Question about Linksys ULTRA RANGEPLUS WIRELESS N GIGABIT ROUTER
Can connect to internet with linksys WRT310N
I get everything running on the wireless router, things hook up correctly, and the computers appear to connect through the router (I even get an internal IP address confirmed), but the installation process says the internet cannot be verified. On the mac, it disables the airport and i have no internet, on the PC, I have no internet.
  • John Erwin Tejano May 11, 2010
    please make it more detailed.
    Genius:
  • 1,269 Answers
If you are on Cable Internet, you need to do MAC Cloning. Open the router's Setup Page through http://192.168.1.1 then look for Mac Address Clone sub-tab under the the SETUP tab. Enable it and click on Clone My PC's MAC then click on Save Settings. You need to power cycle the device now. Unplug the power to the router and the modem. Wait for 30 seconds. Power on the modem first and wait for the lights to go solid, then power on the router. You should be good to go.
Posted on Jun 28, 2009
Driver Linksys WRT310N Wireless Router
driver download link : has all the instructions you need. Should fix most problems.
1 direct link :
http://www.userdrivers.com/LAN-Network-Adapter/Linksys-Router-Upgrade-Firmware-1-255/
2 scanner :
http://www.userdrivers.com/LAN-Network-Adapter/Linksys-WRT310N-Wireless-N-Gigabit-Router-Firmware-Update-1-0-07/
May 10, 2011 | Computers & Internet
I just had an NetGear Wireless "N-150 Router" (WNR1000) sent to Me from Comcast of which all would appear to be hooked-up and running well; to the best of My knowledge. But yet My girlfriends...
If all your gear is working fine then the issue lies with the girlfriend's laptop wi fi chip. I had the same issue and had to return the laptop for another.
Apr 03, 2017 | NetGear WNR1000 RangeMax 150 Wireless...
Disconnecting wireless problems can be caused by any number of things. Please click on this link and follow my instructions to determine the fault and fix :-
http://www.fixya.com/support/r3559120-wireless_router_disconnecting
Jan 15, 2011 | NetGear Computers & Internet
I have 2 desk top computers hooked up to one internet source and they are hooked up to a box which my old linksys router was hooked to. I now have a lynksys wireless router G. i unplugged the internet...
Are you trying to set up the router.
You can do it manually without the CD.
Make sure that your computer is able to go online
through the modem.
If your computer is able to go online through the
modem
Then you need to connect the computer to the
router and the modem to the router.
open the set up page of the router and change the
settings of the router according to the ISP.
Click Here for step by step by instructions
Feb 11, 2010 | Linksys WRT54G2 Wireless Router
We have windows 7 ultimate on a hp pavilion du 7 laptop, coupled to a linksys wr310n router.It was working fine until our c drive crashed & had to replace , now we can't get the router to work , driver...
For the WRT310n, back to the User Guide (download from Linksys), perform a reset and start over following setup instructions (make sure the router is hardwired to the laptop). Set up a new home network on the laptop using Control Panel. Make sure the adapter settings are correct and good to go. Then see if you can connect to the router with your browser to set it up. After setup, you should be able to connect to the router wirelessly from the laptop, but you have to make sure the wireless transmitter inside the laptop is turned on first (see the laptop user manual).
Jul 05, 2017 | Linksys ULTRA RANGEPLUS WIRELESS N GIGABIT...
3 failed attempts to connect HP DV6t laptop
First as a test, turn off the wireless security, and see if the laptop can connect.
If it can connect with security turned off, then it is likely that you are making some type of mistake with the password. (Such as caps lock being on, or having a keyboard error.)
Good Luck!
Jan 03, 2010 | Linksys ULTRA RANGEPLUS WIRELESS N GIGABIT...
Im hooking everything up right as im going through the 4 step intallation disk and it says Your new router does not appear to be connected properly.
make sure the cable going from your laptop/computer is connected - you NEED to be connected! or if you are going wireless and you know that your laptop wireless adapter is working and you can see the default wireless network - which is "linksys" (without the quotes) you should be able to connect to it and configure it without the CD..
Dec 30, 2009 | Linksys Wireless-G WRT54G Router
Using the SMC100 Barricade as a Wireless Access Point
use the wrt310n router as the router for the internet (where dsl modem is connected) then just connect the ethernet port (not wan port or internet port) of the SMC to the ethernet port of wrt310n
Oct 31, 2009 | SMC Barricade SMC7404WBRA (SMC7404WBRA EU)...
We are on Starband Satellite internet. Have windows programs , both vista and xp. We have the linksys G wireless internet system. How do we install it ?? So far, when we put it in, nothing works. No...
Yes you can but it is not as easy as using a router with a cable or dsl connection.
The 360 modem requires the Mission Control software in order to run properly so you can't just hook it straight to a router.
What you need to do is use an old computer to sit in the corner and act as a router(kind of) and then connect it to a real router.
When your finished you won't even need a monitor for it. You will need either two network cards in it or 1 network card and a usb port to hook it up to the 360 modem. Make sure network cards are also working correctly. Install the starband mission control software and make sure it is working correctly.
In Winxp go to network connections and right click on the one hooked to the starband modem and click properties. Now click on the advanced tab and check "Allow other network users to connect through this computers Internet connection.
You can plug the other network cable straight into a switch and this computer will hand out ip addresses through ICS(Internet connection sharing) built into winxp.
You can also get a wireless router and change the ip address of it to match the range that ics is handing out and disable the dhcp server so that you don't have two things handing out ip addresses.
If you use the web accelerator you will have to put it in the browser of each computer that you will be using (in the browser under proxy). It will be something like 192.168.0.1:9877.
Also make sure your running a firewall on your little router-computer. If the computer is running winxp professional you can take the monitor off and use remote desktop connection to check on things or to control it. Or search the Internet for VNC.
from____cajun101...yahoo
hope this helps you get more confused :)
Oct 24, 2009 | Linksys Wireless-G Broadband Router
Lost the internet connection on my laptop that worked before (Linksys wrt310n)
first check if you have internet with the modem if yes then you'll need to reconfigure the router. Contact router's manufacturer to assist you how to set it up.
Sep 14, 2009 | Linksys WRT300N Wireless Router
Linksys ULTRA RANGEPLUS WIRELESS N GIGABIT ROUTER Logo
723 people viewed this question
Top Linksys Computers & Internet Experts
Prashant M
Prashant M
Michael Galve
Michael Galve
Are you a Linksys Computer and Internet Expert? Answer questions, earn points and help others
