Question about NorStar Meridian M7310 Phone
How do I get rid of static interference in the line
Can the digital recording be cleaned; I get lots of static on a recorded message?
There's nothing in your recorder to clean, but. . Static in the message likely indicates a problem with the phone line itself, or at least the connection from the phone line to the recorder. You can clean that.
May 26, 2015 | Lands Phones
HOW DO I CHANGE THE BROADCAST CHANNEL, GETTING LOTS OF STATIC AND INTERFERANCE
The broadcast channel can't be changed according to the units instructions some other electronic device is causing the interference you may have to move the base unit. A PDF file of instructions are here
http://www.google.com/url?sa=t&rct=j&q=&esrc=s&source=web&cd=2&ved=0CCgQFjAB&url=http%3A%2F%2Fservice.us.panasonic.com%2FOPERMANPDF%2FKXTG1032.pdf&ei=Jl_aVNSkGobAggTGlYHoBg&usg=AFQjCNEKuKWxZUBDTtUXNDQOW8Mn92B2dw&sig2=oBfK0fI1HOBEHWvabQGLpA
Jan 26, 2015 | Panasonic KX-TG1033S Cordless Phone
Vizio vw42lfhdtv10a static lines
Sounds like AC line interference. Use an external line filter.
Jun 05, 2013 | Televison & Video
I get static so bad that I can't squelch it down enough to get rid of the noise. Traveling out on the highway it usually works ok. But when I enter a town the static gets badusually around power lines. How...
You could install a filter in the line between the antenna and the transciever. I reccommend a high-pass or band-pass filter set for the 27 MHz band to remove any interference at different frequencies. Also, some older TVs can cause interference to CB radios if they are close. If this doesn't work, the radio may be poorly sheilded or your area may have implemented the broadband power line initiative (BPL). This produces a strong buzz of noise that obliterates all weak to moderate radio signals between 2 and 80 MHz (CB being at 27 MHz).
May 21, 2010 | Cobra 19 DX IV CB Radio
I have a Uniden set of of phones - 5.8 GHZ. Both are making a loud static sound when you turn it on. We can hardly hear. We unplugged both sets for a while, but this did not get rid of the static sound.
• Keep the handset away from microwave ovens, computers, remote control toys, wireless microphones, alarm systems, intercoms, room monitors,fluorescent lights, and electrical appliances.
• Move to another location or turn of f the source of interference.
Dec 31, 2009 | Uniden 5.8GHz Cordless Phone
How do i get rid of the static in my model CKS2235B radio? The original literature which i no longer have indicated that the power cord is an antena. There is no one position that works with that approach....
You will have to place the radio away from any noise sources. Like television,lamps, fans, other stereo equipment,refrigerators. These all cause noise on the a/c line current. This is the source of noise. You can try using a/c line filter/surge protectors to stop the line noise interference. Plug the radio into this and place it near a window so it can easily find the signal source.You can also look on line for more information on how to limit noise interference on a/c line connections. I hope this information help you with your problem.
Apr 17, 2009 | Emerson Smartset Clock Radio
Interference with wireless phones
Get yourself a new wireless phone. Newer technologies like DECT 6.0 don't interfere with wireless applications unlike older 5.8 and even older 2.9 gigahertz phones.
Jan 12, 2009 | GE Security Simon 3 Wireless Home Security...
GE Dect 6.0 Cordless - Loud Static
question is are you running a pc and router/ modem on the same land line
if so you will need the line filters to the phone base
the computer data is transferred by the same land line and there is every possibility that the different frequencies is what is causing the static
reference from a uniden trouble shooter ( will be common as the phones use the same medium)
lots of noise or static on the line === possible solutions --check for interference from appliances ( microwave , tv etc ) or wireless devices ( baby monitors wifi equipment etc)
move the handset base away from the source
if you have any device that uses the phone line , add a DSL or telephone line filter to the system
it is possible from the times you state that the interference could be coming form a neighbour or further down the line so the filter may be the option
available from phone shops or places like JAYCAR
Jul 11, 2017 | Uniden Cordless Phone
Static in the line
Usually caused by bad connections along the line or poor batteries on radio phns.Possible interferance from other equp
Dec 02, 2007 | Lands Phones
NorStar Meridian M7310 Phone Logo
Top NorStar Lands Phones Experts
george  peters
george peters
Are you a NorStar Lands Phone Expert? Answer questions, earn points and help others
