Question about Vehicle Parts & Accessories
Radio fuse keeps popping - Vehicle Parts & Accessories
    New Friend:
    Cheetah:
    An expert who has answered 20 or more questions within one hour.
  • 189 Answers
Overload somewhere. your pulling to much power and the fuse cannot handle it
Posted on Sep 06, 2014
Why does my radio fuse keep popping when I turn on my radio in my 1992 BMW 735i?
This indicates a possible failed component inside the radio's power supply section, causing a short. Any spark at the battery could have caused this. You'll have to get the radio repaired or replaced.
Sep 14, 2014 | Max American Terminal 30 i Fuses
Why does my radio fuse keep popping in my 1992 bmw 735i?
Do you have the correct size fuse as listed in the manual or on the fuse cover? If so do you have an after market alarm system? Many times the after market installers will use a wire that they know is hot. often an always on radio memory wire? If you bought the car new and did not install an alarm or change out the radio out then you may need to bring it into a shop that traces wires. if you bought it used and you have the correct size fuse there is no telling. Caution do not in cress the size of the fuse beyond the recommended size or you could have a fire.
04 grand prix radio fuse keeps popping
Check the radio wiring for shorts. If it's an aftermarket stereo, I recommend running the ground wire directly to the dash frame, as there's a chance the ground in the harness doesn't match up to the vehicle harness correctly. Is there anything else on that fuse circuit? A lot of times the cigar lighter is on the same circuit as well, and that may be shorting out and popping the fuse.
Jul 16, 2013 | Cars & Trucks
1999 lincoln continental alt sense fuse keeps popping
it is a dead ground somewhere...if it started when radio was installed then thats where i would look again,could be something that was overlooked...good luck.
Aug 16, 2012 | 1999 Lincoln Continental
Why does fuse # 25 keep blowing out on my Chrysler pacifica 2004
Fuses pop because it is breaking the direct line of voltage that is being selected...anotherwords...instead of when you turn on your radio and the incorrect amount of voltage that is being sent to the radio frys it, the fuse breaks/pops to stop the flow of voltage to the radio.
The problem seems to either be a bad relay or wires are touching somewhere in that system.
Nov 20, 2011 | 2004 Chrysler Pacifica
My 1999 Isuzu Roder keeps popping the fuses for the backlights and now it wont start
When the fuse for the back lights pops, does the radio stop working? If yes, then you will need to check for a short-to-ground in the area of the radio where your husband hooked up the memory wire- possibly the insulation of the wire has rubbed through and is touching metal somewhere, or perhaps the electric tape he used to cover the splice has fallen off. If the radio still works with the back light fuse blown, then it is highly unlikely that the radio has anything to do with the matter. In past experience, I have seen a Ford pickup with a similar problem, and it turned out that one of the taillight bulbs was shorted internally. Very unusual, but happened nonetheless. Good Luck!!
Nov 06, 2011 | 1999 Isuzu Rodeo
Stearing Wheel No buttons work cruse, radio,etc Fuse?
Need more data...if you are saying the cruise control and radio don't work, then its probably 2 separate issues. Cruise control shares fuses with the instrument panel, if your gauges work then its not the fuse...if its a 5 speed could be a switch not working that operates when the clutch is pushed in (if you push the clutch, the cruise will disengage to keep engine from revving). Radio shares fuses with headlite lift motors...if your headlights pop up then its not the fuse, maybe just a bad radio...blueamber...I've owned 6 of the capris
Nov 04, 2010 | 1993 Mercury Capri
When I plug in power cable it pops fuse
This radio has been hooked up backwards you have to change the resistor in the radio if you keep changing the fuses and turning it on it will do more damage to the radio there is no easy fix you have to change out the part.
Aug 12, 2010 | Cobra 29 LTD CB Radio
Radio and aircon dont work change fuse but keeps poping
you have a short circuit somewhere in those to areas... advance trouble shooting is required to find which one is causing the problem.
Robert
Sep 06, 2008 | 1999 BMW 328 Series
Vehicle Parts & Accessories Logo
Top Vehicle Parts & Accessories Experts
Thomas Perkins
Thomas Perkins
Are you a Vehicle Part and Accessory Expert? Answer questions, earn points and help others
