Question about Health & Beauty
Remington shaver manual Model 483
Where can I get one? How do I remove the battery? What is battery number for replacement?
geokohler
  • 304 Answers
SOURCE: battery replacement
I have the .PDF file from remington for disassembling your shaver for you. Also this model is known for poor battery life and I recommend replacing the NiCd batteries with Lithium Ion batteries of the same size. This will give you much more shave time and 10 time the number of recharge cycles. Post me an E-mail address where you want me to sent the instructions to you or you can just E-mail me and request the instructions and I will attach the .PDF to my reply letter ( geokohler@gmail.com). If you enclose your number I will call you for free and walk you through the process.
I hope you find this information valuable. If you do please take the time to rate this a FixYa. If you ever need my help again post it here and I will be notified of your need for further assistance by E-mail. I do this for a hobby so there will never be a charge.
Sincerely
George
Posted on Jul 28, 2008
ICCeditor
SOURCE: Remington M8221 Help
STEPS
• Thoroughly clean the razor cutter area
• Pull off (straight out) cutters and lay aside
• Release spring clips and remove
• Gently pry up and remove rubber boot
• Pry case open starting at cutter end and bending up toward connector end
• Thoroughly clean razor interior area (blow out)
• Pull up motor and remove black oscillator bars
• Pry up the circuit board by releasing the cutter-end catch using a small tool to push it in while prying gently up on the cutter-end of the board and bending up
• Clean the board and turn it over
• Note battery polarity and mark on board if not present already
• Unsolder the battery tabs using unsolder braid. Be careful not to short the electrical circuitry as the batteries are electrically LIVE at this point.
• Remove the old batteries and fully clean off the circuit board solder-pads using unsolder braid.
• Mark the installation date on the new batteries in a place where it will be visible
• Install new batteries, making sure the polarity is correct (cut the tabs to a correct length if they extend too far through the circuit board)
• Solder the battery tabs being careful not to short the electrical circuitry as the batteries are electrically LIVE at this point
• Re-install the circuit board and other parts following the procedure in the reverse order (be sure to put a soft rubber pad over the motor to hold it firmly in place when the upper case half is snapped in place)
• Before installing the metal retaining clips be sure that the rubber boot is fully free and not pinched between the case halves
• Finalize the assembly by reinstalling the cutters and screen
Posted on Aug 24, 2008
  • 5 Answers
SOURCE: Remington R 9170 shaver
http://www.remington-products.com/manuals/ib_mftitaniumu.pdf
In the PDF instructions it describes how to remove the batteries. The instructions fail to mention that there is a spit of yellow glue that is holding one of the batteries to the curcuit board with a death grip. Undoubtedly, you will have to use a knife, not in the glue, but on the skin of the battery. Pull on the teather wire, and slice the battery skin around the glue.
If after removing the batteries, and you are not thouroughly discusted with the manufacturer, then purchase a couple of AA Ni-cad batteries solder the positive of one battery to the negative of the other. then solder the free positive end to the red wire, and then the blue wire to the free negative end. Then try to remember how to reverse the process and put it back together, without leaving any parts out. ;-)
There is a risk of injury by overheating the battery when soldering. That should be avoidable if you remember how to drop solder. Just like its name, it involves having the wire securely held in place. Then hold solder iron over the wire/battery end. Then take some rosin-core solder and apply the solder to the hot tip. Then make sure the newly melted solder lands on the contact. Keep in place until it cools and holds the wire to the battery.
If you think this is better than writing to Remington complaining that they did not make it easier and use contacts, instead of solder, so we can simply pop in a new set of batteries. Or maybe look at other manufacturers, and see if they are any better.
Posted on Dec 28, 2008
brector3
  • 1621 Answers
SOURCE: I've bought 2 Remington shavers, the latest an
You will find batteries at shaveroutlet.com. I strongly suggest that you take a look inside your shaver to make sure that you have the skill required to mke this repair
Each of your models uses two batteries. See link below
http://shaveroutlet.com/shaver-battery-pack-for-most-shavers-p-211.html
Soldering is required.
Posted on Jan 16, 2010
Testimonial: "useful advice"
  • 3 Answers
SOURCE: How do I open the Remington 9190 Electric Shaver
Remove the Two ( 2 ) Phillips Head screws on the Back side of the
R 9190 shaver near the Electrical Plug .
Pry off the Gray Rubber cover that those two ( 2 ) now removed screws went thru.
Now remove the Two ( 2 ) exposed screws up near the " Trimmer Switch "
Note: If you Popped off the " Trimmer Switch " during your efforts - DON'T WORRY . It will simply pop back in place when you are finished with your repairs.
