Question about HP LaserJet P3005 Printer
Hp p3005 print cartridge stuck right side - HP LaserJet P3005 Printer
    Sergeant:
  • 284 Answers
Toner Cartridge Drive need to be change
Posted on Nov 26, 2014
SOURCE: Hp Office jet print cartridge error
I have a 7410 that is 16 months old with the same problem. It is not a broken spring. Spent over an hour on chat attempting to trouble shoot. HPs only solution was to sell me an "upgrade" for over $300 (which is more than I paid for this piece of junk.)
I expect "top of the line" products to last quite a bit longer than that. The worst thing is that with this error popping up, it is absolutely useless for anything else like scanning or outbound fax.
It should be called an "all or nothing" printer.
Posted on Feb 29, 2008
SOURCE: hp deskjet 3820
the ink cartridges get stuck on the right side. The is a square white looks as if a resting area. I don't know how to fix it.
Posted on Aug 19, 2008
  • 55 Answers
SOURCE: Hp 2820 prints only on right side of page
Yes, you will need to replace the drum unit as well. be sure to shop around so you can get the best price because some people mark up the price for that part. You can check the status of your supplies from the printer itself by pushing the "menu" button the printer and scrolling through until you see something about supplies status then press the check mark button.
Posted on Jul 31, 2009
  • 10 Answers
SOURCE: HP LaserJet P3005 printer prints wrinkled paper
2 reasons:
1. Was there a paper jam prior to this problem? It could be that the paper was pulled out and a small bit of it is stuck on the pins that guide the paper from the heat roller. If no torn jammed paper prior to this issue, then check out 2.
2. the heater/roller is damaged and needs to be replaced. I would suggest you take it to your nearest HP dealer to properly diagnose this for you.This would save you unnecessary cost in trying to pull it apart and causing more damage to it.
Good Luck,
Posted on Jan 29, 2010
  • 202 Answers
SOURCE: HP Laser Jet 4700n-Light printing on right side of
Try shacking the toner or tap it on it side. Toner might not be even at cartridge. Then you can do a full calibration( You can find it at print quality), do this twice. First full calibration checks for errors, second calibration fix it. Also check if fuser isn't dirty at right side.
Posted on Apr 01, 2010
Print white paper
check the toner cartridge connectors (high voltage ) take care you must disconnect the power cord first >
(inside the print area at the left down side)
Dec 14, 2012 | HP LaserJet P3005 Printer
My Hp laserjet p3005 drops offline and cant print, any help
Go to system settings and select the 'Printer' option.
Right-click on the printer and enable the 'Use Printer Online' function.
Cancel all the printing jobs till that moment and redo the process.
Sometimes the 'Printer Offline' message occurs due to a 'Job Stuck' issue.
Check all network connections and functions.
Be sure the network interfaces work properly.
Turn the printer off and on to see whether the device is working properly.
Sep 06, 2011 | HP LaserJet P3005 Printer
Print both sides using hp laserjet P3005
I assume that printer is perfectly installed and
for both side printing,
go to
contro panner ->printer and faxes->right click on printer->select properties->at bottom click on preferences -> choose "duplex printing".
if you cannot duplex printing here need to install duplex printing.
Mar 04, 2011 | HP LaserJet P3005 Printer
HP Laserjet P3005, everytime we print we get black speckles in 7 even lines across the paper. Why is this?
Usually caused by the toner cartridge, try replacing the cartridge. Especially if it is not a genuine HP cartridge they have a higher defect rate.
Jan 17, 2011 | HP LaserJet P3005n Printer
My HP P3005 prints blank pages
Please check the cartridges it see if the toner is finish,clean the print head because it may be block up or you can replace it if it is damage.
Aug 15, 2010 | HP LaserJet P3005 Printer
HP LJ p3005 dn printer will not recogonize hp print cartridge.
you may use a non genuine toner cartridge, check another working cartridge
Mar 30, 2010 | HP LaserJet P3005dn Printer
HP P3005 - skid marks along paper's edge
Print 3 pages. Use the manual feed tray. As they print, open the cover, remove the toner and look down at the paper in the printer. Do you see marks along the edge? If no...replace the fuser. If yes...it could be the transfer roller.
Jan 07, 2010 | HP P3005d Monochrome LaserJet Printer
HP p3005 printer cartridge error but cartridge is ok...how to solw this error..
The cartridge is not ok. Just because you replaced it doesnt mean its a god cartridge. You installed a bad cartridge so replace it and get your money back for the old one. P3005 printers are very intelligent!
Jul 15, 2009 | HP LaserJet P3005 Printer
HP LaserJet P3005 Printer Logo
55 people viewed this question
Seeker5211
Seeker5211
