Question about Keyboards & Mice
Difnition of trouble code p1250 p1397 onbmw e46
Dear sir its accompanied with irratic idling some times missfire and check engine is on
0 characters
1 Points
Why does only half of my keyboard play
most likely a defect in the conductors or connector of the wiring from inside the keyboard to the cord
open the bottom of the keyboard, check the connector to see if the flat wiring is fully seated
unless this is the trouble it is time for a new keyboard
before you buy one use a keyboard from a friend to be sure this is the trouble
Sep 13, 2014 | Keyboards & Mice
What exactly is engine knock in regard to fuel
I has to do with the timing and the octane fuel you are using. If the timing is to slow the engine will have a low rpm fuel knock upon excelleration. If you have a newer computer controlled engine, I would be looking at the Oxygen Sensors. By not knowing the engine size I am limited as to what I can tell you where to proceed to find your problem. If it is an Obd I system it will be limited as to what codes you will get. If it is an OBD II system you can so much more information to guide you to the area of the problem, If you know some on with a code reader or you can get to an auto parts store, they can tell you if it is throwing a code and what it is.
I hope i have help you in some small way.
Feb 27, 2014 | Keyboards & Mice
Rough idle
Try changing the plug wires and see if it makes a difference.
Nov 28, 2013 | Road Mice 1995 Ford Mustang Cobra...
Dear Sir I upgarde the os from Win Xp to Win 7. My
you may download driver from ""
there is a trouble shooter which is highlighted do the needful
you mus comment for solution
Aug 22, 2010 | Logitech Cordless Desktop EX110
also there is trouble shooting there which I highlighted
you must comment
Aug 22, 2010 | Logitech Wireless Access Duo Optical...
Mouse ball stops responding, or responds irratically at times. shaking and rotating the mouse 180 seems to provide temporary solution...ball, and sensors are clean (mouse is only 2 mths old...)
Send it back for repair, there is no fixing the chip in a mouse. Sometimes they don't work after one day.
So it depends on how much you paid for it depends on if its work ending back.
This is a great mouse, I only use logitech.
It does have a 5yr warranty.
Feb 04, 2010 | Logitech Cordless TrackMan Optical...
Keyboard repair
Normal 0 Press the Receiver button (and the lights will start flashing.
Then if the Keyboard isn't working, press the small RESET/CONNECT button on the back of the board to connect the keyboard to the receiver.
If the MOUSE isn’t working, push the small RESET/CONNECT button on the back of the mouse to connect to the receiver. Then they should work okay.
Hope this helps. Bud
Apr 13, 2008 | Compaq Keyboard
No keyboard = no startup ???
Hi Sir Its more likely that you may have got fluid on your hard drive if this is the case i would sagest that buy a new hard drive and have someone put it in for you if you are not capable of doing it yourself also whoever replaces your hard drive ask them to also check your memory sticks and other components for damage but i feel that you may get away with just a new hard drive but do not hold me to it Hope this helps Paddy
Jan 15, 2007 | Acer NSK8458AN Keyboard
Keyboards & Mice Logo
208 people viewed this question
Top Keyboards & Mice Experts
micky dee
Brian Sullivan
Brian Sullivan
Are you a Keyboard and Mice Expert? Answer questions, earn points and help others
