Question about Asko Dishwashers
I have an ASKO DW 20.1 dishwasher and the pump wont stop running
Timon90
  • 126 Answers
SOURCE: Asko D3350 code F7
Service manual says:
LED L1+L2/Fault code F7, Pumping out fault
(machines with pressure sensor)
Water not evacuated after 120 seconds’ pumping
out. Programme interrupted.
Check: Drain pump, hoses, installation of drain
hose, control unit and wiring.
Posted on Jan 24, 2008
VOTIT
  • 2071 Answers
Just click below;
WHAT IS WRONG WITH YOUR DISHWASHER?
For a detailed Dishwasher illustration, click below.
Built in
Warning! To avoid personal injury or even death, always disconnect your appliance from its power source--that is, unplug it or break the connection at the circuit breaker or fuse box--before you do any troubleshooting or repair work on your appliance. Also, because some components may have sharp edges, use caution while working on your appliance.
There's an error code on the digital display
It doesn't work at all
It cleans poorly
There's no water entering the machine
The water doesn't drain from the machine
It's noisy
It leaks
The dry cycle has problems
The door has problems
The cycle doesn't complete
I see an error code
The detergent cup doesn't open
The cycle times are too long
Hope this may help;
Regards,
VOTIT
Posted on Sep 14, 2008
  • 42 Answers
SOURCE: Overfill Protection tripped on ASKO D3112 dishwasher
remove the front toe kick. you should have 6 torx screws. four in the top 2 in the front. your float switch will be in the front center .the float is a piece of styrofoam - the float many times is what you find jammed up making the unit believe it has water in the base
Posted on Dec 21, 2008
  • 14 Answers
SOURCE: Water in drain pump for ASKO D5122XXL dishwasher
Yes, Asko dishwashers can leave a small amount of water in the sump after a cycle completes. At the beginning of most cycles the sump is pumped and new water added.
Posted on Jun 19, 2009
SOURCE: Asko 3120 dishwasher drain pump
this is because ther is a leak from the main tank. Water goes under the main tank, where all electric motors, pipes an pump are. There is sensor in that area that trigger the drain pump. Up to 4 or 5 liters can accumulate in that area.
Only solution is to remove that water by tilting the washer on what ever corner.
Posted on Dec 05, 2009
Asko d3250 drain pump wont stop running
Most likely is activated overflow system.
This means water leaks under the dishwasher and is activated drain pump to prevent flooding. The simplest is to lean on either side the dishwasher so if there is water on the floor, that's it. Now you need to identify and repair the leaks. You can not be excluded that a defective triac by driving the drain pump placed on circuit board. It very rarely happens and some brands signals a failure by display or LED diodes .
Dado
Mar 10, 2015 | Asko Dishwashers
Asko 1755 dishwasher. The pump keeps running We need to replace a new PCB P/N: DW955 8057931-05 Is it available?
My Asko Model 1585, Type DW 95.4 Circulation pump just died. I have the following parts available (All in working condition):
* 8057931-05 Control Board (this is the replacement part AFTER the recall)
* 8057083 Drain Pump
* 8057085 Fan circulation module (the one in the dishwasher door)
* 8057077 Heating Element
Photos and motor/coil/element resistance values available on request. I have no prices listed as I am still trying to determine their value. I am an old Boy Scout & NOT out to screw anybody.
Feb 20, 2011 | Dishwashers
Asko 1805 DW Circulation pump NF. What is the most common cause / fix. Is it the motor, impeller, capassitor or control board?
The pump motor can easly be tested by 1) Physically looking at the pump motor in the pump out mode. The motor must spin freely. The motor has 2 push on electrical connections that must have AC voltage across them in pump out mode. If voltage is present and motor not spinning indicates the motor windings are open circuit. No voltage at the 2 terminals indicate that the electrical / electronic switch circuit is faulty. The impeller could be jammed from debris or pipe blocked.
Jan 25, 2010 | Asko 24 in. 1805 Built-in Dishwasher
Asko model 1485 Type, DW 95.3. No water supply. Inlet valve needs replacement? Where can I find a parts repair manual for this unit?
I have an ASKO 1485. It overfilled and know it will not stop flashing the lights on the panel. I have manually removed the water
Sep 08, 2009 | Dishwashers
New Asko Dishwasher. Both the appliance store
Make certain the door switch is making contact and the switch is good. Open the front panel and trace all the wires,especially where they go from the door to the underside of the DW. Look for a broken or pinched wire.
Jul 06, 2009 | Asko 24 in. D3250 Built-in Dishwasher
The drain pump motor on my ASKO model 1375 dishwasher wont stop running
Had a similar scenario on my Asko 1325. I simply removed the unit in preparation to chuck it, but once outside decided to check the inside of the pump/impeller and the electrical connections. Found plastic debris in the pump, and wiggled every electrical connector of its attachment and then re-attached it. Tried the Asko-fiasko outside and it worked.
BTW be prepared for an electrical failure/ meltdown as per the following two photos:e4b01cd.jpg47ce737.jpg
Jun 22, 2009 | Asko 1375 Dishwasher
Lights blinking
I have a 3122 and had a similar problem, Lights flashing, humming noise and me standing there scratching my head! I emptied all the water out of the filter basket and then tilted the machine backwards (only needed about 20 degrees) and then the rest of the water drained all over the floor... about 1/2 a liter. Now its all good! and the missus is nun the wiser!
Jan 25, 2009 | Asko 24 in. D3112 Free-Standing Dishwasher
ASKO 1605
Hi Guys
My dishwasher this morning has desided to not work correctly.
Its a ASKO 1302 about 20 years old. It has been a very good machine.
Over the last couple of weeks during the washing cycle, the dishwasher has been making a loader noise than usual.
1. Today, the dishwasher timer, travels all the way through its cycle, but very little washing take place.
2. Soap power is still there, plates not clean!!!!
3. Water is hot
4. At the end of the cycle, there is no water in the dishwasher.
5. I'm thinking the problem could be the pump needs replacing.
What do you think?
Greg
Sep 05, 2008 | Asko 1375 Dishwasher
Asko 1805 Frozen
Sounds like the controlunit is bad.
Jan 01, 2008 | Asko 24 in. 1805 Built-in Dishwasher
ASKO Overfill protection tripped
Remove the backpanel of the machine, and look if there is water at the bottom of the machine. If so, use a towel or so to dry up the water. This should solve the prob.
Dec 31, 2007 | Asko 24 in. D3120 Dishwasher
Dishwashers Logo
66 people viewed this question
Top Asko Dishwashers Experts
John Tripp
John Tripp
Are you an Asko Dishwasher Expert? Answer questions, earn points and help others