Posted on Aug 17, 2010
1969 Remington ladies electric razor model Cl how to use it
Women's Shaver Parts' Parts and Accessories ' Remington ...
www.remingtonproducts.com/.../womens/shaverpart...
Remington ProductsRemington women's hair removal replacement parts. Electric shaver parts, wet dry shaver blades, shaver heads and cutters, shaver cords, ... I have a Remington Smooth & Solky Plus Wet/Dry Rechargable Shaver (Model: WDF-5000) and am ...
Women's Electric Shavers - Remington Products
www.remingtonproducts.com/womens/.../wetdrysha...
Remington ProductsRemington Women's Hair Removal Wet Dry Shavers ... Wet/Dry Shavers. Smooth and Silky 4 Blade System Rechargeable Shaver With Almond Oil; $39.99.
Jan 07, 2016 | Remington Health & Beauty
Can I replace my Remington Titanium MS 5200 shaver's battery myself and where do I buy the battery?
You will find compatible batteries for model MS-5200 at shaveroutlet.com. See link below. You will need two
http://shaveroutlet.com/shaver-replacement-parts/batteries/shaver-battery-pack-for-most-shavers-p-211.html
To open the shaver body, remove one screw on the back. Also partially remove the 4 outer screws found on the metal plate under the cutters. Once these 4 screws are removed you can partially remove the top part of the shaver body (the parts with the trimmer on it). Then you will need to gently pry off the rubberized grip on the front of the shaver. This will reveal two more screws. Remove these to seperate the front and back of the shaver and access the batteries.
You will need to remove the wires from the batteries by melting the solder with a soldering iron. Solder in the new batteries and reassemble. Charge for 24 hours before use
May 16, 2011 | Remington MS-5200 Electric Shaver
How do I find where the battery is located?
To open the shaver and access the batteries, you must start by gently prying off the rubberized grip on the front. Once removed, you can access and remove two screws at the bottom. Under the cutters is a metal plate/clip. Remove this clip and the front of shaver can be removed and batteries accessed,
You will find replacement batteries at shaveroutlet.com. See link below. You will need two
http://shaveroutlet.com/shaver-replacement-parts/replacement-battery-for-remington-df-ms2-some-braun-p-213.html
If this job is out of your capabilities, you might want to consider the replacement part linked below
http://shaveroutlet.com/shaver-replacement-parts/remington-ms2370-lower-unit-p-208.html
Jan 10, 2011 | Remington MS2-200 Electric Shaver
How to open remington ms3 1700 electric shaver to change battery and battery type??
Your shaver model is not designed to replace the batteries. To open it, you have to remove the side grips on oscillator housing which are glued on. Disassembling it will cause it to be all marred up.
shaveroutlet.com has an easy and inexpensive solution. See link below
http://shaveroutlet.com/shaver-replacement-parts/remington-ms31000-lower-unit-p-567.html
Oct 04, 2010 | Health & Beauty
Shaver not turning on
Most likely, the rechargeable batteries need replaced. This model does not run directly from the cord. You can change them yourself if you can do some light soldering.
To replace them, you will need to remove screws on the back to take off the back cover. You can then remove the old batteries.
Batteries can be purchased at shaveroutlet.com. See link below
Feb 07, 2010 | Remington Microflex R-845 Electric Shaver
Batteries for ms5500
Give the folks at electricshaver.com a try. I tried to look up the replacement batteries for your shaver, but didn't find your model number listed on their site.
However, you can give them a call and see if they have them available, as many shavers use similar batteries, you just have to know the cross-reference list to figure it out. There phone number is 1-888-476-1785.
Normally I can provide the replacement part numbers for electric shavers and provide a link to the parts list for them/
Hope you find this Very Helpful and best regards!
Sep 17, 2009 | Remington MS5500 Electric Shaver
I need to replace the battery for a Remington
Surfing the internet is the best way to find the battery. Here's a link which might be a place you could start your search:
http://spendoo.com/1496-buy-shaving-appliances.htm
You may have to remove the battery and use the part number in your search.
It's not extremely difficult to replace the battery. There may be solder connections to deal with.
May 13, 2009 | Remington MicroScreen3 TA-3070 Electric...
Replacing the battery
Download the user manual - it has battery removal instructions ----
http://safemanuals.com/user-guide-instructions-owner-manual/REMINGTON/MS3-1000
Nov 28, 2007 | Remington MicroScreen 3-3000 Electric...
Health & Beauty Logo
43 people viewed this question
Top Health & Beauty Experts
Robin Hill
Robin Hill
wcdoc1953
wcdoc1953
Are you a Health and Beauty Expert? Answer questions, earn points and help others
