Question about ASUS Computers & Internet
Error unable to load dll (1114)
I'm trying to instal tower 6(7)x64..and this problem come out. What to do?
    Top Expert:
  • ASUS Master
  • 8,376 Answers
Check hdd
Posted on Oct 25, 2016
2 Suggested Answers
anasourabh
  • 202 Answers
SOURCE: error: 0x80040702 Failed to load DLL :
It sounds like the uninstall files have been corrupted. The best option in
this case is to reinstall the game and then uninstall it.
Posted on Nov 17, 2009
Error 0xc000007b
fix 0xc00007b error "the application was unable to start correctly"
there may be multiple reasons as to why you might receive 0xc00007b error when trying to run an application on a windows machine. 0xc000007b error usually comes from mixing up 32bit environment with 64bit one. For example 32bit application loads a 64bit dll causing 0xc000007b error.
Solution 1
In most cases it's .NET framework causing issues. This can easily fixed by re-installing latest .NET framework from [link]
Solution 2
Re-install the application that you are trying to run. It sounds simple but the application data files could be corrupt or missing. This could be caused by a installation that did not complete successfully or by a virus.
Solution 3
Running the application as an administrator could fix this error. Right click on the program shortcut or program .exe file, then click on Properties, and on the Compatibility tab. Check the Run this program as an administrator box, and click on OK
Solution 4
Restart your computer as some applications require restart after installation to function properly.
Solution 5
Run Windows update as it can provide application fixes and updates. Furthermore it installs missing drivers and updates the outdated ones like graphic card drivers. Windows 7 / 8 / 8.1 users need to search for "windows update". select all important and optional updates and click on the "install updates" button. If you use Windows XP navigate navigate to Windows Update by choosing Start > All Programs > Windows Update. When the scan is complete,Click the Review and Install Updates link. Finally press the "install now" button.
Windows 7 / 8 / 8.1
Windows XP
Solution 6
manually update the application if possible.
Solution 7
re-install Microsoft Visual C++ from [x32 link] or [x64 link]
Solution 8
re-install DirectX [link]
Solution 9
Many times hard disk problems can be repaired using the chkdsk command. If you are using windows 7 press the start button in bottom left corner of your screen. If you are using windows 8 / 8.1 press the windows key .Search for "cmd" and Right click it and select "Run as administrator". Windows XP users Click on start > run. In the Run box, type in "cmd" in the box.
Windows 7:
Windows 8 / 8.1
Windows XP
A CMD window should appear. In that window you can just type it as you see "chkdsk c: /f /r". If you have more then one drive or partition, you will need to tell it the disk (chkdsk d: /f /r).
If it is the primary windows disk c: it will ask you to schedule it for next boot. When you restart, it will do a chkdsk for you before even getting to the login screen.
Solution 10
This solution only works for a 64-bit system. It requires replacing files is system32 directory so be careful. Only attempt this solution if you are confident and if other solutions have failed. When Microsoft Visual C++ Redistributable Package is not properly configured it may cause 0xc00007b error. Firstly download the zip file [link] and decompress it. Reboot in safe mode and go to C:\Windows\System32. copy all files included in the zip package (mfc100.dll, mfc100u.dll, msvcr100.dll, msvcp100.dll and msvcr100_clr0400.dll) to C:\Windows\System32 replacing the current ones. After that reboot in normal mode.
If all the solutions above haven't worked i would consider backing up data and performing a clean install of windows.
Jan 11, 2016 | Dell Inspiron Computers & Internet
Error 1114
Hello Bruce,
Since you are here you have internet connection. Best solutions for network errors and problems is do a web search for the error. here is one solution for the problem.
http://answers.microsoft.com/en-us/windows/forum/windows_vista-networking/error-1114-dynamic-link-library-dll-intialization/f6245128-52f8-4fb7-a66b-9928c483cf8a
Nov 01, 2014 | Computers & Internet
1670: unable to load module d:iss setup.dll,error code:193
this game was not released for the PS3 and may not be compatible with the newer hardware.
Jun 22, 2013 | Activision Spiderman: Friend or Foe for...
1670: unable to load module d:\iss setup.dll,error code:193
get current PS update when you turn on system - if the update doesn't automatically load - go to system - system updates - follow instructions on machine.
When i try and run photo impression program is giving the error msvcrt.dll.
Good day! Pls. retry the installation, your installation with photo impression was not unable to be successfully loaded all the files. Uninstall please the photo impression then try again the installation. msvcrt.dll is a file that is needed in photo impression. Or try to copy that file in your OS cd.
Jan 11, 2010 | Computers & Internet
MSVCR71.DLL NOT FOUND
If the error started appearing soon after you have installed a new application or device driver, then it is possible that the error is occurring due to problems in the installation. To fix the error in this case, uninstall the software you installed and reinstall it.
Many times, errors related to DLL files, such as Msvcr71.dll, occur due to malware infections. Download, install and run Malwarebytes.
Hope this helps.
Jul 09, 2009 | Microsoft Windows XP Home Edition
Error: 1670 Unable to load Module D:issetup.dll error code 1114
Router setup
If you are using the cd that comes with the router, that is the problem. You do not have to use the cd. Go to the control panel and un-install the program that the cd installed. then:
Shutdown your PC. Unplug the power from the router and the cable modem.
Wait 30 sec. then plug in the power to the cable modem, wait 30 sec. then plug the power to the router. Wait till you have "Internet" light then restart your PC. The PC should pick up an IP address and you should be able to get on-line. This is if you have a cable service provider. If you have DSL, the router needs to be configured with PPOe.
If I could be of further assistance, let me know. If this helps or solves the issue, please rate it.
Thanks, Joe
I’m happy to assist further over the phone at https://www.6ya.com/expert/joe_8b8c2cd6ce148309
Mar 02, 2009 | Linksys Ultra RangePlus Wireless Routr...
Unable to load install CD
Router setup
Thanks, Joe
Dec 26, 2008 | Computers & Internet
I have a WRT160N and when I put in the install CD it gives me an error code: Unable to load Module D:\issetup.dll Error Code 1114
Router setup
Thanks, Joe
Dec 26, 2008 | Linksys WRT160N Wireless Router
Computers & Internet Logo
1,231 people viewed this question
Top ASUS Computers & Internet Experts
Alun Cox
Are you an ASUS Computer and Internet Expert? Answer questions, earn points and help others
