Question about New Home HF-504D Mechanical Sewing Machine
A manual for bush ak37 - New Home HF-504D Mechanical Sewing Machine
Singer 3314c need help with timing
Hi the point of the hook should be in line with the needle and just above the hole in the needle with the needle 2.5mm up from the lowest needle position. The gap between the bottom line and bush should be 2.5mm in the lowest position
Sep 14, 2017 | Singer Sewing Machines
Lost manual for bush sewing machine 988
Let me point you directly to Bush to request a replacement manual.
Nov 14, 2014 | Sewing Machines
Bush instructions manual
Go to google and search "Manual 988".
Jul 15, 2014 | Sewing Machines
When to cut rose bushes winter or spring
Yeah the freeze a bit but if you cut them low and pile straw on them they ride out the winter ok. I cut mine in the fall and pile leaves on them.
Oct 12, 2012 | Sewing Machines
The hand wheel on my Janome 9000 has become very tight and hard to turn. I am still able to sew but something isn't right.
It is very likely that the main shaft bushing on the handwheel side has failed. It is very easy to diagnose. With the top cover removed, one can inspect the bushing for any discoloration seeping from the bushing. If that is the case, the main shaft and the bushing will need to be replaced. Not a big deal, I've done lots of them, but definitely a job for an experienced technician. paul@howellgroup.org
Aug 20, 2011 | Janome Memory Craft 9000 Computerized...
I bought a used juki DDL-8500 and i am having difficulties to adjust the stiches which are being made by it. i will b grateful if u can attach a manual for the sewing together with your reply.
hi there
you can go to www.juki .com
under industerial sewing machine youy can download DDL 8700 instruction manual it's same DDL8300 model.
now you can do next steps
1- change needle with new one.
2- you can find tow mark on needle bar the upper mark for adjusting the hight of needle bar bring the needle bar at lower position and check if the upper mark aqual with the lower bushing or no.
3- when the lower mark aqual with the lower bushing at this time the blad point of hook must be at the center of groove for the needle if no lose tow screw for the hook and readjust the timming between the blad point for the hook and grove for needle bar
best regards
ashraf abozid
aabozid@hotmail.com
Aug 05, 2010 | Juki DDL-8300
My sewing machine gears jammed.
One or more of the bushings is seized, the machine needs to disassembled, the bushings removed, cleaned, re-lubricated. Not something you can do yourself.
Apr 07, 2010 | Baby Lock Espire
Bernina Patchwork 140 handwheel is getting stiff to turn
A stiff handwheel can be a simple as a thread stuck in the raceway or as severe as a failed uppershaft bushing.
Using your instruction manual, perform the basic maintenance and see if that helps. If not, take it to a repair person for evaluation.
Jun 17, 2009 | Bernina Activa 140
New Home HF-504D Mechanical Sewing Machine Logo
Top New Home Sewing Machines Experts
Tally Girl
Tally Girl
Nava Hirshenson
Nava Hirshenson
Level 1 Expert
Are you a New Home Sewing Machine Expert? Answer questions, earn points and help others
