Question about Metra CHTO-02 Chrysler Pacifica 04-Up Radio Interface
Factory amp location 05 town and country - Metra CHTO-02 Chrysler Pacifica 04-Up Radio Interface
2 Suggested Answers
clifford224
  • 1975 Answers
SOURCE: where is pacifica factory amp located
There are a couple of different systems. There are 2 pictures below that should help..............
Posted on Dec 07, 2012
Tip
How To Install Replace Headlight and Bulb Chrysler Town and Country 05-07...
How To Install Replace Headlight and Bulb Chrysler Town and Country 05-07 1AAuto.com
on Apr 04, 2012 | 2007 Chrysler Town & Country LX New Cars
Where is the radiator fan relay located on a 2005 chrysler town and country? not the condenser fan relay.
look behind the drivers side headlite on the crossmember , it looks like a silver module , clean and check the plug , it is corroded 9 out of 10 times , just did this on my 05 t and c , hope this helps
Dec 24, 2010 | 2005 Chrysler Town & Country
LOCATION OF THE ECM ON A 1996 CHRYSLER TOWN AND COUNTRY 3.8
On 1996 Chrysler Truck Town & Country 2WD 3.8L MFI 6cyl the Engine Control Computer is located under hood, driver side, front side of strut tower, mounted on wheelwell.
Hope this help you (remember rated this asnwer).
Aug 08, 2010 | 1996 Chrysler Town & Country
Check engine light comes on. odb2 code P2096 What does it mean
WHAT EXACTLY MEANS THE CODE P2096 AND HOW I SHOULD FIX IT CRYSLER 300 2010
Apr 24, 2010 | 2005 Chrysler Town & Country
Describe your 2002 Chrysler Town &
On the driver side of the intake plenum close to the throotle body is were your pcv valve is located :)
Aug 23, 2009 | 2002 Chrysler Town & Country
Describe your 2005 Chrysler Town &
check the bulbs do not have fractured filaments,and check the headlamp relay.check the sockets for corrosion and if all that checks out ok check the connection on the back of the headlight switch and the daytime running light module
Aug 15, 2009 | 2005 Chrysler Town & Country
Chrysler town and country wiring diagram
2002 Chrysler Town and Country Car Stereo
Car Radio Battery Constant 12v+ Wire: Gray/Red
Car Radio Accessory Switched 12v+ Wire: Black/Pink
Car Radio Ground Wire: Strap or Chassis
Car Radio Illumination Wire: Orange/Tan
Car Stereo Dimmer Wire: N/A
Car Stereo Antenna Trigger Wire: N/A
Car Stereo Amp Trigger Wire: Gray/Green
Car Stereo Amplifier Location: N/A
Car Audio Front Speakers Size: N/A
Car Audio Front Speakers Location: N/A
Left Front Speaker Positive Wire (+): Green
Left Front Speaker Negative Wire (-): Green/Brown
Right Front Speaker Positive Wire (+): Gray
Right Front Speaker Negative Wire (-): Gray/Brown
Car Audio Rear Speakers Size: N/A
Car Audio Rear Speakers Location: N/A
Left Rear Speaker Positive Wire (+): Green/Black
Left Rear Speaker Negative Wire (-): Green/Orange
Right Rear Speaker Positive Wire (+): Gray/Black
Right Rear Speaker Negative Wire (-): Gray/Pink
May 25, 2009 | 2002 Chrysler Town & Country
Does the 1998 TOWN AND COUNTRY have a factory amp
good morning and welcome to fixya
Yes there is a pre-amp that powers your system, it is actually bolted onto the back of the deck ( radio) . If you pull the radio out of the dash and look on the rear of it there will be a shiny silver block with heat sinks in it that is the amp. you can remove and re-install and new one if you need. Just make sure that you re-apply die electric silicone between the mounting surfaces. If you remove the amp from the back then the radio will probably not function at all. They are hard wired into radio itself. You must solder the new terminals back into the board if you change the amp. hope this helps, let me know if you need any other assistence. thank you for using fixya and dont forget to rate
please rate this solution??
Mar 26, 2009 | 1998 Chrysler Town & Country
Metra CHTO-02 Chrysler Pacifica 04-Up Radio Interface Logo
457 people viewed this question
Top Metra Car Audio & Video Experts
xxxxxx xxx
Are you a Metra Car Audio and Video Expert? Answer questions, earn points and help others
