Question about Dell Vostro 200 PC Desktop
Each time I boot up I get an error message. This
I have windows xp home edition. It is a Dell desktop computer.
Each time I boot up I get an error message. This is what it says: Error loading C:Progra~1\mywebs~1\bar\1.bin\msplugin.DLL
The specified module could not be found.
How can I repair this? Thanks
  • 93 Answers
Looks as if you have eraced part of a program that runs on start up. Run a search of mywebs and see what you come up with. Dont delete any of it. Write it down and send it to me. Budice7h20@aol.com Make sure you do the complete search also opening advanced options searching hidden files and folders.
Posted on Jun 23, 2009
  • 47 Answers
You can try to creat a file such *** that
I have trouble booting from the window's xp home Edition,When it starts up every things fine up until It starts loading the windows,It then says fatal error code 17 the D:\I386]NT5INF.CAT catalog not...
I hope you have the cd that came with that or you made system disks. You are going to have to repair the installation. Try pressing F8 and see if you can enter safe mode.
Dec 06, 2017 | Dell Dimension 2350 PC Desktop
Dell computor message on a black screen windows root \system 32\hal.dill what do I do
Use the Bootcfg utility in the Recovery Console to correct the Boot.ini file:
  1. Use the Windows XP CD-ROM to start your computer.
  2. When you receive the message to press R to repair Windows by using the Recovery Console, press the R key.
  3. Select the Windows installation that you want, and then type the administrator password when prompted.
  4. Type bootcfg /rebuild, and then press ENTER.
  5. When the Windows installation is located, the following instructions are displayed: Add installation to boot list? (Yes/No/All)
    [Type Y in response to this message.]
    Enter Load Identifier:
    [This is the name of the operating system. Type Windows XP Professional or Windows XP Home Edition.]
    Enter OS Load options:
    [Leave this field blank, and then press ENTER]. After you perform the preceding steps, restart the computer, and then select the first item on the boot menu. This should allow Windows XP to start normally.
    After Windows XP has successfully loaded, the Boot.ini can be modified to remove the incorrect entry.
May 16, 2011 | Dell Microsoft Windows XP Home Edition
Running Windows XP Home Edition Error code
The diags code was a failed response from the floppy drive. Most system didn't ship with one.
Boot to the XP CD, go to recovery console, run bootcfg /rebuild
http://support.microsoft.com/kb/330184
May 18, 2010 | Dell Dimension 8400 PC Desktop
Dell Inspiron 530s/531s desktop, Win. Xp home...Windows stops responding at the ''Loading Personal Settings'' cannot boot in safe mode.
try to boot in "Last good known configuration settings" by restarting your pc and then press F8 before windows appear and then select the boot option i mention above. if this not work since you said that it can't boot to safe mode, your other option is to repair the windows or else reformat it. when you repair the windows you must have windows xp home edition cd installer, you load it to your cd/dvd rom and then restart your pc and press F2 or DEL button before windows appear in order to go to setup bios settings. in bios settings, you choose boot order setup and setup first priority to cd/dvd and press F10 by saving the changes and then press any key when you see the prompt so that it can boot up to windows xp home cd installer and then follow screen instruction that you arrive to windows repair option.
Mar 27, 2010 | Dell Inspiron 530 Desktop Computer
My desktop came up with a blue screen last week and wouldn't boot, so I decided on a reinstal of XP Home Edition. Set Bios to boot from CD - the PC reached the stage where it uninstalled Windows files and...
First refix your RAM.
Then boot youre computer with winxp
Then go to recovery console.
Then type in command prompt "chkdsk /r"
then enter "y"
then it fixes error on disk.
Thats it.
Jun 18, 2009 | Dell Dimension 2400 PC Desktop
''Can't load kernel file'' error message on boot up
try to boot in the safe mode and tell me what happens
Nov 11, 2008 | Dell Dimension 9100 PC Desktop
FATAL ERROR MESSAGE/DELL OPTIPLEX GX150 DESKTOP/WINDOWS XP PRO
I have experienced this problem as well, it is either the CD is scratch or the CD-rom lens needs cleaning, however it can read the content of the CD, I would susgest you try a another CD-rom , borrow it from a friend. It works for me.
Nov 06, 2008 | Dell OptiPlex GX150 SF PC Desktop
Error on windows load
[boot loader]
timeout=30
default=multi(0)disk(0)rdisk(0)partition(1)\WINDOWS
[operating systems]
multi(0)disk(0)rdisk(0)partition(1)\WINDOWS="Microsoft Windows XP Professional" /fastdetect /NoExecute=OptIn
This is what the boot.ini file should look like. Use U'r recovery disk to create or edit the ini file as above. U cannot use DOS 6.22 to create this file if U'r system is formated in NTFS.
If U don't have a recovery disk, make one from someone else's XP computer (DOS 7.xx).
May 10, 2008 | Dell Dimension 4600 PC Desktop
Dell Vostro 200 PC Desktop Logo
123 people viewed this question
Alun Cox
mukhtar21 shaikh
mukhtar21 shaikh
