Question about Russell Hobbs Coffee Makers & Espresso Machines
Glass panel heater how to mount - Russell Hobbs Coffee Makers & Espresso Machines
The. Glass seems to Be loose in the door of a 2000 Camry convertible
you will have to remove door panel to inspect the lower glass mounting frame to see if the rollers on window regulator frame are bad or lower glass mounting frame could be loose,or possible window regulator motor loose or motor woren out. hope this is helpful.
Mar 22, 2015 | 2000 Toyota Camry
GE pss26lgrb defrost mode Freezers
There is a problem with your self defrosting system which has 3 different parts. You need an ohm meter to test 2 of them. The defrost heater and safety thermostat are mounted to the cooling coils in the freezer behind the back wall panel. The safety is a round disk at the coil top with 2 wires coming out of it. When it is cold the reading across the 2 wires should be like a closed switch. The heaters are in a glass tube near the bottom and should read around 20 ohms. If no reading from end to end of the heater it is burned out. The main mother computer board in mounted on the outside back wall under a square cover panel. Any one of these parts will cause a freezer ice build up. The main board is the most expensive average price $150.
Mar 02, 2015 | GE Refrigerators
1000w athena glass panel heater, how to set timer/program?
Recently bought the Athena glass panel heater from B&Q but there were no instructions. Easy enough to set time but how do you set the timer for coming on in the morning and then again in the evening?
Dec 07, 2010 | Heating & Cooling
How to remove the window driver side of toyota corrola 1988
Door Glass and Regulator - REMOVAL & INSTALLATION
Front Door
  1. Disconnect the negative battery cable.
  2. Remove the front door panel to gain access to the regulator assembly.
  3. Remove the service hole cover.
  4. Lower the regulator until the door glass is in the fully open position.
  5. Remove the two glass channel mount bolts.
  6. Pull the glass up and out of the door.
  7. Unbolt and remove the inside door panel frame if so equipped.
  8. If equipped with power windows, disconnect the electrical connector.
  9. Remove the equalizer arm bracket mounting bolts.
  10. Remove the window regulator mounting bolts and the regulator (with the power window motor attached) through the service hole.
To install:
  1. Coat all the window regulator sliding surfaces with multi-purpose grease.
  2. Place the regulator (with the power window motor) through the service hole and secure with the mounting bolts. tighten the bolts to 48 inch lbs. (5 Nm). Attach the power window harness if equipped.
  3. Place the door glass into the door cavity.
  4. Connect the glass to the regulator with the channel mount bolts.
  5. With the equalizer arm, raise the glass to the almost closed position and make sure that the leading and trailing edges of the glass are equally distant from the top of the glass channel. If not, adjust the equalizer arm to achieve an even fit.
  6. Install the service hole cover.
  7. Install the door panel and reconnect the negative battery cable. Check window and door for proper operation.
Hope helps (remember rated and comment this).
Aug 25, 2010 | 1988 Toyota Corolla 4 Door
How do I remove heater core on 1997 dodge stratus
prev.gif next.gif Heater Core REMOVAL & INSTALLATION Cirrus, Stratus, Sebring Convertible and Breeze
  2. Remove the radio/HVAC control module bezel. CAUTION
    The vehicles covered by this manual are equipped with a Supplemental Restraint System (SRS), which uses air bags. Whenever working near any of the SRS components, such as the impact sensors, air bag modules, steering column and instrument panel, disable the SRS, as described earlier in this section.
  3. Remove the right instrument panel side trim.
  4. Remove the two retaining screws at the lower right side support beam.
  5. Remove the instrument panel support bolt at the A-pillar.
  6. Remove the left instrument panel side trim and upper instrument panel bezel.
  7. Remove the lower knee bolster and console screws at the instrument panel.
  8. Remove the gearshift knob and shifter bezel.
  9. Remove the mounting screws at the front and rear of the floor console. Remove the front and rear console halves.
  10. Remove the right side instrument panel support strut.
  11. Drain the cooling system into a suitable container, then disconnect the heater hoses at the cowl panel. Plug the heater core outlets to prevent coolant from spilling during unit housing removal. Fig. 1: Remove the heater core cover 90906g01.gif
    Fig. 2: Remove the heater core 90906g02.gif
  12. Remove the mounting screws and heater core cover.
  13. Remove the heater core from the vehicle. To install:
  14. Carefully position the heater core unit into the heater housing.
  15. Install the heater core cover onto the heater housing and tighten the mounting screws.
  16. Install the right side instrument panel support strut.
  17. Install the front and rear console halves.
  18. Install the shifter bezel and gearshift knob.
  19. Install the lower knee bolster and console screws at the instrument panel.
  20. Install the upper instrument panel bezel and left instrument panel side trim.
  21. Install the instrument panel support bolt at the A-pillar.
  22. Install the two retaining screws at the lower right side support beam.
  23. Install the right instrument panel side trim.
  24. Install the radio/HVAC control module bezel.
  25. Fill the cooling system to the proper level.
  26. Connect the negative battery cable.
Sebring Coupe and Avenger
  1. Disconnect the negative battery cable. CAUTION
  2. Remove the instrument panel from the vehicle, as outlined in Section 10 of this manual.
  3. Drain the cooling system into a suitable container, then disconnect the heater hoses from the dashboard panel. Plug the heater core outlets to prevent coolant from spilling during unit housing removal.
