Question about Funai Televison & Video
Turn off closed caption direct tv - Funai Televison & Video
  • 305 Answers
SOURCE: Closed Captions won't work
make sure your dvd player has the capability to display closed captions, as not all of them do, also if it does have the capabilities, it may need a scart connection.
Posted on Jul 02, 2008
SOURCE: Closed Caption won't turn off
cannot turn off closed caption on 27" insignia. the option screen which illustrates the closed caption category, is not highlighted and you cannot manually choose that option from the remote control.
Posted on Jul 29, 2008
SOURCE: can not get closed captioning to turn off
You have to use your SVA remote controll to access the CLOSED CAPTION function to turn it off ....as I just found out myself by the Wiz..... ;)
Posted on Dec 21, 2008
SOURCE: toshiba 62hx94 cant shut off closed caption have comcast cable
The problem was with the Motorfolla Comcast cable box not my T.V. . I turned off my Comcast cable box, pressed menu on the remote to the cable box. This made a 16:9 ratio appear on the cable box's LED read out, and a bluish screen appear on my television. One of the options on my television was to turn on and off closed captioning. Therfore, I turned off closed captioning and the problem was solved.
Posted on Jan 30, 2009
  • 126 Answers
SOURCE: how to turn off closed captioning without orginal remote?
well if it has a menu option go into menu then set up and change cc okay if does not have menu button try to find universal remote w/ menu option and try to change okay
Posted on May 18, 2009
How do I turn off closed captioning in HDMI? I've turned it off in tv mode but it still is on. It's annoying
What's the HDMI source? You need to disable the CC on the cable box or DVD player. These are only two of the possible HDMI sources that will provide the captions directly.
Without knowing the source, I can't tell you how to disable the captions. For many devices, you'll need to enter the settings. (Some cable/IPTV boxes will need a passcode to enter the settings menu.) On my IPTV box, the CC option is tucked into the Hardware Settings under Audio. On some satellite TV boxes, I found that the closed captioning had to be turned on at the primary box and that would enable secondary boxes to also show the captions. (It was an annoying feature for a family with one hard-of-hearing guest. They didn't need closed captions on the primary box. The specifics of their set-up and service meant that the secondary box couldn't display captions directly.)
Please add a comment with the HDMI source for specific information on turning off the captions that you currently see on that source device.
Nov 27, 2017 | Televison & Video
How to remove closed caption when on direct TV
While on the channel you want to remove the captions from:
1.) Push the yellow button on the remote control.
2.) You should see an option to turn on/off the captions.
3.) Select the option "Remove Closed Captions".
Mar 05, 2011 | Televison & Video
I can not turn off the closed captioning on my philips tv , i do not have the original remote to the tv but my cable remote works as a universal remote, please help me the subtitles are driving me crazy !...
I have direct tv, and had the same problem. After an hour on the phone with the worthless tech, I gave up. Finally I figured it out. First of all do you have closed caption problems or is it "subtitles". mine turned out to be direct tv subtitles, not closed caption. I hit the yellow button on the direct tv remote, and presto. Subtitles was set to the on position. changed it to off, and what do you know. fixed.
Jan 02, 2011 | Philips Televison & Video
Above pretty much says it. The "Caption" function under "Option" is greyed out. Can someone tell me how to "ungrey/activate the closed caption option?
If the closed caption is shaded out in the menu, this usually means closed caption is not an option. Closed caption can not be turned on if the TV is on component, RGB, DVI, Or HDMI inputs. The closed caption will need to be turned on by using the set-top box or other device that is connected to TV inputs. or if the tv is connected directly to the cable line or anteanna
Dec 03, 2010 | LG 37LP1D 37 in. LCD Television
I have a panasonic TV. direct tv remote for a . while programming the timer, somehow closed captioning got turned on & i after hours of trying to get it turned off, NO LUCK. it's driving me insane!!...
I could do better with a picture of the remote. Closed captioning is usually a multi-press button, that is each press takes you through each of the four types of closed captioning and then off.
You can enable closed captioning on a DVD Recorder, it looks like the TV, but its only on the picture from the DVD Recorder.
If you have a PVR, you could have closed captioning on on that device.
Try tuning off everything else to make sure it IS the TV.
Turn on the menu and find the closed captioning settings and set to OFF.
Press the close captioning button on the remote (If there is one) and press CC repeatedly until it says OFF.
Try and control close captioning, timer and menus with the ORIGINAL remote and not a programmable one.
Programmable remotes are not always completely compatible.
Mar 20, 2010 | RCA Universal Remote Control
How do you turn on and off the Closed captioning
We have a Sony TV but can't shut off the closed captioning.
How do I do this? Do I use the TV remote or the Direct TV remote.
Thank you.?
Mar 13, 2010 | Orion STV2763 27" TV
Some channels on direct tv have a black rectangle
Either your tv or your directv receiver is on the text mode of the closed captioning function turn closed caption off and this will disappear.
Oct 15, 2009 | LG 42LC2D 42 in. LCD HDTV
How do i enable the closed caption on my samsung tv/direct tv?
Correct solution WITH DIRECT TV is NOT going to SETUP MENU on your Samsung TV and enabling it, this won't work with Direct TV!! I'll walk you through it. Grab your Direct TV remote, hit "Menu", pan down to "Parental, Fav & Setup", next click "System Set-up", next click "Display", now at the top of the screen between "Preferences" and "Clock" is "Captioning", click on it, now the first box reads Captioning TURN IT FROM OFF TO ON! You now have Captioning.
Aug 05, 2009 | Sharp Aquos LC-32G4U 32 in. HD-Ready LCD...
CAN'T GET CLOSED CAPTIONING TO STOP
buy a remote and turn off captions ... or see if the buttons on front can bring it up on menu.
Aug 24, 2008 | Orion1934 19" TV
Insignia TV and Direct TV Remote issue - cannot get the closed captioning turned off
The TV slowly, all by itself, ran closed caption on the major stations.
Unable to turn off through the menu as that option was greyed out.
Now all channels have this unwanted closed caption.
Any similar problems and ideas.
Thanks, Harold
Jul 07, 2008 | Samsung HCN4226W 42" Rear Projection...
Televison & Video Logo
18 people viewed this question
Top Funai Televison & Video Experts
Demonic-2011
Demonic-2011
Jaime Hernandez
Are you a Funai Televison and Video Expert? Answer questions, earn points and help others
