Question about Saws
Where can i purchase a switch? - Saws
    Sergeant:
  • 458 Answers
You did not give enough information on the device with the problem. I am sorry I can not help you at this time.
Posted on Sep 04, 2014
I have a 98 blazer 4wd emergency lights switch
If you purchase the complete multifunction switch to repair, you will need to disassemble the column covers and steering wheel to access the screws. If you purchase just the hazard switch (sometimes available from GM), just remove the upper cover and use a pocket screwdriver down the side to release the lock tab. Then insert the new switch and reinstall the cover.
Sep 24, 2014 | 1998 Chevrolet Blazer
Rear lights on my buick will not turn off
Possibly your brake light switch may be improperly adjusted or may be shorted. Purchase a Haynes repair manual for your automobile and follow the remove, install and adjustment procedure in the manual. You should be able to purchase a new switch at your local automotive parts store. You should Google the brake light switch so you can get an idea of what it looks like.
The switch should located either in front or behind the brake pedal lever. Before you purchase the repair manual and brake light switch, remove the wire connector off the brake light switch to confirm the switch or adjustment is your problem.
I hope this helps and good luck!
Dave
Jul 25, 2014 | 2004 Buick Park Avenue
Subzero 3211rfd fan runs non-stop. I suspect it's using tons of power. Should this be happening?
No sir it should not! Your problem is more than likely your fan switch which can be found for purchase all over the web. Purchase a black back universal fan switch from somewhere and change the switch.
refer to this websites blog post on changing a light switch, onlu difference is you change the switch located right next to it. Switch replacement for sub zero.
thanks
-joe b
Mar 15, 2013 | Refrigerators
The main on/off switch is defective... Where can I purchase another one? Honeywell portable heater HZ-515
dear sir /madam
please find out heater unit company,s dealer at your area you can purchase that switch or you contact to your maintenance personnel for further action .i mean replace your defective switch.
hope answer the question
please vote
thank you!
Sep 05, 2010 | Honeywell HZ-515 Baseboard Heater
I purchased a dx-esw5 5-port ethernet switch and am haveing problems setting it up.
You will need to connect this device to a router.
there is no setup for a switch.
It either work or doesn't work.
May 20, 2010 | Computers & Internet
Where can I purchase parts?
Try Orange County Appliance Parts in Garden Grove, CA. http://www.ocapsupply.com/
Jun 10, 2009 | Coleman Propane Forced Air Heater...
The "on" switch has gone out.
If the switch is indeed bad, then the obvious solution is to replace it, whether you opt to do it yourself, or to have a local vacuum cleaner repair shop do it. Be aware though that if your purchase a new switch and it turns out that your old switch was not teh actual cause of the problem, then in most cases you will not be able to return / get a refund on the switch you purchased.
May 07, 2009 | Hoover Tempo Widepath Upright Vacuum -...
Saws Logo
Top Saws Experts
Tom Chichester
ray gallant
Pieter Vleeshouwers
Pieter Vleeshouwers
Are you a Saw Expert? Answer questions, earn points and help others
