Question about Health & Beauty
What is a pyloric polyp? - Health & Beauty
Had deviated septum surgery several years ago and having nasal blockage problems in the same nostril as corrective surgery was done.
No. Polyps grow back. You might need to go through the surgery again. Have your doctor look to verify what is going on.
May 03, 2017 | The Health & Beauty
Is it ok to take Altosec for Reflux on a long term basis?
Hello ,
Dear , here is the answer you're look for :
Long-term use of PPIs is strongly associated with the development of benign polyps from fundic glands (which is distinct from fundic glandes polyposis); these polyps do not cause cancer and resolve when PPIs are discontinued. No association is seen between PPI use and cancer, but use of PPIs may mask gastric cancers or other serious gastric problems and physicians should be aware of this effect.
Sincerely.
Nov 13, 2016 | Televison & Video
I've been in periods for 5 months they not stopping,I tried all contraception but they getting worse,help me.
There are many causes for this being infection, polyps, fibroids, endometriosis, cancer or Ectopic pregnancy (really bad) and Chylamydia (this is a very common s.t.d that has less side effects in men but can cause bleeding in women )
Would suggest as a first point of treatment of going to a doctor or s.t.d. clinic and asking for a s.t.d. test for your peace of mind and to eliminate this as a possible cause.
Hopefully it is not some of the other causes .
Ectopic pregnancy is rather nasty as a baby starts to grow in the fallopian tube and is life threatening for the mother .
Jun 04, 2016 | Pets - Others
What words can you make with the word happy holidays?
hay day polyps lap ply apply splay sip soap pay plaid paid halo hail lid pail lad pop pod pal allay ally ploy hold play lop lip plod load hop ahoy holy daily dip slip slay slap sloppy plop sold slid hid hip hippy ship shop soda solid old opal dial sad said sail
Jan 01, 2015 | Audio Players & Recorders
Convert 3cm into inches
3cm is about 1.18 inches.
One inch is exactly 2.54cm.
Sep 18, 2014 | Office Equipment & Supplies
How many cm is 2-3 mm?
There are ten (10) millimeters in a centimeter, so 2 mm is 0.2 cm and 3 mm is 0.3 cm.
May 21, 2014 | Office Equipment & Supplies
GEARS OF WAR3 WALKTHROUGH
Get into your silverback and go through the front gate that goes into the area where to fight the Leviathan. Then go to the right and turn around the right wall go straight and back into that corner in the back left. At this point just shoot the Leviathan in it's right eye. Use the vulcan and shoot in the right eye until it pops. Tap a to bring down your shield and use your rockets to shoot him in the mouth. After he leaves for the first time get out of your silverback because you're not very mobile and if you try to kill something close to you you might blow yourself up. Go to the very right side of the field by the crate and in front of the fire in the corner to kill the polyps they should be focused on Dominic instead of you. As soon as the Leviathan comes back run back to your silverback. Then go back to the spot you were at and start using your vulcan to shoot his left eye until it pops. When it does start shooting rockets into the Leviathan's mouth. Once the Leviathan goes down again move the silverback back into the corner where you first shot it's right eye until it popped. Next get back to the spot on the very right behind the crate and in front of the fire in the corner and start shooting polyps, they should be focused on Dominic. When the Leviathan comes back get your Silverback out of the corner and run back to the spot on the very right of the behind the crate and in front of the fire in the corner and start spamming rockets at its mouth. After this the Leviathan should go down for the final time.
Feb 10, 2013 | Microsoft XBOX360 By Yallstore
What sorts of corals should I buy for starters?
The best corals for the beginners are the soft corals such as, mushrooms, polyps, and Leathers. Next comes the large polyp corals such as brain, frogspawn, and torch. Finally, the most sensitive corals are the S.P.S. corals.
Aug 02, 2012 | Fish
Health & Beauty Logo
27 people viewed this question
Top Health & Beauty Experts
Robin Hill
Robin Hill
wcdoc1953
wcdoc1953
Are you a Health and Beauty Expert? Answer questions, earn points and help others
