Question about Microsoft Windows XP Home Edition
My laptop is giving me a msg power surge hub port problem
I inserted a usb device the connect to my wireless mouse before this problem started and now i can no longer connect to that particular port on my laptop is asking me to disable the port or reset it but when i reset it, the problem keep displaying it boring please help solve this problem sir
  • 63 Answers
The USB power problem might be difficult to diagnose and resolve. An option would be to restore your computer using the recovery discs, make sure you backup all your data first as this will format your hard drive and delete everything on it.
Posted on Jun 23, 2009
How to connect to laptop
Using a wireless mouse with a laptop is a convenient way to avoid using the laptop's built in mouse.
Moreover, even if you use an external mouse, carrying a wireless mouse is easier than the wired version.
Here is how to use a wireless mouse with a laptop.
Ensure that your laptop is compatible with a wireless mouse.
Most wireless mice use Bluetooth technology.
Any Bluetooth enabled laptop can connect to a Bluetooth wireless mouse.
Unpack your mouse and insert batteries to the battery chamber.
While doing so, make sure that the positive side of the battery is inserted into the positive niche in the compartment.
Place the mouse in a way that makes it easy for you to use and less stressful for your fingers.
Use a wireless receiver if your laptop does not have an built in wireless receiver (either Bluetooth or 802.11b).
It should be kept at least eight inches away from the laptop or any other object that would cause any interference.
Insert the drivers, if any, for the mouse to function properly.
Connect your receiver to the laptop by plugging in the mouse's USB connector to the USB port of the laptop.
If you do not have any free USB ports, simply use an external USB hub for more ports.
Apr 20, 2013 | HP Wireless Optical Mouse
HP LaserJet 2430 Printer Will Not Print since USB Power Surge Error
INSUFFICIENT POWER - USB PORT
If you get an error message "Insufficient power to operate USB device" when you plug a USB device into the computer's USB port or the un-powered USB hub that is attached to the computer's USB port, then this device is drawing excessive current that the USB port cannot supply. The maximum output from an USB port is 500mA. In case such as this, you need to purchased a powered USB hub and connect this hub into the computer's USB port and then connect the USB device into this powered USB hub.
Feb 19, 2013 | HP LaserJet Office Equipment & Supplies
Hp notebook Nx6110 having following problems (1) When it is powered on sometimes it fails to start and gives msg NON SYSTEM DISK OR DISK ERROR ...PRESS ANY KEY TO CONTINUE (2) its bluetooth device...
I will first try to restore the system first to the point when you had no such problems.
Then, run anti virus program like kaspersky. (Some programs catche virus or spyware well but don't fix well.)
If your problem stays same, there are two possible problems. (hightly possible first)
1) Motherboard Problem. (If your notebook were shut down due to any electric shock like sudden power down)
2) Power Problem. (Short power) - example bad battery
I hope it helps.
May 26, 2011 | HP Compaq nx6110 PC Laptop
Laptop Model : Dell XPS 1530 i think i m having some problems with the usb power issue. Problem 1: when i connect an external hard drive which have bigger capacity than 120gb, the power of the usb will...
It sounds like the motherboard is causing the usb ports to malfunction by allowing power surges into the power input to the ports.You maybe should try a powered usb hub to power your hardware or you may face motherboard replacement
Jan 10, 2011 | Dell XPS M1530 Laptop
How do i connect my wireless i.t.works optical mouse model MWO03 to my eee laptop windows 7?
Follow these steps :
1.
Check to see if your laptop supports wireless technology (Bluetooth, 802.11 or other). If it doesn't, you will need a wireless receiver. If it does, verify that your laptop is compatible with your wireless mouse, which could use either Bluetooth technology or a radio signal.
2.
Unpack your mouse and open its battery compartment. The wireless mouse won't receive any power from the laptop, making batteries necessary.
3.
Add new batteries to the compartment. Make sure that the + battery end is inserted into the + niche in the compartment.
4.
Place the mouse where it is easy to use and least stressful on your fingers.
5.
Place your wireless receiver appropriately if your laptop doesn't support wireless technology. The receiver should be kept at least 8 inches away from the laptop or any other object that would cause any interference.
6.
Place the wireless receiver anywhere from 8 inches to 6 feet from the mouse.
7.
Insert the driver CD into your laptop and follow the instructions to install the software for running the mouse.
8.
Connect your receiver to the laptop by plugging in the mouse's USB connector to the USB port of the laptop. If you do not have a free USB port, simply use an external USB hub for more ports.
Nov 07, 2010 | Computers & Internet
I am getting a power surge on th ehub port
Uninstall the SP2, or just mouse over the START menue and right click then chose properties then costumize then find the power surge then thick ALways hide...i beleive there is un update for this but you will need to llok for it as it is bug in windows.
Apr 29, 2010 | Panasonic CF30 Notebook
Hp nx6110 laptop error power surge on hub port
OK if you have anything plugged into the USB Ports at bootup, unless Keyboard or Mouse, remove everything, and see if it boots normally, if it does, then the "Hub" you are using may be faulty, or a device you are using is drawing a lot of current at switch on and overloading the USB bus, that can only supply 500mA. If it still does it, and you do use a USB KB & Mouse, then remove them one at a time & reboot, between, and see if it was one of them causing the problem. If you have nothing attached then your internal USB bus is flaky.
Feb 16, 2010 | HP Compaq nc6120 Notebook
Hp pavilion dv4000 usb port can't use
This error occures when a USB device draws more power than the USB port can supply.
To fix this problem, purchase a powered USB hub. Power up the hub and connect it to the laptop's USB port and then plug the USB device into the powered USB hub.
May 05, 2009 | HP Pavilion dv4000 Notebook
Power Surge on Hub Port
Some USB devices draw excessive power from the USB port, especially USB scanners. When this happens you need a powered USB hub, connect this to your computer's USB port and connect the USB device into the powered USB hub, you should not have any further error power surge problems.
Apr 27, 2009 | Compaq NX6110 TFT XGA Notebook
Power surge on hub port on my computer
Try unplugging everything from the hub and if that doesn't work then disable the hub.
You can either buy a new hub or buy a USB card. Both get the same results.
Oct 22, 2008 | E-Machines eMachines Desktop PC
Microsoft Windows XP Home Edition Logo
98 people viewed this question
Top Microsoft Computers & Internet Experts
micky dee
Alun Cox
Are you a Microsoft Computer and Internet Expert? Answer questions, earn points and help others