  4. Remove the center stay.
  5. Remove the lap cooler duct mounting screw. Remove the center duct.
  6. Remove the left and right rear heater ducts.
  7. Remove the foot distribution duct.
  8. If equipped with A/C, remove the cooling unit mounting nut and bolt.
  9. Remove the retainer clip, then the heater unit.
  10. Remove the heater core. Fig. 3: Exploded view of heater unit and core assembly 90906g03.gif
    To install:
  11. Install the heater core into the heater housing.
  12. Install the heater housing and retainer clip into the vehicle.
  13. If equipped with A/C, install the cooling unit mounting bolt and nut.
  14. Install the foot distribution duct. Install the left and right rear heater ducts.
  15. Install the center duct, then install the lap cooler duct mounting screw.
  16. Install the center stay and connect the heater hoses to the heater core at the dashboard panel.
  17. Install the instrument panel.
  18. Fill the cooling system to the proper level.
  19. Connect the negative battery cable.
Jul 08, 2010 | 1997 Dodge Stratus
How do i replace left door mirior
remove trim panel, remove mirror fasteners.
Glass, Outside Mirror—Town Car
Removal and Installation
  1. Push upper edge of outside rear view mirror glass (17K707) into the outside rear view mirror to expose latch release.
  1. Using a small flat-bladed screw driver or equivalent, move latch release to released position.
  1. Remove outside rear view mirror glass mounting back and outside rear view mirror glass from outside rear view mirror.
  1. Disconnect heater wire connectors and auto dimmer connector, if equipped.
  1. To install reverse Removal procedure.
Mirror, Power—Outside Rear View
Town Car
  1. Disconnect battery ground cable (14301). Refer to Section 14-01 .
  1. Remove front door trim panel (23942). Refer to Section 01-05 .
Trim Panels, Door Front—Town Car
Removal
  1. Snap out two door pull strap retaining screw covers. Remove screws.
  1. Remove three screws on front and rear side and center of front door trim panel (23942).
  1. NOTE: The following procedure must be used during removal and installation of the door armrest and trim panel. Refer to the appropriate illustrations for component and vehicle model identification.
    Using the Trim Pad Removing Tool from Rotunda Windshield and Moulding/Trim Removal Kit 107-R0401 or equivalent, pry the trim panel retaining clips from the door inner panel.
  1. NOTE: Do not use front door trim panel to remove trim clips from door inner panel. Replace any bent, damaged or missing push pins.
    Remove window regulator control switch housing from front door trim panel. Lift up housing in front and disconnect all connectors.
  1. Disconnect wiring harness and heated seat switch electrical connectors if equipped.
  1. Remove the door trim panel.
  1. Disconnect two electrical connectors.
  1. Remove nut from outside rear view mirror mounting base.
  1. Swing outside rear view mirror (17682) toward driver door window glass to expose screw in mount base.
  1. Remove screw from outside rear view mirror base.
  1. Remove outside rear view mirror from front door (20124). Guide wiring and connectors through hole in front door.
  1. To install, reverse Removal procedure. Tighten nuts to 8-10 Nm (71-88 lb-
Nov 05, 2009 | 1996 Lincoln Town Car
Need instructions on removale and install of 1985 newyorker door regulator
Front door flex drive window regulator tightening sequence
  1. Lower the glass all the way. Remove the trim panel as described earlier.
  2. Gently pull the air and water shields off the door.
  3. Remove the 3 nuts that attach the glass to the regulator channel. Then, lower the glass all the way.
  4. Remove the outer glass-sealing weatherstrip by disengaging the spring clip tabs from the slots in the outer door panel. To do this, grasp the weatherstrip between the thumb and forefinger on either side of each spring clip. Pull out slightly and then up at each clip until the weatherstrip is free.
  5. Work the glass off the mounting studs and remove it through the slot in the top of the lower door.
  6. To remove the regulator, drive the center pin of each regulator mounting rivet out with a hammer and drift punch. Then, drill the rivets out with a 1⁄4 in. (6mm) drill.
  7. Disengage the regulator arm from the lift plate and then remove the regulator through the access hole in the inside of the door. To install:
  8. Load the new regulator in through the access hole and engage the access arm with the lift plate. Then, bolt the regulator to the door with 1⁄4 –20 nuts and short screws, making sure these screws will not interfere with regulator operation. Tighten the screws and nuts to 90–115 inch lbs. (10–13 Nm).
  9. Install the new glass by lowering it into the door. Position the glass on the mounting studs.
  10. Install the outer weatherstrip by sliding the clips into the door panel slots and sliding them downward until they lock.
  11. Raise the glass to the top of its travel, then loosely install the 3 retaining nuts. Seat the glass fully in the upper glass run to adjust it, and then tighten the mounting nuts gently.
  12. Install the air and water shields and the trim panel as described earlier in this section.
Jul 12, 2009 | 1985 Chrysler New Yorker
Wiring up the heater elements on the electric door mirrors.
I have a Mazda 6 Estate - I've just had the glass out of my mirror this evening, because my mirror heater is not working - there was a bunch of wires into the mirror unit - two of which went to spade connections on the back of the mirror.
The glass itself is on a plastic mount. The mount and the glass should just lever/pull out - that's what I did with mine - I was worried it was going to break though, it took substantial force! Once out I could see a plastic rectangle with rounded corners that it had been clipped onto. It clipped back into place with out any difficulty (on mine there is a wire guide behind the glass - just make sure that you haven't bent it upon removal - I had, but the pliers straightened it again).
Oct 12, 2008 | 2002 Mazda Miata
Electric wall mounted heater
Make sure that the heater is mounted where convection currents occur freely. When heat builds up around the top of the heater its temperature will rise uncontrollably. You'll be luck not to get a fire.
Jan 18, 2008 | Fahrenheat (FFH1614) Wall Mounted Panel...
Coffee Makers & Espresso Machines Logo
12 people viewed this question
Top Russell Hobbs Coffee Makers & Espresso Machines Experts
Paul Bade
ray gallant
Tom Chichester
Are you a Russell Hobbs Coffee Maker and Espresso Machine Expert? Answer questions, earn points and help others
