Question about KitchenAid KUDK03ITBK Built-in Dishwasher
Dishwasher and everything run in it smells like mothballs
KitchenAid dishwasher KUDK03ITWH2, every time it is run, emits an overpowering smell like mothballs. The smell is so strong that all of the dishes inside smell like it, too. We had to throw away the plastic items because we could not get the smell out. Our dishwasher is run at least once every day (so it has not been "sitting"). We have run it 4 times and this smell is so strong we have to "air out" the kitchen. The smell comes out in the steam, too, into the kitchen from the "vent" on the front of the washer. The water from the sink (right next to the washer)smells fine.
    Sergeant:
    Champion:
  • 205 Answers
There will be some loose conections,the heating coil might be defective and please check if there is any wire damage undrneath the machine.if yes rectify it then provide a rat mesh.
Posted on Jul 26, 2009
Kitchen aid dishwasher has pinkish orange goo around soap dispenser
Run Dishwasher Magic cleaner in it.
If you need further help, I’m available over the phone at https://www.6ya.com/expert/jeffrey_634abadf963e31e5
Sep 15, 2014 | KitchenAid Dishwashers
Dishwasher smells
Check the filter catcher mesh little basket at the bottom.
Run dishwasher empty using Sanitize option with detergent.
I’m happy to help further over the phone at https://www.6ya.com/expert/zelio_00a80ed57645ccbf
Jul 24, 2014 | KitchenAid Dishwashers
I own a kitchenaid dishwasher that is only a few months old and I have this horrible smell on my dishes. I have noticed this also on our old dishwasher. What can it be? I have tried putting bleach and...
I suspect your water supply is at fault. Sulfur and iron in the water will cause terrible smells. You may try using an additive like Lemi Shine with your detergent, but it will likely not help much. I would recommend having your water tested....
Kelly
Mar 23, 2011 | KitchenAid Dishwashers
I have a burning smell coming from inside my kitchenaid superba side by side fridge. It smells like a burning plastic. The fridge still turns on and keeps things cool, but it started to kick out that...
Remove the power plug and move your fridge forward. Now look at the rear bottom side of the fridge to see if there are any parts that heats up. You can trace this to the smell emitting from the heated part and confirm. It can be the motor, contactor or the defrost timer.
Mar 18, 2011 | KitchenAid (KSRD22FKST) Side by Side...
KitchenAid KUDP01FLSS A bad smell inside the dishwasher
Here is a tip that will help you with how to clean that dishwasher up and get it smelling good again...
Dishwasher Maintenance
heatman101
Nov 23, 2010 | KitchenAid 34 in. KUDP01FLSS Stainless...
There is a foul smell when we run the washer. There is also a lot of black residue inside the washer.
heatman101
Oct 14, 2010 | KitchenAid 24 in. KUDS02FRSS Stainless...
Bad smell in dishwasher, have cleaned and even used bleach. The smell just comes back. even smells on the dishes. the smell is like a stink bug.
Three things, dryer coil, food stuck inside.
Most washers have a one way valve on the drain and a water trap
created with the line, so no water or smell can go into the machine.
Check the valve, remove the hose,that should be under the sink,
wrap a cloth around it and blow,it should not be able to blow into it.
Then make sure the hose at some point go higher then where it
connects to the drain.
Fill a bucket and fill the washer until you see a little in the bottom of the machine, watch it for a few minutes to see if it drains, it
shouldn't, dump in a bottle of white vinegar and run the machine, make sure dry is off. Then run it again, do not add anything.
Feb 17, 2010 | KitchenAid 24 in. KUDI01ILBS Stainless...
Dishwasher smells like fish
There are several possible causes.
First, make sure the machine is properly installed with the drain hose up in a loop or an air gap before going down to the drain. This is to ensure no dirty water or smells from the sour or garbage disposer backs up into the machine.
Sometimes nasty stuff gets trapped inside internal parts of the machine and inside the sprayer arms. It is normally easy to remove the sprayer arms for cleaning, on reasonably modern Bosch machines they can also be opened up for easy access.
There are also special dishwasher cleaning agents that you can use to perform periodic cleaning cycles. Some believe it is important to use rinse agents to minimize the problem, maybe it is worth trying if you don't use it.
If there is warranty left on the machine I would advise you to complain, there is a slight possibility there is something wrong in the machine for instance bad choice of insulation lining that have been known to emit foul smells.
Good luck with tracking down the cause of this!
May 24, 2009 | Bosch Dishwashers
Bad smell in my dishwasher
try running a load through witha shallow bowl filled with vinegar on the lower shelf, this should clean out anthing built up in it. does it drain into a garbage disposer hook-up? clean that out with vinager as well if you do
Feb 19, 2008 | KitchenAid 24 in. KUDS01FLSS Built-In...
KitchenAid KUDK03ITBK Built-in Dishwasher Logo
772 people viewed this question
Top KitchenAid Dishwashers Experts
Carmen Mikulic
Mike
Are you a KitchenAid Dishwasher Expert? Answer questions, earn points and help others
