Question about Canon imageRUNNER 1023iF Black and White Copier
Canon mx459 fax confirmation - Canon imageRUNNER 1023iF Black and White Copier
3 Suggested Answers
  • 121 Answers
SOURCE: fax confirmation for canon imageclass d780
no...sorry.
Posted on Oct 27, 2007
old marine
  • 2152 Answers
SOURCE: Fax Confirmation on a Canon MP830
To print a TX (transmission) report after each fax sent:
1. Press the Copy button if that light is not already lit
2. Press the Menu button
3. Press the Right arrow to get to "Maintenance / settings"
4. Press the OK button
5. Press the Right arrow to get to "Device settings"
6. Press the OK button
7. (You should be at FAX SETTINGS) Press the OK button again
8. Press the down arrow to get to "TX settings"
9. Press the OK button
10. Press the down arrow to get to "TX report"
11. Press the OK button
11. Press the down arrow to get to "Print for each TX"
12. Press the OK button
(You can have the machine print the first page of the fax with the report if desired)
13. Press Stop / Reset
Posted on Apr 18, 2008
Trying to use adf but tells me to put original on platen
You need to check the settings for scanning. The machine wants to use the platen because that is what it has been set up to do, or you are using a sheet size the machine doesn't know about. Again go through the scanner settings both on the machine and any attached computers.
Sep 04, 2016 | Canon Pixma Mx459 All-in-one Inkjet...
No matter whatido cant send fax keeps saying off the hook
Try unplugging other phones (from the phone jacks) that are on the same line. Also, remove any phone that is plugged in to the fax machine, if there is one attached. If that doesn't work, swap the phone cable on your all-in-one printer/fax with a different one. Lastly, try a different phone jack all together.
I can tell you I had the same problem with my fax/printer, and it ended up being a bad phone cable. It, the cable, worked fine with a handset, but not with the fax. Good luck.
Apr 02, 2016 | Canon Pixma Mx459 All-in-one Inkjet...
Printer keeps printing same thing over and over and will not quit. I pressed for 1 copy and it keeps shooting out the same thing. It won't let me fax it just prints. Help!
go to control panel--to add a printer--click on the printer and you will see whats printing
highlight each line in the print task que one at a time and cancel print
the command is probably in a loop and it will print the previous print instruction over until the task is deleted
Feb 06, 2016 | Canon Wireless Office All-In-One Printer...
My fax machine is saying off hook but the printer is working
Hello, my name is Steve. It sounds like your Fax machine has detected that the phone lie to your machine is still "opened".
The Fax board that detects the signal for the incoming fax tone is either not connected or it has an open circuit.
If you have another cable that goes to the Fax try this as a replacement. If this corrects the problem, then the fault is the cable from the connection of the wall to the fax machine.
If this does not, then if you have another source, connect it...like a telephone. If you hear a dial-tone then it is not the line-in.
The part that failed is the Fax-card or the Logic board...
I hope this helps, best regards,steve
Aug 18, 2015 | Canon Pixma Mx459 All-in-one Inkjet...
Cannon mx459 will not feed copies at ALL!!!!!. hAVE TO PLACE ALL COPIES ONE AT A TIME TO COPY. DO NOT HAVE TIME FOR THIS
Your ADF feed rollers are worn or dirty. Clean or Replace the rollers and it should pick up pages again.
Oct 13, 2014 | Canon Pixma Mx459 All-in-one Inkjet...
How to fax using canon mx459 all in one
Start by connecting it to your phone. Until you do that, it's not a fax.
Now put the document you want to fax in the document feed tray.
Push in buttons to dial phone, and away it goes. It's pretty easy.
Sep 11, 2014 | Canon Wireless Office All-In-One Printer...
How to get a fax confirmation on a canon faxphone L190
There should be a button on the front of the fax 'Reports'. Push that. Then go to 'Report settings'. Select that option. For confirmation reports that a fax was sent 'TX Result Report'. Turn this 'On'. You should be set. We just figured this out on our faxphone.
Nov 29, 2012 | Canon Office Equipment & Supplies
How do I get a confirmation page of a sent fax on Canon SuperG3?
Tx (confirmation) Report needs to be enabled before sending the fax. Super G3 is an industry standard, not a model number. What model of Canon facsimile do you have? I have most User Guides downloaded...so I should be able to provide directions on enabling Tx Report. Let me know.
Aug 17, 2009 | Canon Office Equipment & Supplies
Canon imageRUNNER 1023iF Black and White Copier Logo
29 people viewed this question
old marine
old marine
