at the end of the mixing/kneading cycle, just before the baking cycle starts. Most machines have a small pause allowing you to do this - sometimes with a "beep" or screen message to tell you that you can do this. Sorry i couldn't find the exact info for your model, it will vary for different baking programs also. If you check the cycle to determine at which stage it starts actually baking, then you can do this quite safely so long as you are careful of the machine heating up while you are removing the paddles - usually you would have around 20 minutes at least to remove the paddles before baking. Hope this helps :)
Apr 11, 2007 | Black & Decker B2000 Bread Maker
Kenwood Breadmaker Kneading Blade Paddle Bm 210 -s Logo
37 people viewed this question
Top Kenwood Kitchen Appliances - Others Experts
ka4iup
ka4iup
Irene Tulloch
Are you a Kenwood Kitchen Appliances - Other Expert? Answer questions, earn points and help others
