Lexmark x543 magenta streak in every page - Office Equipment & Supplies
antiochpc
  • 1314 Answers
SOURCE: Horz. streak approx.3/4 down on each page I print
From the service manual:
Dark Streaks in a Single Color or All Colors in the
Direction of Paper Travel
.There are dark lines running along the page in
the direction of paper travel from the leading
edge to the trailing edge
This is generally due to fuser, paper path roller
and/or exit guides contaminated with toner
debris.
Troubleshooting Procedure
Step Check Yes No
1 Run the Remove Print Smears routine from the
printers front panel.
Did this fix the problem?
Complete Go to step [2].
2 Are there any obstructions, dirt or debris in the
printer’s paper path.
Check for toner spills inside the printer.
Clean and
remove
obstructions.
Go to step [3].
3 Visual inspect the Imaging Units and rollers for
signs of damage.
Note: Exposure to light can damage the
Imaging Unit, examine the unit quickly
and out of direct sunlight.
Replace the
defective
Imaging Unit.
Go to step [4].
4 Check the Fuser where paper enters for spilled
toner or contamination.
Clean if dirty. Did this fix the problem?
Complete Go to step [5].
5 Verify the ribbon cables and wiring harnesses
on the LED Heads are seated, connected and
routed properly.
Go to step [6]. Reseat, reroute
or replace any
damaged wiring
harnesses.
6 Generate a service test print pattern from within
service diagnostics. This will test the Engine
Controller Board.
Did the test pattern print correctly?
Replace the
Image Processor
Board.
Replace Engine
Controller
Board.
Posted on Dec 09, 2008
SOURCE: Magenta leaving a colorless streak
You need to check with Xerox , ther is some toner that was manufactured last year (2008) that was defective
the phone number for xerox support is 503-682-7377
Posted on May 09, 2009
onynn
  • 5 Answers
SOURCE: We have a Dell 5110 printer streaking
are you getting any error messages from the printer's control panel? if not you can try inspecting the fuser drum for for gouges, grooves, or any other type of damage.
Posted on Sep 09, 2009
Testimonial: "Thanks for your feedback!"
SOURCE: clp-500. toner streaking the paper.
I have the same streaks problem. Any solutions?
Posted on Dec 02, 2009
pappapumpdaf
  • 635 Answers
SOURCE: I have a HP laser 2600n and it is streaking magenta horizontally.
Sounds like the red cartridge was removed or tilted and leaked toner on the drum. Just do a self clean and it will clear up. It in the maintenance menu.
Posted on Mar 07, 2010
How do I open the lexmark x544 to change the cartridges
you could start on page 168 of the manual. I don't like to type everything there. In the end you still have to read it.
Use a PDF reader like adobe acrobat reader (free on the net) to read this:
http://www.lexmark.com/publications/pdfs/2007/x54x/v5404678_en.pdf
Jan 27, 2015 | Lexmark International X543, X544 Black &...
FRENCH/MANUEL LEXMARK X543 POUR IMPRIMER
Here is the direct link to the French version of the User's Manual for the Lexmark X543:
http://www.lexmark.com/publications/pdfs/2007/x54x/v5404678_fr.pdf
To view the Owner's Manual with Operating Instructions just use your mouse to click on the link, which is the underlined and highlighted text just above. This will open a new web browser page automatically for you and allow you to view the information at the website indicated and the contents of the Owner's Manual.
You may need ADOBE READER installed on your computer to read PDF documents.
You can download this free at WWW.ADOBE.COM if necessary.
Click on the DOWNLOAD ADOBE READER button on right side of the ADOBE home page when you get there, then follow the onscreen instructions to install the software on your computer.
I hope that was helpful to you, good luck and take care.
Joe.
Aug 13, 2011 | GE Lands Phones
How do you change the ink cartridge on a lexmark x543 printer
See the manufacturer's web-site:
http://support.lexmark.com/index?segment=SUPPORT&userlocale=EN_CA&locale=en&productCode=LEXMARK_X5435&page=product&frompage=null#1
for the 'X5435' (not the 'X543') printer, and select to download the "manual", which tells you how to maintain your printer.
May 12, 2011 | Lexmark X543dn Laser Color All-In-One...
Lexmark X543 --Getting msg Waste toner box near Full. What is required ?
very simple there is a waste toner bag that came with your Lexmark X543, so you need to remove it and dispose of the toner inside and replace exactly the same you took it and the message will message will disappear
Jan 12, 2011 | Office Equipment & Supplies
I have a red streak on the page coming from my hp color laser Juest 2600n
are you sure the colour is not magenta,if so replace the magenta toner
May 15, 2010 | HP Color LaserJet 2600n Printer
Clp-500. toner streaking the paper.
Nov 14, 2009 | Samsung CLP-500 Laser Printer
Apr 01, 2009 | Xerox Phaser 7760/GX Laser Printer
Prints black vertical line at bottom of page on every print. HP 8550gn
This should help -
Developer streak
Developer streak is characterized by a line of dark or missing toner
that stretches from the leading edge to the trailing edge. Replace the
toner cartridge corresponding to the color of the developer streak (for
example, if the streak is magenta, replace the magenta toner
cartridge).
Repetitive defects troubleshooting
Repetitive defects are defects that occur in the same vertical position
on the page, but not necessarily on every page. Most repetitive
defects are caused by problems with one of the following, and are
indicated by the positioning of the defect on the page:
 developer roller (at 38 mm)
 charging roller (at 44 mm)—see additional information under
“Charge roller set” on page 454.
 cleaning roller (at 56 mm)
 developer DSD wheels (at 65 mm)
 transfer roller (at 66 mm)
 transfer drum (occurs once per 11-by-17 inch or A3-sized page,
or every other letter- or A4-sized page)
 fuser (at 150.5 mm)
 imaging drum (at 195 mm)
 transfer belt (at 222 mm)
May 21, 2008 | Office Equipment & Supplies
Vertical streaks
The toner forms small lumps and get stuck on the doctor blade of the cartridge. Where there are the lumps it blocks the toner from getting on the roller. Removing the doctor blade and cleaning it with a soft cloth and alcohol can solve your problem.
Send me a mail at ecoworld@myt.mu if you need further help in doing it.
Sep 11, 2007 | Lexmark C500n Laser Printer
52 people viewed this question
k24674
