Question about NEC Ip2at-12txd Phone/telephone Handset black
My NEC has no plug. How do i get power for it
Looking for a power supply for a NEC PX-42XRA4 plasma tv?
Paul, Check the attached links, not much on this power supply.
"I hope this helped you out, if so let me know by pressing the helpful button. Check out some of my other posts if you need more tips and info."
NEC TV Power Supply Board
NEC Plasma TV Repair Part Number Guide for NEC Hitachi Fujitsu Plasma...
Repair KIT Capacitors FOR NEC Plasma TV P506Y1 FOR Power Supply Ypsu J011A...
REPAIR SERVICE FOR POWER SUPPLY BOARD OF NEC 50XP10 50 PLASMA TV
Mar 08, 2016 | NEC Televison & Video
NEC PX-50XM4A 50" plasma tv - I get a picture but no sound. I have my cable box plugged in to the DVI port converted to HDMI going to my cable box but I cant get sound when I plug external speakers in to...
HDMI carries both video and audio.
Do you get video and audio on TV. Just to be sure.
Now are the external speakers powered ?
are you connecting the Speakers to Audio Out of the TV ?
By the way, I cannot see any RCA port that is output port on your NEC plasma. NEC 50XM4 User Manual Specifications The audio input is for audio from dvd for example.
Oct 23, 2013 | NEC Televison & Video
Hello, I have NEC MultiSync LCD195VXM+ and when I turn it ON, there is just white shining LCD and nothing else. When plugged in power it came shining ON and after about five seconds its go into sleep...
1. From what you have described this sound as though the video card ( internal) is defective. Most mother boards have video cards on the mother board.
2. use a know good video card and install it to the mother board > there should be ample slots to install it.
3. The OS (operating system should see the installed video card immediately and install drivers if you see a screen then this has isolated the problem to video.
If you don't see any video then you have a defective mother board.
Jul 14, 2011 | Computers & Internet
The proper way of charging nec computer laptop
insert the battery onto the laptop. Then plug the power cable to the wall and then plug it straight to the laptop. Its best to charge the laptop if it is shut down so that the laptop would charge faster..
Apr 29, 2011 | NEC Computers & Internet
I have lost the power cable for my NEC LT 220.With the unit placed on a table ,which of the power pins should be assigned 'Live and Neutral' the center being the ground. please advise.Thanks.
you can use any type of computer cable and plug with your projector and main there is no any problem with live and neutral all projector and computer power cables are standard. good_help.jpg
Jan 20, 2011 | NEC LT220 DLP Projector
NEC MultiSync LCD1765 won't power on
Look for bad caps with bulging top in the power supply first, post back what you see inside so we can guide you further, see example of failed monitors due to bad caps (after about 2 years): http://s807.photobucket.com/home/budm/allalbums
Feb 15, 2010 | NEC MultiSync LCD1765 17" Flat Panel LCD...
My NEC VT660K wont power up.
Hello.
Some suggestions from NEC support:
Check that the power cable is plugged in and that the power button on the projector cabinet or the remote control is on.
• Ensure that the lamp cover or lamp housing is installed correctly.
• Check to see if the projector has overheated or the lamp has reached the end of its usable life. If there is insufficient ventilation around the projector or if the room where you’re presenting is particularly warm, move the projector to a cooler location.
Hope this helps.
Nov 05, 2009 | NEC VT660K Multimedia Projector
The motherboard called NEC N4-IBFGL It is not supporting my PS/2 Key board as well as Mouse. can you give me a good solution......
use a ps2 to usb convertor, ps2 ports are not plug and play, you can damage the board by unplugging and plugging in PS2 devices with the power on, that may be what happened to yours, if thats the only thing, use an adapter
Apr 20, 2009 | NEC Galileo 845GL (N4-IBFGL) Motherboard
NEC 42mpi plasma tv not working
Check the +170 volt  test point on the power board (not the power filter board, the one that the plug comes into) but the one to the right of that board. It has a 5v test point (TP +5v) , a +170 and a +70. I've found that the +170 transformer goes bad, and won't allow you to adjust the voltage using the pot screw.
Dec 29, 2007 | NEC PlasmaSync 42MP1 42 in. Television
Nec multisync 2080 monitor
You don't really need to replace the power supply, you can repair it by replacing the bad capacitors. I've done it to 2 Nec monitors and it works. However I do not believe its you power supply because you are getting the power on light.
Oct 16, 2007 | NEC MultiSync LCD2000 Monitor
NEC Ip2at-12txd Phone/telephone Handset black Logo
21 people viewed this question
Top NEC Cell Phones Experts
Computer Repairing
Computer Repairing
Shehu Pro
Shehu Pro
Are you a NEC Cell Phone Expert? Answer questions, earn points and help others
