Question about Dishwashers
OKO Favorit 40300 repair manual
Need a repair manual to sort out overflow problem. Every time the water is pumped into the machine it pumps it all out again as the water tray fills up
SOURCE: The drain pump on the AEG oko favorit 6050 keeps
Empty all the water from the salt resevoir, (I used a turkey baster), then rock the machine backwards and forwards a few times and empty the last few drops from the resevoir again.
Posted on Jan 18, 2010
joe_lishman
  • 192 Answers
SOURCE: AEG OKO FAVORIT 6050 trips earth leakge
This is typical of a water leak onto electrical connection OR the electrical element has shorted internaly . Check this with a Ohm meter and itshould show the problem
Posted on Jan 19, 2010
joe_lishman
  • 192 Answers
SOURCE: drain pump keeps running AEG oko favorit
This seems like the anti flood system (polystireen float / micro switch) at the base of the washer is triggered,\. This puts the washer in pump out mode and stops inlet of water via the inlet solinoid. Dry the water on the base and then check for any water leaks. (pipe leak
Posted on Jan 20, 2010
SOURCE: I have a AEG OKO
spend the car much energy?
Posted on Sep 21, 2010
  • 539 Answers
SOURCE: Machine is blocked, water will not go out. OKO favorit 6060
Try www.manualowl.com Best of luck. Jimmy
Posted on Apr 11, 2012
AEG OKO FAVORIT 40300 When switching dishwasher on no water is flowing into the the dishwasher?
It should first be checked for correct water inlet hose with safety valve. After connecting the double-walled water inlet hose, the safety valve is next to the tap. Therefore the water inlet hose is only under pressure while the water is running. If the water inlet hose starts to leak during this operation, the safety valve cuts off the running water and the draining pump in the dishwasher is switched on. If the inlet hose with safety valve working correctly than could be some of following faulties.
  • The door of the dishwasher is not closed properly.
  • Mains plug is not plugged in.
  • House fuse in defective.
  • In the case of dishwasher models with start delay
    timer: A start delay is selected.
If you look at the lower electrical diagram then you can see that all electrical components are located in a circuit inlet valve which can be also faulty.
  • ON/OFF Switch
  • Door switch
  • Program controller (Timer)
  • Pressure switch
  • Inlet valve
  • Float switch
  • Wiring between all this components
Dado
Sep 15, 2015 | AEG Dishwashers
My oko favorit 6081sensorlogic stopped working half way through a cycle and displayed the code c21 what does this mean
OKO codes that start with 20 lead to the siphon being clogged
(no water coming in)
Sep 25, 2014 | Washing Machines
Aeg oko favorit 50500w water not coming in through spray arms
There are several reasons if spray arms doesn't spray water. First you need to check efficiency of circulation pump. If it works, then should check the turbine of circulation pump. Sometimes turbine blades can be broken and the pump does not produce enough pressure to turn the spray arms. Be sure to check that the filter is not clogged which can also causes same problem. Finally, check that the nozzles of spray arms are not clogged.
So, could be:
- motor circulation pump
- circulation pump
- filter
- spray arms
- electronic or power board
Dado
Jul 12, 2014 | AEG Dishwashers
My 12 year old AEG OKO LAVAMAT is making a grinding sound when it fills. It's fine at all other times. I've tried cleaning out the filter, and running it empty.
This is usually caused by the recycling pump running empty whilst the washing is still soaking up the initial fill water. as the water begins to soak the clothes it then starts to pass through the drum into the pump and the whole thing quietens down. running empty will not work. to test this theory try opening the drawer very slightly and filling it manually with a hose before starting the machine, (ONLY TO THE NORMAL LEVEL) and see if the noise is still as bad.
Feb 09, 2013 | AEG Washing Machines
Aeg oko favorit 40300 service manual
Please help
Jan 11, 2012 | AEG Dishwashers
I have water in the bottom of my AEG OKO-Favorit
did you take the air gap by the faucet apart they plug alot the fist thing i usually check disconnect drain hose lay it in a pan does water drain, may need new pump
Dec 27, 2009 | Dishwashers
Dec 20, 2009 | AEG 24 in. Favorit 60830 Free-standing...
The drain pump on the AEG oko favorit 6050 keeps running even when the on/off switch is off or the door is open.
Oct 17, 2009 | AEG Favorit 50500 Built-in Dishwasher
Aeg dischwaher model oko favorite
Nov 15, 2008 | AEG 18 in. Favorit 64800 Free-standing...
Drain pump keeps running AEG oko favorit
Aug 29, 2008 | AEG Favorit 50500 Built-in Dishwasher
Dishwashers Logo
16 people viewed this question
Top Dishwashers Experts
Owen Barnes
