Question about Kaloo Blue Crochet Booties - Size 6-12 months
What does sc in last 4 ch turn - 6 ch 7 sp mean?
Meaning of these crochet instructions.ch 2, in first sc (1 sc, 1 hdc, 1, dc), * Will. I make my ch 2 where the parentheses begin or in the single crochet in my last row of a shell
Chain 2 then in the next SC (of the row below), make the combination stitch. So, if the previous row has a bunch of SC, you would make the stitches leading up to the Chain 2. Then Chain 2 and in the next SC, make the 1SC, 1 HDC, ! DC.
Dec 02, 2016 | Sewing Machines
How to make reset for sc 544 for Ricoh Aficio SP 9100DN
Reseting SC 544 error code on Ricoh copier
Press CLEAR MODE(yellow) key,
Press 1 , 0 , 7
Press and hold down CLEAR/STOP (red) key for more 5 sec.
Press in the SP Mode( on the touch pane)
Go to sp5810 and reset SC code
Open the front door turn OFF the power main switch, and turn it ON
Heating roller overheat 1 (hardware error)
During stand-by mode or a print job, the detected heating roller
temperature reaches 220 °C.
Defective PSU
Defective IOB
Defective BCU
Defective fusing control system
Related SC code: SC 543
1. Replace the PSU.
2. Replace the IOB.
3. Replace the BCU.
Jun 08, 2016 | Ricoh Aficio SP 9100DN Laser Printer...
What does the crochet abbreviation SK mean
It means to SKip the next 2 chain stitches, single crochet in the next (third) chain stitch...etc.
Apr 10, 2015 | Bernat Big Ball Baby Sport Yarn Ombres
Ricoh mpc 6000 sc 670
Engine startup error - sudden communication reset between controller and VBCU 7/29/2008 Helpful SC 670 Engine startup error - VBCU defective 7/29/2008 Helpful SC 670 Engine startup error - VBCU installation incorrect 7/29/2008 Helpful SC 670 Engine startup error - LCT lift tray sensor was shorted 9/2/2008 Helpful SC 670 Engine start up error. Check main power supply, cn 409 for 5volts 7/20/2009 Helpful SC 670 Engine startup error - Replace laser unit and follow SP adjustments after laser unit replacement 4/5/2010 Helpful SC 670 Engine startup error - IOB board defective 6/8/2010 Helpful SC 670 Blown fuse 2 on VBCU due to shorted harness in registration motor harness 6/8/2010 Helpful SC 670 Engine start up error - Check wiring for df feed in cover.. 8/6/2010 Helpful SC 670 Engine startup error - Replace finisher main board 10/26/2010 Helpful SC 671 Controller mis-match error - Install correct controller b
THIS UNIT IS VERY HARD TO WORK ON YOU NEED A SERVICE CALL, GOOD LUCK! -Carl
Mar 31, 2015 | Ricoh Office Equipment & Supplies
I can turn my Cobra 21GTL on and it goes right back off!
sorry disregaurd the wire colors.. on last post
1. Ground Shield
2. Audio
3. Transmit
4. Receive
5. CH. Up
6. CH. Down
wires can be any color. just matters what pin and pole of the switch they are one.
Oct 20, 2013 | Uniden Bearcat Pro PC68XL 40-Channels Base...
Hai ....am vivek .please help me dears...i have RICOH Aficio 2045 ...it will appears sc 990. What's the solution for this error?? Plz help me ...
SC 990 is software performance error. This means The software attempted to perform an unexpected operation.
Possible causes:
1. Software defective
2.Internal parameter incorrect
3.Insufficient working memory
4.When SC occurs, the file name, address and data will be stored in NV RAM this information can be checked by using SP 7403. Note the above data and situation in which this SC occurs. Then report the data and conditions to your technical control center.
Apr 23, 2013 | Office Equipment & Supplies
Is the sunvic sp2 a 2channel timer please
Yes. It appears the Sunvix SP2 is 2-channel timer.
http://www.sunvic.co.uk/documentation/Programmer_Select_207.pdf
Two-channel means CH central heat and WH water heater can be programmed separately, and each can have its own timing program.
pg 3
The timer offers pre-programmed options for both CH and WH, which can be used, or program your own schedule. chart pg 5 and steps pg 3
Limitations: both channels operate on same clock time, and dip switch setting. pg 6. So the WH cannot be programmed for 5-2 weekdays-weekends and CH programmed for 24 hour.
As a convenience for varied work schedules, Sometimes people use the 5-2 weekday-weekend option so 2 days of week can have different programming, and then fudge current day setting during the set-current-time step pg2 so the 'weekend days' are actually moved to wedsday-thursday instead of sat-sun.
Option: both CH and WH timer programs can be linked and follow same programming by using copy button. pg 5
Using advance button on either side of timer, pg 3-4, WH and CH timing schedules can be overridden temporarily until next set point is reached. Then regular programming automatically resumes.
If override or Advance button is pushed for either CH or WH, it reverses whatever programming is in effect. On becomes off, or off becomes on. However if CH thermostat is satisfied and room temperature has not fallen below thermostat set point, then override will not turn CH on, but override will turn CH off. Same for WH override: If cylinder thermostat is satisfied with internal water temperature, the water heater will not turn on and heat more water, but the override can turn water cylinder off.
Unit requires Cr2033 lithium button battery. Pg 6. Probably lasts 3-5 years. Programming is protected for 30 days from power outage.
If programming is lost, change battery, the reset timer and reprogram to restore functionality.
Nov 24, 2012 | Hardware & Accessories
Correct wiring for a ASTATIC TEARDROP MIKE to a RANGER RCI 2950DX
here is the info you asked for the following is the correct wiring.
Mic Wiring Info
Stock Mic Wiring
1. Ground Shield
2. Audio Yellow
3. Transmit Red
4. Receive Black
5. CH. Up White
6. CH. Down Blue
Turner 4-Wire MIC. Wiring
1. Ground Shield
2. Audio White
3. Transmit Black
4. Receive N/C
5. CH. UP N/C
6. CH. Down N/C
Turner 6-Wire MIC. Wiring
1. Ground Shield & Red
2. Audio White
3. Transmit Blue
4. Receive N/C
5. CH. UP N/C
6. CH. Down N/C
Astatic 4-Wire MIC. Wiring
1. Ground Shield
2. Audio White
3. Transmit Red
4. Receive N/C
5. CH. UP N/C
6. CH. Down N/C
Astatic 6-Wire MIC. Wiring
1. Ground Shield & Blue
2. Audio White
3. Transmit Red
4. Receive N/C
5. CH. UP N/C
6. CH. Down N/C
Mar 11, 2009 | Connex 3300 240-Channels Base CB Radio
Error Aficio 550
reset the problem first if don't work then replace laser unit
1, press "clear mode" on up-right of panal.
2, enter 107
3,press and hold "clear/stop" for 3-5 second
4, turn power off and on
Dec 12, 2008 | Ricoh Aficio 450 Copier
Copier problume.
return SP1-902-1 to 0. Then, the SC will
be cleared.
Sep 23, 2008 | Ricoh Aficio 1085 Laser Printer
Kaloo Blue Crochet Booties - Size 6-12 months Logo
18 people viewed this question
Top Kaloo Toys Experts
Andrew Taylor
Andrew Taylor
Are you a Kaloo Toy Expert? Answer questions, earn points and help others
