Question about Refrigerators
Lamona Model number LAM 6100 not making ice cubes checked ice cube tray no water some ice cubes in tray... No frozen pipes around ice tray...
  • 1462 Answers
SOURCE: rs21dcns
there is a double valve at the back bottom lhs. check continuity of both valve coils but doubtfull this is the problem. the fault may be that the filling tube is frozen. try looking in this area
Posted on Jun 13, 2007
SOURCE: no water for ice maker
make sure wire is in down position this is like the on and wire up is off
Posted on Jul 14, 2007
ginko
  • 19396 Answers
SOURCE: Ice Maker will not release the frozen ice cubes from tray
The icemaker use an avaporator system with an heatinc coil and a fan to release cubes.
In your case either the heating coil or the fan in the icemaker must be replaced.
parts can be purchased from partselect.com.
Posted on May 31, 2009
  • 142 Answers
SOURCE: water dispenser on front of refrigerator door does not dispense water. Ice Cube maker continues to make ice cubes. Defrosting doesn't fix problem.
Water dispensing solenoid is bad. You need to replace the solenoid valve. This typically is independent of the ice maker.
Posted on Jun 02, 2009
  • 212 Answers
SOURCE: Samsung RS26 frozen water line in Ice maker
all you can really do is put heat to it (hair dryer) but be careful that you don't melt the water tube. or you can remove food and leave door open til it melts
Posted on Jun 24, 2009
My ice maker does not make ice but water does run to front of fridge plz Help ????
I can't make out the words in your picture so there is not a lot of information to go on, but I will give it a try. If yours is like my refridgerator, there are a couple of off switches for the ice maker. One is on the control panel like the one you tried to photograph. Mine selects crushed ice, cubed ice, or ice off. The other soff switch is the lever switch that sits over the ice cube reservoir inside the freezer and shuts off the ice maker when the reservoir is full. If this lever switch is stuck in the up position you will make no ice. You say that water runs out of the front. Another problem that I once had with my ice maker was that the plastic housing around the ice cube tray cracked. One tray of ice cubes was made but when the ice maker flipped the tray over to expel the ice cubes the cracked plastic prevented any torque on the tray and the ice cubes would not come out. When the tray returned to the upright position new water would flow onto the tray, but since it was already full of ice cubes the water would simply overflow into the ice bucket reservoir. It did this over and over until I had an ice sculpture in my freezer and reservoir instead of ice cubes.
Jan 02, 2017 | Refrigerators
Frozen solid cube tray
Unplug the frig. Take a hair dryer and melt the ice tray. Then get a paper towel and soak up the left over water. hope this helped
Mar 30, 2010 | Refrigerators
Freezer stopped making ice cubes
Pour about 2/3 cup of water into the ice maker . If it dumps , then replace the dual water valve behind the refrig . If it does not dump the frozen cubes , replace the ice maker .
Sep 27, 2009 | GE Refrigerators
Ice cubes not freezing completely before dumping
check evaporator fan if working or u may have a leak , or check condsr fan motor :)
Aug 28, 2009 | Amana ARS2464B Side by Side Refrigerator
Ice maker is making ice cubes AND pouring water
the apparatus that distributes the water into the tray had been knocked out of balance when taking the tray out. We pulled the ice maker and replaced the apparatus back in it's proper location .
Aug 07, 2009 | Freezers
I have a GE Profile Side by side that is working fine except the ice maker won't dump the frozen ice cubes in the tray. Another party in the house decided it would be a good idea to put water in the tray...
The ice maker is basically frozen. There are two fixes for this condition. If you can transfer all of the food out to another appliance you can unplug and open the doors and let it completely defrost on its own.
the other method is to use a blow dryer. When you have completely defrosted the ice maker and thoroughly dryed it spray the ice cube tray with pam cooking spray which will act as a lubricant. When you are ready to make ice again expect the ice maker to take about 24 hours before the first batch of ice cubes are ejected.
Jun 16, 2009 | GE Profile PSS26NGS Side by Side...
Ice maker quit making ice
your refrig has a built in bypass in the filter housing so yes it will work with out a filter in place. if you have not replaced your filter in the last 6 months that is likely the problem. Hollow cubes are usually a sign of not enough water getting into the icemaker then it cycles too fast and harvests hollow cubes.
when the hollow cubes fall into your bucket they bust and put water in with your cubes freezing them together. so by solving your water supply problem you'll solve most of your icemaking issues..
Dec 19, 2007 | Kenmore 64802 Top Freezer Refrigerator
My ice freezes together!
Do you mean the ice cubes are too large to be individual cubes and come out as a lump? The water is filled by a timed fill so if the fill solenoid stays open a little and drips water into the cube tray it will have more water than normal. I guess I'm not sure if you mean the ice cubes are stuck together in the tray or are they sticking together in the holding bin area?
Jan 30, 2007 | Kenmore 74172 / 74174 / 74179 Top Freezer...
Refrigerators Logo
41 people viewed this question
Top Refrigerators Experts
John Tripp
John Tripp
Brian Coughlan
