My numark icdmix3 decks are displaying code error when I put a cd in
2 Suggested Answers
SOURCE: Numark CD MIX2 right deck skipping, sounding scratchy
Did you by any chance buy it from a b stock retailer?...send it back...also reduce your burn speed when recording cds
Posted on Sep 27, 2008
How do I connect my laptop to my numark icdmix3
If you want to mixdown onto your laptop, get a cable with RCA left and right on one end and an 1/8 headphone jack on the other. On the back is a master out w/left + right and go to line in or mic input on laptop. If you don't have a line in, you have to disable the mic signal +4 db setting in control panel/audio properties volume control. Open properties there and add mic volume control, and open advanced to turn off +4db setting.
Mar 04, 2013 | Numark Industries Numark iCDMIX 3 Dual...
My 4 months old ICDMIX3 deck does not read CDs. What should I do?
As it is under warranty, replace or refund is the way I would go. Get a Pioneer.
Dec 12, 2017 | Numark Audio Players & Recorders
I have a numark cd mix 2 im getting error cd on the screen
You may have dirty lens. You can clean it using CD lens cleaner or clean it manually.
If no joy, your optical lens may defective and need replacement.
Other possiblity cause is the mechanism is out of service.
Regards
Sep 25, 2011 | Nu Mark Numark CD-Mix-2 Dual CD...
My NDX400's display screen doesn't show anything. When I turn it on, all the "characters" flash white, so I know it works. But then, it just goes blank. No matter what I do, nothing shows...
If you was to turn the deck upside down you will see 4 main screws in the corners holding the silver top to the black chassis of the deck. undo these screws and carefully turn the deck over and lift the top off slowly. I say slowly because before putting it down (you might need someone to hold it for you) you need to un-clip the white plug and there will be a data ribbon stopping you from pulling the lid away. this is the strip you need to check both ends that the connections are clean and pushed in properly (the blue strip on the connector should be facing the middle of the circuit board) be careful not to snap the connector and make sure you push it into its socket straight and not at all at an angle or it could snap. put the white connector back in and pop the lid back on and turn it on to see if worked.
Jul 05, 2011 | Numark Industries Numark NDX400 Tabletop...
Can I connect my iphone4 to my Numark icdmix3?
Yes you should, if it is a conventional Ipod docking port. The Ipod connector on the top of the Icdmix3 is the same as the one on the iphone. Happy mixing,
Mark
Jan 26, 2011 | Audio Players & Recorders
Numark HDX system needs upgrade: Insert upgrade cd?
You just need to type Numark Hdx in your search engine or on numark's website, and they have the download for the firmware update. Download and burn to disk. Turn on your deck holding the eject button until it ask for you to insert the disk you burned. Go thru the prompts and let it install firmware *NOTE DO NOT TURN OFF DECK* or you will ruin it.
Jun 12, 2009 | Numark HDX Turntable
Numark Cd-Mix-2 left side disk problem
Cd drawer and laser assembly are belt driven. Belt needs to be replaced
Sep 08, 2008 | Nu Mark Numark Cd-Mix-2 Dual CD...
Aug 04, 2008 | Nu Mark Numark Cd-Mix-2 Dual CD...
81 people viewed this question
 Grubhead
Grubhead
