Question about Vehicle Parts & Accessories
My radio fuse keeps popping i dont know why - Vehicle Parts & Accessories
    Scholar:
  • 53 Answers
You have a short in the wiring somewhere. Your radio may be on a circuit that also supplies power to other things like your cigarette lighter for instance. If it's once in a while, you may have a bare wire hanging somewhere under the dash or behind the radio thats making contact with a ground causing the fuse to blow. If it blows as soon as you replace it, there is a short somewhere in the wiring. It's impossible to say where it could be without more info. Is it a stock radio? Ever been modified or replaced? Is there an amplifier that was put in? everything need to be checked..
Posted on Sep 06, 2014
I HAVE ASKED TWICE ABOUT MY 2011 DODGE NITRO AND GOT NO ANSWER THEIR IS NO SOUND COMING OUT OF MY RADIO ?
you keep typing in caps and nobody will ever answer you. check the fuse first like most would do. if you dont know where it is get your owners book out and look it up.
Sep 12, 2017 | Dodge Cars & Trucks
Why does my radio fuse keep popping when I turn on my radio in my 1992 BMW 735i?
This indicates a possible failed component inside the radio's power supply section, causing a short. Any spark at the battery could have caused this. You'll have to get the radio repaired or replaced.
Sep 14, 2014 | Max American Terminal 30 i Fuses
Why does my radio fuse keep popping in my 1992 bmw 735i?
Do you have the correct size fuse as listed in the manual or on the fuse cover? If so do you have an after market alarm system? Many times the after market installers will use a wire that they know is hot. often an always on radio memory wire? If you bought the car new and did not install an alarm or change out the radio out then you may need to bring it into a shop that traces wires. if you bought it used and you have the correct size fuse there is no telling. Caution do not in cress the size of the fuse beyond the recommended size or you could have a fire.
Why does my efi fuse keeps popping 1999 chevy prizm
Pull the EFI relay, replace the fuse, and see if it blows when you turn the key on. If it does not turn the key off, reinstall the EFI relay and remove the circuit opening relay/fuel pump relay. Turn the key on. If the fuse blows than we know the problem is One of the O2 sensors, the IAC, the purge solenoid, or the ECM You can unplug the O2 sensors, iac, and purge solenoid. Replace the fuse, turn the key on, and plug them in one at a time until the fuse blows. Replace that component. If the fuse blows with those unplugged than its probaly the wiring and possibly the ECM. let me know what you find and I'll help you more if needed.
Aug 05, 2012 | 1999 Chevrolet Prizm
Why does fuse # 25 keep blowing out on my Chrysler pacifica 2004
Fuses pop because it is breaking the direct line of voltage that is being selected...anotherwords...instead of when you turn on your radio and the incorrect amount of voltage that is being sent to the radio frys it, the fuse breaks/pops to stop the flow of voltage to the radio.
The problem seems to either be a bad relay or wires are touching somewhere in that system.
Nov 20, 2011 | 2004 Chrysler Pacifica
I keep having to put the code in the radio every time i switch it on dont no how to set it it in a peugeot 206 y reg 2001 please help
the wires are on wrong or the fuse for permanant 12v memory supply has popped ,fuse in back of set and one in fuse panel its a 10 amp red fuse but i think but it could be a 3 amp one just cannot remember ,old age
Apr 21, 2011 | Car Audio & Video
Tv wont turn on green timer light keeps flashing i have left it off one week,all day then try again,still nothing.shall i toff the tv,is it worth fixing?
I dont know for sure but i got a hdtv someone threw away and was doing the same thing and i popped off the back and right where the power cord goes in there was a blown fuse. Which i bought at radio shack for like thirty cents. That was like nine months ago and still works good.
Aug 23, 2009 | Televison & Video
Keep popping fuse on 1990 corsica...
You know whats connected to the fuse, now start systematically disconnect each component and each time you try the fuse same fault, reconnect, till you ge t to the component which you disconnect and do not blow the fuse, now you know it is in that component start tracing the wires/bulb connections. , have 10 spare fuses ready'
Aug 16, 2009 | 1990 Chevrolet Corsica
Radio and aircon dont work change fuse but keeps poping
you have a short circuit somewhere in those to areas... advance trouble shooting is required to find which one is causing the problem.
Robert
Sep 06, 2008 | 1999 BMW 328 Series
Vehicle Parts & Accessories Logo
52 people viewed this question
Top Vehicle Parts & Accessories Experts
Thomas Perkins
Thomas Perkins
Are you a Vehicle Part and Accessory Expert? Answer questions, earn points and help others
