Question about Hoover Max Extract 60 Pressure Pro Carpet Deep Cleaner
How to fix pin on bottom of clean water tank - Hoover Max Extract 60 Pressure Pro Carpet Deep Cleaner
Why doesn't the water pick up on my carpet shampooer???
Hi Julie! If the cleaner is not picking up the dirty water this usually means something is not sealed off properly. Try these steps below to restore suction to your cleaner.
1. Remove the clean water tank. Recline the handle & let the handle lie down on the floor.
2. Remove the dirty water tank. Check that the dirty water tank cap is on the dirty water tank and tightened closed.
3. Clear the filter screen of any hair or debris.
4. Remove the nozzle. Clean the nozzle of any hair or debris.
5. Located on the machine behind the nozzle is a 2nd filter screen. Clean it of any hair or debris.
6. Replace the nozzle.
7. Replace the dirty water tank. Press down on all sides so that it is flush to the cleaner base.
Give it a try! The suction should be restored to your cleaner. If not I have included a video link where you may view these instructions. Hope this helps! Loss of Suction Won pick up Hoover Max Extract 77 FH50230 FH50222...
Nov 02, 2014 | Hoover Max Extract 77 Multi-Surface Pro...
Why is my clean tank emptying immediately to my dirty water tank?
Hi Medori! It sounds like you have an issue with your pump assembly. We recommend taking your unit in to a Hoover authorized service center. For your convenience I have included a link to our service center locator. Hope this helps!
Service Center Locator
Aug 02, 2014 | Hoover Max Extract Pressure Pro 60 FH50220
How do I fix pin at bottom of clean water tank?
Replace the part. This might mean buying a whole new water tank. You can order most parts online. Have your make and model ready. Find a site by google. ie if it's a hoover enter, "hoover parts".
May 12, 2014 | Hoover Max Extract 60 Pressure Pro Carpet...
How can you tell if it is working?
you will know if its working if there is water in the tank at the bottom. this is if it was empty from the start.
Apr 12, 2014 | Ionic Pro Air Purifiers
Hoover max extract 77 wont pick up water
did you make sure the dirty water tank is cleaned out and the cap is on?also did u check the clear kinda hour glass shaped thing in the front where the water sucks up at to make sure there is no blockadge?
Mar 30, 2014 | Hoover Max Extract 77 Multi-Surface Pro...
ON LOW GEAR MOTOR IS WEAK ,ON HIGH GEAR RUNS OK
Hi, Sounds like not enough fuel, in low gear motor turns over a lot faster, using more fuel, high gear it chugs on a trickle of gas. When i used to work in a garage, the final test was a long steep hill that would show flaws in the fuel delivery system, and everything else to, well worth the extra few minutes time. Also, if the big fuel tanker is at your favorite gas station, you might better keep driving bye, or else you can pay 4 bucks a gallon for mud, rust, and water. There is a sock screen on the pick-up tube in your gas tank, the screen is so fine and dense, that gas will flow easily thru it, but water has to be sucked thru. Suppose there is 4 gallons of water in the bottom of your tank, car sitten still the water is half-way covering the pick-up sock, car is running good. Junior stomps on the gas, then hits the brakes for the stop sign down the street. The water sloshes in the tank, covering the pick-up sock several brief moments, forcing the fuel pump to suck water thru the dense screen, causing all kinds of problems. Up here I have a big ice slab in the bottom of my tank that grows each time i get gas until april. Now I hear that ethenol in the fuel is supposed to cure all that. When I was young all the cars had drain cocks on the bottom of the fuel tank to let the water out. Best Wishes
Feb 25, 2013 | AM Auto Parts 2000 to 2002 VW Jetta Mass...
How much water should i use
I run mine day and night while home and clean and re-fill it every morning. I also use one of the room odor eliminators in my Rainmate. Fill the water one inch above the line about an inch off the bottom of the water container.
Aug 20, 2009 | Rainbow Rainmate Air Purifier
Venta Airwasher Venta LW14
When you add water, you should notice bubbles (just a few) on top of the water.  When the water no longer has bubbles, the additive is shot, and you should wash out the tank.  We have dirty air, and it takes about 2 weeks for us.  I spray it with Murphy's Soap to soak a few minutes and wipe it out with a sponge.  Rinse.   Spray the wheel similarly (all over) and spray with a kitchen hose, as hot as possible.  You may have to repeat.  I clean my wheel between tank cleaning, so it doesn't build up.  You should use the additive, because the water has to be slippery to work with the wheel.  Maybe you can find a different "wetting solution,"  that would be cheaper;  Venta gets an arm and a leg for it.  Good Luck.  I like the performance of mine, but it is temperamental.
Dec 29, 2007 | Venta Airwasher Venta LW14 180sq ft...
Hoover Max Extract 60 Pressure Pro Carpet Deep Cleaner Logo
29 people viewed this question
Top Hoover Air Purifiers Experts
Thatvacguy.com
Are you a Hoover Air Purifier Expert? Answer questions, earn points and help others
