Question about Gibson Heating & Cooling
What is the capacitor rating for Gibson JS5BD - 048K?
A technician replaced the capacitor on my air conditioner a couple of years ago but also added a 2nd capacitor connected to the fan side of the main capacitor. I am guessing he just didn't have the correct capacitor. Compressor won't start again so I want to make sure I get the right one. Currently the main capacitor is a Packard PRCFD 805 80+5 MFD with a 3 MFD added to the fan side. Is this the correct capacitor for the unit?
    Genius:
  • Gibson Master
  • 1,363 Answers
Obviously the 80 part of cap is for compressor if the motor was not changed it should still be a 5uf. new motor require different values.
Posted on Aug 13, 2015
  • 883 Answers
SOURCE: Danby DPAC10061 portable air conditioner problem
you may have a factory defective unit that is not turning off the anti-frost heating coil (I have assumed yours contains this item based on your problem description). I would trade it in for a new unit, again assuming you have a warranty or the store offers a good in-store return policy. If this plan bombs, then open the unit and find the heating coil near the cool side of the radiator fins. then disconnect the power wires to the heater and prevent electrical short to wires with quality electrical tape.
Posted on Jul 07, 2007
motor1258
  • 6674 Answers
SOURCE: Air conditioner fan will not come on and unit will run for 1 minute and stop
You hear the compressor kick in (Hum) but no fan comes on? Will the fan come on when just in fan mode, not cool, or do you have that set-up?
Posted on Aug 14, 2008
jumptrout51
  • 3361 Answers
SOURCE: Air Conditioner compressor fan stops, Capacitor wired wrong?
Purple should be on "C".
The fan motor may be destroyed now. Switch the wire and see if it keeps running or not.
Posted on Apr 28, 2009
  • 93 Answers
SOURCE: Compressor hums but fan not turning. Pushed fan to
cap most likley
Posted on Jul 16, 2009
VtToolMan
  • 704 Answers
SOURCE: RV Air Conditioner Keeps Tripping Circuit Breaker & Compressor
It sounds like the unit was miswired at the factory, since when the A/C is "off" at the thermostat, there should be no calls for cooling or for the fan to run.
You also stated the most puzzling issue, with the breaker turned "off" the same thing happens. This shouldn't happen at all, when the power breaker is turned off, there should be no power being supplied to the unit and it shouldn't be able to do anything. Very strange indeed, but likely a major error done when the RV was manufactured, or some wiring in the loom has somehow become shorted and is supplying power from another breaker/source.
I think a call to the manufacturer is in order since there is no easy solution aside from possibly rewiring the A/C circuit.
Not sure when your RV was made, but definately time to call the manufacturer and break out the wiring schematic in an attempt to isolate and resolve the problem.
Hope you find this helpful and best regards!
Posted on Aug 06, 2009
Blower humms doesntwork
ck. mfd on blower capacitor
Aug 20, 2014 | Gibson Heating & Cooling
Ac compressor fan running backwards.
Fan motors have rotations, clockwise and counter clockwise, lead end and opposite lead end. If you are looking at the motor from the fan blade side and the wires are on the back (opposite) side of the motor then you are looking at opposite lead end. Then you need to determine the rotation of the blade. It will scoop the air, so turning the blade that direction will give you the rotation. They also sell motors that you can change rotation by changing certain wires they have added.
When you replace a motor you need to notice the rotation and order that rotation. which end of the motor you are looking at to determine it. Then order the same rotation when buying the new one.
May 30, 2014 | Goodman CKL24AR24 Air Conditioner
Fan spinning backwards
If its the original mtr. or was working fine before then mtr is bad replace mtr with new capacitor
May 17, 2013 | Intertherm P3RA-048K Air Conditioner
Q3RD 048K
Check the capacitor and verify if the motor is receiving voltage, if not ithen the motor is bad.
Jan 07, 2012 | Intertherm P3RA-048K Air Conditioner
I HAVE A GIBSON JS5BD-024KB (2.0 TON) THE LINES ON MY UNIT HAVE ICE BUILD UP, AND THE UNIT DOES NOT PUT OUT COLD AIR
Clint, the copper refrigerant lines coming off the compressor to the house, generally freeze up because the sealed cell foam insulation is missing or damaged. Replacing it or repairing it, should solve the problem. Allow the lines to thaw completely, before installing or repairing the insulation.
Hope I helped you and thanks for choosing FixYa.
Aug 27, 2011 | Gibson Heating & Cooling
Central ac system compressor and fan no t running dual capacitor kind of bulged
Most likely the capacitor.Any signs like that is a definite.The outside unit some run a capacitor for motor (compressor) an fan.If you are replacing your self discharge capacitor first or you will get hurt.
Jul 07, 2011 | Gibson GAM155Q1A Air Conditioner
Fan will not engage unless assisted
Check fan capacitor
most times this is a bad fan motor.
If this was helpful please rate me.
Leo Ponder Appliance-Tyler,Texas
imufo2@sbcglobal.net
Aug 06, 2010 | Gibson GAK124Q1V Air Conditioner
Heating & Cooling Logo
102 people viewed this question
Top Gibson Heating & Cooling Experts
john h
Are you a Gibson Heating and Cooling Expert? Answer questions, earn points and help others
