Question about OKI Pacemark 3410 Matrix Printer
Problem with OkiData ML 320 Turbo
I have a OkiData ML 320 Turbo, I am printing a report for payments and the first couple of pages come out fine, then it starts to space the lines out incorrectly and then it doesn't finish the entire report. I have tried different drivers from OkiData and just Generic print drivers. I printed from my software to another OkiData ML 320 Turbo and it worked fine. Any one who can help I would be greatly appreciative. Thanks, Sean
  • 148 Answers
SOURCE: Oki 320 Turbo -- Unclear characters in output
If it is not the ribbon, you may have to replace the print head.
Genuine Okidata Print Head
Mfr Part #:
50063802
Hope that helps...
Posted on Jun 21, 2008
  • 138 Answers
SOURCE: OKI Data Microline 320 Turbo
Suonds as if your spacing motor is going out. The part number is 56513701. Here's a link to a free complete Okidata Service Manual for your 320Turbo. The manual will walk you through the testing process to verify the problem prior to ordering the part.
http://www.feedroller.com/Store/Service%20Manual/SER320T.PDF
If this helped you, please hit me a fixya!. I'm just a tech trying to help people in my spare time.
Posted on Aug 30, 2008
SOURCE: microline 391 okidata continous feed leaves a page of space
We have downloaded the manual and will see if we can figure it out.
Thanks
Posted on Apr 07, 2009
Sphynkter
  • 221 Answers
SOURCE: Oki ML 320 Turbo/D IBM - JetDirect 170x Print Server prolems
I just had this exact same problem - same printer, same Jetdirect model. Mine turned out to be the parallel printer mode setting inside the JetDirect. I connected to the configuraiton page by IP, then changed the Parallel mode from "AUTO" to "Centronics", tested it, and it worked fine after that. Hope it helps.
Posted on May 11, 2009
  • 14 Answers
SOURCE: My Okidata Microline 320 at my office has started
this sounds like a print head issue. a replacement printhead is the way to go.
Posted on Nov 09, 2009
Page length too short
Put it on 12" and try what happens. It should work.
Jul 10, 2010 | OKI MICROLINE 320 Turbo Matrix Printer
I want oki ml 320 turbo driver.. eny body can help me on that..?? pls,,,,,
the oki data ml 320 driver should be bundle with the operating system. If not you can download it from okidata website.
http://okidata.com/mkt/html/nf/Drivers.html
Try it and let me know if this helps.
Thank you.
Mar 04, 2009 | OKI MICROLINE 320 Turbo Matrix Printer
Okidata 320 turbo microline prints jibberish
sounds like a job was sent to the printer with the wrong driver. There is no way to purge it just load some paper and let it run until it stops. They make sure your emulation matches the driver youa are using. Example Epson 9pin compatiable or OKI ML320 Turbo-IBM drive you want the emulation set to Epson FX. Or if using the OKI ML320 Drive you want the emulation set to ML.
Jan 15, 2009 | OKI MICROLINE 320 Turbo Matrix Printer
Aug 29, 2008 | OKI MICROLINE 320 Turbo Matrix Printer
Mfr Part #:
50063802
Hope that helps...
Jun 21, 2008 | OKI MICROLINE 320 Turbo Matrix Printer
Printing jibberish
Hello babytenbucks,
I can help you setup your Okidata 320 printer.
Connect the printer to the printer port coming off the motherboard. Usually it's colored pink. Also known as LPT1.
If your operating system is Win XP do this. Open Control panel, open Printer & Faxes. Click File, Add new printer.
Uncheck, automatically detect & install my plug & play printer.
Click Next. Allow it to use LPT1. Click next.
There are two windows here. On the left is Manufacture on the right is Printers. Scroll through Manufacture till you find
Okidata. Under Printer, scroll down till you see Okidata ML 320 Turbo/D (IBM), click next. You can give it a new name or leave it as is. Make the 320 the default printer. You can let it print a test page. Either way re-start the system. Try another test page.
Click the link below for a .pdf file which is the manual for your
Okidata 320 Turbo.
http://www.precision.com/manuals/Okidata_ML320_321_Manual.pdf
If you do not have Adobe's pdf reader download it from the next link.
http://adobe-reader.download-express.org/now/
babytenbucks, if your still have any trouble please just post back & we'll get it solved.
Good day!
& please vote...
Feb 25, 2008 | OKI MICROLINE 320 Turbo Matrix Printer
Check the receive buffer on the Oki. I usually set it to the highest (88k or 128k). You might also check the print head gap if you are printing multi part invoices. If the print head is too close it may overheat and stop printing. If you have a different printer, swap it out and see if it prints correctly. It may be a problem with the JetDirect 170x, not the printer.
Nov 08, 2007 | OKI MICROLINE 320 Turbo Matrix Printer
OKI Pacemark 3410 Matrix Printer Logo
Top OKI Office Equipment & Supplies Experts
Jimbras
Level 1 Expert
Don  Farrell
Don Farrell
mukhtar21 shaikh
mukhtar21 shaikh
Are you an OKI Office Equipment and Supply Expert? Answer questions, earn points and help others
