I have a NEFF W5320 X0 GB washing machine. The drum has stopped spinning so I have checked the filter and that was clear, I then took the back off the machine and checked the belt and that was ok too. I took out the motor and replaced the carbon brushes which were worn down but it still doesn't work! What else could if be? And how expensive would it be to repair? I don't know if it's worth fixing the machine or just replace it?!
2 Suggested Answers
  • 228 Answers
SOURCE: Change integrated Neff washing machine door seal
you will need to remove front panel this is quite easy,turn off mains open door and look for steel band spring holding front lip of door seal this needs to be removed it will be tight but will pull off,push door seal into drum so as out of the way, look at bottom of panel you will find 2 or 4 holding screws dependent on age of appliance undo these ,there is one other screw to undo behind the soap drawer take out draw and remove screw it is bottom r/h/side one you can then pull front panel away you need to disconnect door lock plug just pulls out.
remove panel out of the way and you will see another steel band holding back of seal to wash tub remove this and pull of door seal. reverse procedure to fit new one a little washing up liquid may help reassembly fit panel etc run check for leaks.
good luck
Posted on Aug 05, 2009
My lg front load washer posted this ER: check the drain and the hose. we checked all the drain. but the machine stopped when it was on SPINNING. the ER POSTING : CHECK THE DRAIN is back
Water comes out of the drum through a soft corrugated hose, into the filter, out of the filter through another soft corrugated hose into the pump and out of it through the hose that is put to the drain. Have you checked all of these pipes? Sometimes something small can get past the filter and get stuck in the pump. If it is all clear, then perhaps the pump is faulty.
Aug 03, 2015 | LG Washing Machines
Hotpoint BWD129 Spinning Difficulties
IF it sits and you can turn it later, the only thing that would cause that is something heating up and becoming seized. When it cools off it frees itself. I would check the bearings on the drum.
Mar 12, 2014 | Washing Machines
Neff washing machine not spinning. Fine yesterday, slightly funny noise and now drum not moving on wash or spin! Any clues?
Could be worn Carbon brushes on the motor.Check belt has not fallen off though...some Neff you need to buy half motor to fit new brushes as it comes this way, perhaps a good test is to blow ut any dust next to the brushes this may allow the motor to Briefy run long enough to tell if brushes are worn ..Half motor cost to buy - 60 GBP......Happy new year...
Jan 02, 2011 | Neff Washing Machines
We have a Samsung WF8802 RPZ washing machine with a 5ud fault code. What is the problem?
We have a Samsung WF8604NGW front loading dimond 6kg washing machine. We had the 5ud error message. It turned out the filter was clogged with fluff from a new set of bathroom mats my wife washed. To fix: Put the machine on to drain (if poss) - should be 1 minute on our machine however as the machine was so clogged it took around 15 to finish. Also use the draning tube located next to the filter (on our machine) to get rid of as much water as poss. Now remove filter and clear (warning some water will remain in the system) Before spinning any laundry run the rinse cycle (with an empty drum) a couple of times and clear the filter each time. If the filter is still clogged the laundry will spin heavy as the water will still be in the drum leaving you with no very dry laundry and a horrible noise during the spin. Regards Rik.
Nov 14, 2010 | Samsung Washing Machines
WSSH300G0 won't spin - filter is clear
Check your lid switch, and the strike, which is the other half of the switch, and is attached to the lid (the switch is on the machine).
Regards!, --W/D--
Jul 20, 2009 | General Electric WSSH300G Front Load...
good luck
Dec 22, 2008 | Neff W5340X0 Washer
Haier front loader 1400 spin
check to see that pump is not blocked stopping water getting away quick enough
Mar 16, 2008 | Haier XQ8M22-C PORTABLE TOP LOAD WASHER
Neff washing machine W5320
What is the temp of the water coming in to the unit. If it is not hot enough some machines heat the water up to a prescribed temp before washing, rinsing etc..... Could be a problem with the sensor too...let me know,
Feb 10, 2008 | Neff W5340X0 Washer
Washing machine - Bosch WFF 1401 - spinning problem
Bosch WFF 1401 This washing machine tutorial will show you what to do if the washing machine does not drain or empty the water out this repair was done on a Bosch, Neff and Siemens type appliance.
Thanks for using FixYa - a 4 THUMBS rating is appreciated for answering your FREE question.
Dec 29, 2007 | Washing Machines
Washing Machines Logo
Top Washing Machines Experts
Gerry Harvey
Gerry Harvey
