Question about Amana ATB1935HR Top Freezer Refrigerator
Both freezer and fridge dont cool
What is problem if both feezer and fridge dont cool
I had ge refrigerator and the fridge is not cooling well
For starters a year and model number would be helpful. Do you have turn dials to contol temp of freezer and fridge or electonic pushbuttons? The fridges with manual rotating dials use a "dampner" between the freezer and fridge section. In short the freezer evap fan blows air in the freezer but also has a passage from the freezer to the fridge section which aloows a controled amount of air from the feezer section to cool the fridge section. IThis passage may be obstructed by ice build up or some other blockage. Units prior to 2002 are not controled by circuit boards and the ones after 2002 are. For more specific help give me the GE fridge model please.
Sep 24, 2012 | GE Refrigerators
Feezer cold ref. not
Check out these tips...they can help you figure out what is going wrong withyour refrigerator and why it is not cooling
Refrigeratornot Cooling or Fridge not Cooling
How to Defrost Refrigerator DefrostTimer Problem
WaterRunning in refrigerator from Freezer
Refrigeratoror Freezer not Cooling or Getting Cold
heatman101
Apr 23, 2011 | Dometic RM2852 Refrigerator
Hello How to trouble my GE top feezer, it is making avery load noise.
Check the fan to see if it is hitting on built up ice...
Check out these tips...they can help you figure out whats going wrong with yourrefrigerator and why it is not cooling
Refrigerator not Cooling or Fridge not Cooling
How to Defrost Refrigerator Defrost Timer Problem
Water Running in refrigerator from Freezer
Refrigerator or Freezer not Cooling or Getting Cold
heatman101
Oct 01, 2010 | GE Refrigerators
We have a stainless model # pfss5nfxbss. With the feezer on the bottom.. freezer is cold but the refridge. not cooling?
Check out these tips...they can help you figure out whats going wrong with your refrigerator and why it is not cooling
http://www.fixya.com/support/r3662945-refrigerator_not_cooling_or_fridge_not
http://www.fixya.com/support/r3771673-defrost_refrigerator_defrost_timer
Water Running in efrigerator from Freezer
http://www.fixya.com/support/r3780310-water_running_in_refrigerator_from
heatman101
Aug 20, 2010 | GE Refrigerators
Feezer working fine but ref.not cooling good
heatman101
80ydgh
Oct 27, 2009 | Kenmore 53642 / 53644 Side by Side...
Fridge not cooling, freezer not cold enough, ice maker not workin
is there alot of frost in the rear panel of the freezer if not the compressor is not start or getting hot because fan that cools it has failed is the part between the side/side door extremely hot if so check the cooling fan for the compressor
Aug 19, 2009 | Maytag MZD2766GES Side by Side...
Freezer and fridge not cooling (halfway)
SxS Amana upper half of feezer and Refrigerator not working
Jun 22, 2009 | Amana 22.6 cu. ft. Side-By-Side...
I have an FFA70 fridge feezer thw fridge does not drain propery
turn fridge around at bottom you will c a round black cooling pot the fridge overflow pipe leads to here so water can drip on it and evaporate with the heat from it take off pipe give it a blow to remove foreign objects it should sort problem
Feb 03, 2009 | Hotpoint FFA70 Bottom Freezer Refrigerator
Amana ATB1935HR Top Freezer Refrigerator Logo
Top Amana Refrigerators Experts
Charles T Nevin
Charles T Nevin
John Tripp
John Tripp
Dan Webster
Dan Webster
Are you an Amana Refrigerator Expert? Answer questions, earn points and help others
