Question about GE DBVH512EFWW Dryer
ERROR CODE E61GE DCVH515 - GE DBVH512EFWW Dryer
The code ER CO keeps coming on, on the display panel. The fridge and freezer still work but the code keeps coming up. Any info on that?
LG Bottom Freezer Refrigerator Error Codes Sears PartsDirect
Select
Use our model number finder
Choose your product type
Common model number plates
Close
LG Refrigerator Error Codes
These error code explanations can help you diagnose a problem with your LG bottom-freezer refrigerator. For repair how-to help, visit the PartsDirect repair help section, which includes repair help for washing machines, other major appliances, lawn and garden equipment, garage door openers, vacuum cleaners and more. You can also search for owner's manuals, get advice from an expert and find refrigerator replacement parts. Error Code
Er FS Error Code
Er rS Error Code
F dS Error Code
r dS Error Code
Er HS Error Code
Er IS Error Code
Er SS Error Code
Er rt Error Code
Er It Error Code
Er gF Error Code Error Code
r dH Error Code
Er IF Error Code
Er FF Error Code
Er CF Condition
Condenser fan motor is defective Check/Repair
Condenser fan motor, wiring or the control board Shop Parts
Condenser fan motor, Power control board, Wiring harness Error Code
Er CO Condition
Communication error Check/Repair
Communication error between main board and display board Shop Parts
Display control board, Power control board, Wiring harness
Jul 16, 2015 | LG LFX25974ST 24.7 cu. ft. French Door...
Error code E01
Models covered in this error code table :
DBVH512 DCVH515 DHDVH52
EEPROM is in the control board. Here is the part number WE4M385
Here are instructions to replace it. d9f57bce-8333-45b0-9402-b672a600df28.jpg
Jan 31, 2014 | GE DCVH515EFWW Electric Dryer
GE dryer DCVH515 - making noise when in use - metal rubbing? Any thoughts?
Hi peggymaag...
You have drum rollers that need lubrication or replacement...also you felt seal at the door may need to be replace if it is a metal to metal contact that is making the metal rubbing noise or it could be the drum bearing is going bad and making the metal noise you hear.
I will include a webpage so you can see your dryer and order the parts necessary for the repair of your dryer
Please take time to rate me 4 thumbs up
http://www.partselect.com/MultiModels.aspx?ModelNum=dcvh515gf&searchTerm=&RefineSearch=0
Sep 03, 2011 | GE DCVH515GF Gas Dryer
My clothes are being ruined in the dryer..I have the DCVH515 frontload model...clothes getting caught inside..i think some kind of seal from the inside around the door opening is gone..clothes are getting...
I have had the same problem for about 6 months. I have been sticking duct tape on the inside over where my clothes were getting hung/caught. It works :) but the heat makes the duct tape peel off so you have to keep replacing it. We finally had to call a repairman when the drum started making a horrible noise. He came out this morning and said one of the "sliders" the drum rolls on had broken. He said when the sliders begin cracking it can make a very slight gap where the clothes were getting caught. I have run 3 loads this morning and had only one dishtowel get hung whereas before multiple items in each load were doing it. He said there are multiple sliders so it may happen again.
He also said the clothes getting hung was an indication of a breaking slider so you may want to call a repairman to head off your drum doing what mine did. It cost me a total of $105 and I live in SE Texas.
Aug 02, 2011 | GE DCVH515EFWW Electric Dryer
Dcvh515: dryer does not heat. Replaced the ignitor. Still no good
Hi, If you have a gas dryer2_bing.gif.
The most common problem with a gas and no heat is the ignitor going bad...
Here is a tip that I wrote about that problem...
Gas Dryer2_bing.gif not Working Gas Dryer2_bing.gif Not Heating
http://www.fixya.com/support/r4398592-gas_dryer_not_working_gas_dryer_not
If your dryer2_bing.gif is electric2_bing.gif..
There could be a number of different problems...
Check out this tip that I wrote about this problem...
Dryer2_bing.gif Troubleshooting2_bing.gif Electric2_bing.gif Dryer2_bing.gif won t Heat
http://www.fixya.com/support/r3866345-dryer_troubleshooting_electric_dryer_won
heatman101
Jun 03, 2010 | GE DCVH515GF Gas Dryer
Clothes get caught between frame and drum
Is this the dcvh515 GE? Mine began doing that and then started making a high pitched scraping noise that sounds like it's coming fron the door gasket/seal.
Dec 21, 2008 | Dryers
DCVH515 GE Gas Dryer
The sensor in the filter "PATH" is actually located past the screen. It measures the amount of air flow passing through the exhaust cavity going outside. My suggestion is to clean the airflow duct from right past the lint filter all the way out side. It is recommended that this be done once a year for optimal performance. If this doesn't work, let me know.
Mar 16, 2008 | GE DCVH515GF Gas Dryer
Dryers Logo
42 people viewed this question
Top GE Dryers Experts
John Tripp
John Tripp
Sal DeAngelo
Are you a GE Dryer Expert? Answer questions, earn points and help others
