Question about Garden
What is the model number for replacement cutter belt for viking mt 785 sit down mower?
2 Suggested Answers
SOURCE: I have a Viking MT
It a bit hard to explzin but here goes start at the front pulley on the left side you have an idler pulley it goes thru the pulley backwards and continues to the left to the other pulley which has the spring near it to hold it plate then straight down to the rear pulley around hydro pulley at rear back up to right pulley on other side straight up to pulley in the middle and its complete
Posted on Dec 21, 2011
I replaced my belt on my 50 inch mower deck and now the blade on the left side as you are sitting on it is not working would a twist in the belt cause this problem?
A simple "twist" in the belt would not likely be the culprit, More likely you have routed the belt improperly. This is easy enough to do considering the number of pulleys in the system.... With a model number you should be able to fins a belt routing diagram online displaying proper belt installation routing.
Aug 02, 2016 | Cub Cadet Garden
How to addjust cutter belt
If the belt is an older one it likely is stretched and wore out. Take the old one off and match it up in a shop where they sell lawn equipment or a place like Canadian Tire but I advise not to buy a cheap one as they don't last very long.
Mar 13, 2015 | Viking MT5097C
Replace cutter belt for a Victa Pro 12 ride on
Contact dealership/service center or buy a service manual online
Jan 25, 2014 | Garden
I have a Viking MT 785 ride-on mower. It starts OK but cuts out after a few seconds.
Does this mower have a primer bulb. If so, you are starting on the prime and no fuel is being drawn up for normal running operation. This means the main jet is clogged and you are going to have to clean the carburetor.
I hope this helps.
Aug 02, 2011 | Garden
I need a diagram on how to fit a cutter deck belt for a murray sentinel 15.5/ 106. Belt number 037 x 88 Keith
The routing is usually pictured on the belt cover such as in your picture. If you send me the model no. to the rider, I will verify proper routing.
Feb 11, 2011 | Murray 38 Lawn Mower Blade Belt '90'96...
My lt1000 craftsman riding mower belt broke. I bought a new one and can not seem to find the manual to see how to replace it. Can you show me a diagram please?
On your mower, lift up the seat and you will find a silver sticker with numbers on it. There is a 9 or 10 digit model number. It will look like 123.456789 Go to www.searspartsdirect.com and input your model number and perform a "model" search. I am assuming that the belt you are referring to is the deck belt. Go to the deck section and you will see a basic pattern of what shape the belt will have when installed. There are 2 kinds of pulleys on your deck...V-groove & flat side. The v-groove pulleys go on the inside of the belt, the flat side will go on the outside of the belt.
If the mower is more than 3 or 4 years, it is probably a good idea to replace the drive belt(s) also.
Good luck.
Oct 22, 2010 | Craftsman Replacement Belt for 42" Deck
Craftsman 42 inch deck mower. Model 917.277611 (2007). LT1000. 16.5hp Briggs & Stratton. Springs on cutter deck assembly broke. Had to re-assemble cutter deck. Re-attached springs and tension arms....
That model number des not show up as a good number on the http://www.searspartsdirect.com site. Are you sure you have the belts on correctly? If it has 2 belts on the deck & 1 is not installed correctly they work against each other. Safely make sure that each blade will turn by hand. did you take the blades off? If they are too long by just a fraction, they will hit ach other, but that usually makes quiet a noise. Get your book out & systematically go over everything you touched or changed. It sounds like something really simple you have overlooked. you can go to http://www.searspartsdirect.com & enter a good model number & view all of the parts diagrams. Sometimes they are a big help, & at other times they just confuse you more:). Let me know what you find!!
Aug 12, 2010 | Craftsman 17.5 hp 42 in. Deck Lawn Tractor...
Belt size of cutter belt on craftsman ride on mower 42in cut
Go to www.sears.com and click on partsdirect. Enter your model number of your tractor (found on a data plate usually under seat). It will take you to the page with your parts diagram. Look for the belt in diagram and scroll down to the appropriate number and it will give you the part number for the belt. You can order it from sears and pay shipping or go to local small engine parts department and give them the part number or you can just give them the model number of your tractor and they can get you the belt.
roundo4
Aug 12, 2009 | Craftsman 20 hp 42 in. Deck Lawn Tractor -...
Garden Logo
23 people viewed this question
Top Garden Experts
Dennis Key
Dennis Key
roeb
john h
