Question about UPS Battery Backup Systems
Wingman game controler extreme 3d
My controller wont work with windows vista
  • 105 Answers
Re: wingman game controler extreme 3d
We Call It "Bosta"( Pice of Sack), In INDIA. Use XP, This Is The Best OS Till Date, Unless "Bosta" I mean Vista Comes up with Service Pack One Or Two to over come It's Bugs!!!
Posted on Nov 08, 2007
0 characters
3 Points
The Windows Vista/7 driver may work. Others have managed to get the 9 to work but Dell doesn't have a Win8 driver. First are you installing the printer for the first time to the computer or did you upgrade the OS and are reinstalling the driver? If you have done an upgrade or attempted to install once before, you will need to delete any jobs in the printer queue.(Win+X > Control Panel > Hardware and Sound > View Printers and Devices. Select your printer and then see what's printing. Cancel all jobs.) If you can't delete the jobs, press the Windows key and type in Command Prompt. Right click on the appropriate program and at the bottom of the screen, select Run As Administrator. Type in "net stop spooler" followed by enter (without the quotes). Follow that line with "net start spooler" again followed by pressing enter. After you see the responses, restart the computer. Then unplug the printer from the computer. Then uninstall the printer driver. (Win+X > Device Manager. Expand the Printers section. Right-click on the printer and then select uninstall driver.) Manually remove the printer from the Devices and Printers list. (Win+X > Control Panel > Hardware and Sound > View Printers and Devices. Select your printer and then click Remove Device.)
The driver itself is available here: . Make sure that you select the x64 version if you have a 64-bit version of the OS. Most desktops and laptops currently sold have the 64-bit version of Windows 8. An older computer that was upgraded may have the 32-bit version of the OS.
Find the install file that you downloaded from the Dell site. Right click on the file and select Properties. Under the Compatibility tab, choose Always Run in Compatibility Mode for Windows 7 (use the drop-down menu to select the OS version). Click Apply and then OK to save the setting. Now double-click on the installer to run it. You will need to acknowledge the UAC to allow the program to run. You will need to repeat this Compatibility step on the Setup file after extracting the files from the downloaded file. Keep track of where the extraction places the files; my computer showed the default location of C:\dell\drivers\R165704 .
Tablets with Windows RT probably can't use the driver since it isn't offered through the Windows Store.
I hope this helps.
Jun 25, 2013 | UPS Battery Backup Systems
What software do I need to connect to my MGE UPS Pulsar EXtreme 1500C?
The Personal Power Pack (UPS_psp_2_60_02.exe)is the best for MGE UPS,but it has been discontinued for a long time and it runs only on XP and older windows os.
For adjusting the advanced parameters of the UPS,u can use the upsdrv15.exe. This software works only with serial connection.
The only solution for Windows 7 is Eaton's Lan Safe software (since Eaton bought a part of MGE,the UPS is recognised by their software).
These software are not very easy to find,but they're there.
Jan 13, 2011 | MGE UPS Pulsar EXtreme 1500 C UPS System
Mikomi BC03RUT-01 conflict
my driver wont work with vista
Mar 23, 2009 | UPS Battery Backup Systems
Laptop doesn't recognize QuickCam® Deluxe for Notebooks (2)
hii john sorry about this .. ok
another solution install the driver clicke here
restarts the computre When will the solution accept my respect and greetings
sincere markknof
Aug 24, 2008 | UPS Battery Backup Systems
Ikasu wireless keyboard and mouse
Hi I have IKASU W-K-with trackball. I run Vista i just pluged it in and windows found the drivers.I allso run Driver Detective.Hope this helps.dave
Jun 29, 2008 | UPS Battery Backup Systems
Window vista
new vista alot nicer funner to use 3d styles cool effect faster stable u need to update it tho when u get it ok turn it on update it get ionline cheak windows update in start control panel then classic view then in ther windows updates and custum drivers updates do it alll and cheak msconfig on start ups unwanted and run ccleaner tool dl free online once u do all that run fast maby adjust video effects
Jan 23, 2008 | UPS Battery Backup Systems
Installation on windows vista program
Who makes the ez305 web cam. Look @ the website of the producer if they have a driver your in. But if they don't and vista won't install a generic driver it won't work. Vista will make a lot of hardware obsolete just like xp for hardware that works with windows 98.
Dec 30, 2007 | UPS Battery Backup Systems
It sounds like it is a settings issue in Windows, you should be able to fix it by following this order:
Go to your Start Menu>Control Panel>Display>Settings>Advanced
Click on: "GEForce Go XXXX" and on nView Display Mode change from Single Display to either "Clone" or "Dualview"
Than click apply and that should fix your problem.
If that doesn't work, than download the Acer Driver with the for Windows XP if your monitor is certified for vista.
This is a common issue with vista,
Hope this helps!
Dec 25, 2007 | UPS Battery Backup Systems
Nexxtech product bought with no programing for windows vista
You will find many programs (and therefore hardware devices) that are NOT supported by Vista. Many drivers have not been written yet. You very well will not find any drivers that work with this device.
Dec 05, 2007 | UPS Battery Backup Systems
Mustek Scanner
check system to see if there is lpt port(control panel - system)
check drivers of scanner that are compartible with vista
if nothing please tell me your scanner model and the cable type
Nov 24, 2007 | UPS Battery Backup Systems
UPS Battery Backup Systems Logo
Top UPS Battery Backup Systems Experts
Jax Planet
Jax Planet
Sudeep Chatterjee
Sudeep Chatterjee
Are you an UPS Battery Backup System Expert? Answer questions, earn points and help others
