Question about Dyson DC07 All Floors Bagless Upright Cyclonic Vacuum
BEATER BAR RESET BUTTON?
WHERE IS IT LOCATED?
    An expert whose answer gotĀ voted for 100 times.
    Sniper:
  • 83 Answers
There is no reset button for the beater bar on the DC07, DC14, DC17 or DC25. If you have a DC18 or DC24 post your question again and I'll tell you where to find the reset button for the brushbar.
If you don't have a DC18 or DC24 call the Dyson Helpline, they will troubleshoot it and try to get your brushbar to spin.
Posted on Jul 30, 2009
5 Suggested Answers
  • 4 Answers
SOURCE: Beater Bar Does not turn
Also the beater bar only works when the handle is in the operating position. Meaning the foot release must be depressed and the handle tilted back towards the user.
Posted on Feb 18, 2009
SOURCE: halo beater bar has quit
take it to an oreck dealer. duh
Posted on Feb 09, 2010
Ironfist109
  • 3018 Answers
SOURCE: beater bar does not spin...
  • If the brush bar is not spinning on your vacuum there are a couple possibilities here.
  1. The first thing to check the the belt than connects between the brush bar and the brush bar motor. If it has broke or is very loos then there will be no rotation in from the brush bar. If you hear the motor whirring but no brush bar then the belt has moved to the top of the list.
  • Of course you want to make sure that the brush bar spins freely. Make sure the vacuum is unplugged and give it a few manual turns to make sure there are no hangups. Keep the brush bar of hair and things that get caught in the brush.
  • Another issue is the motor could be burned up or otherwise not spinning. If the motor is not running there is nothing to spin the brush bar. I will upload all 3 exploded diagrams of your vacuum so you can get a good view of your vacuums workings in my next post to you that I will send directly. Mean while here is my solution to your problem.
  • If you have any comments please feel free to leave them right here and I will respond to you.
  • Hope this helps and thank you for using FixYa.
Regards, Tony
Posted on Aug 15, 2011
SOURCE: beater bar is not turning...read
Worked for me thanks very very much! I always try this button and it didn't work. Pulled the head off, cleaned out any fuzz, hair, etc. Still didn't turn on the beater bar. Cursed, cried, etc. Found you here (even after trying the dyson site!) and got the solution. I had to push that button in harder than I've ever had to. Nearly thought I broke it off. Tada!! It worked. Thank you!!! Now where the kleenix?
Posted on Nov 06, 2011
I was told by a previous repair man that there is a fuse in the beater bar that needed to be replaced.
Up to my experience in my Panasonic vacuum cleaner, if the beater bar is not working this could be because the 'Carpet/Floor' selector switch is in the 'OFF' or 'FLOOR' position. In both of these positions the beater bar will not rotate. Move the selector switch to the 'CARPET' position. When in this position the beater bar will rotate once the foot pedal is pressed.
If the selector switch is in the 'CARPET' position and the beater bar is still not rotating it could be that there is something entangled in the beater bar, or the belt is worn or broken.
To check this first unplug the vacuum cleaner
Inspect the beater bar and belts to ensure that there is nothing entangled in the beater bar and that the belts are intact and are not excessively worn. If the belts are excessively worn they may slip resulting in the beater bar not rotating.
The vacuum cleaners often have an overload protection system inside the nozzle, which stops the nozzle motor when the beater bar jams to prevent belt breakage. After clearing any lint build up or jamming you may need to reset the overload protection, by pressing the reset button on the top of the floor nozzle.
May 04, 2015 | Vacuums
Kenmore model 401.39035900 vacuum cleaner beater problems
probably need a new motor and beater bar.
Feb 20, 2013 | Vacuums
Stop working. brush was cloged. It there a reset button?
i had a similar thing happen and just got off the phone with dyson. there is a resettable switch on the handle. they told me to start the vacuum in the upright position, put it in the non upright position, then push and hold in the beater bar switch which is located next to the on/off button for 10 seconds and the beater bar should start to function once again
Jul 15, 2010 | Dyson DC07 Animal Bagless Upright Cyclonic...
Beater bar not working on Halo vacuum
Check the bar to see if there is a buildup of hair or string causing it to jam,
Jun 17, 2009 | Vacuums
Beater bar will not turn
Something probably got caught in the beater bar whilst you were vacuuming, that'll cause it to stop itself so that it doesn't cause any further damage, solution:
- make sure the beater bar is clear of obstructions
- step on the red pedal on the back and recline the handle
- turn the machine on with the red power button
- press the gray button next to the red power button, this is the beater bar's ON/OFF button
- if it still doesn't turn, press and hold the gray button down for 10 seconds
- if after this it still doesn't turn, inspect the beater bar again and make sure there are no obstructions and if there aren't, call the Dyson Helpline, they will set you up with a repair with the closest authorized repair dealer in your area
Apr 24, 2009 | Dyson DC25 All Floors Bagless Upright...
Beater bar has stopped turning
All beater and rotating brush bars are fairly easy to get to with a couple of screw on the bottom of your wan. They are driven by a belt and these belts come off, break, or the bar itself is stuck with rug material. Unplug your vacumn and get our screwdriver. It;s easy to figure out once inside the wan.
Mar 02, 2009 | Kenmore 23313 Whispertone Bagged Canister...
Beater bar stopped working
hi welcome to fixya you need to replace belt if belt is ok than you burnt out the motor please check belt first as it is cheaper thank you for useing fixya please rate
Beater Bar/Brush Won't Turn
Sometimes dust,lint and thread can work its way into the bearings on both ends,take the beater bar out and see if you can turn it in your hand,if it doesn't inspect the ends and clean them.Use what ever you can find to pull out the threads.Or take it outside and hose it off.
Feb 01, 2009 | Dyson DC07 Bagless Upright Cyclonic Vacuum
YOU MAY HAVE A POSSIBLE BAD BELT OR THE MOTOR THAT RUNS THE BAR MAY BE BAD, THE OTHER POSSIBILITY IS THE SWITCH THAT TURNS ON THE BAR MAY BE BAD. OR A WIRE COULD HAVE COME OFF THE MOTOR. i THINK YOU DO KNOW THAT THE BEATER BAR DOES NOT RUN WHEN ON WOOD FLOORS.
Dec 03, 2008 | Eureka 5892AVZ Bagless Upright Cyclonic...
Dyson DC07 All Floors Bagless Upright Cyclonic Vacuum Logo
1,728 people viewed this question
Top Dyson Vacuums Experts
AskDyson
AskDyson
Samyfam
Samyfam
Are you a Dyson Vacuum Expert? Answer questions, earn points and help others
