Question about Fujitsu FI-6670A MONO CLR DUPL 70PPM/ PERP140IPM ULTRA SCSI A3 600DPI TWAIN
6670 scanner won't scan
When I press the scan button on the scanner, the display shows "n" on it and nothing happens.
Copy and Scanner not responding
Copier may require you use the scan feature to make copies either ise the feeder otr flatbed. Press start on machine for manual entry but still use scan to get things working.
Nov 15, 2013 | HP HEWLETT-PACKARD CN583A Officejet 6700...
Scanner pro 93
reset it one more time and let the scanner boot before you do any thing else chill out for while dont be so egor
Sep 26, 2013 | Radio Communications
Wand Scanner - panscn08 buttons do nothing
Yes follow the first steps to set up the scanner (charge it, properly insert the memory card, etc.) Then you are ready to scan
Once you press the SCAN button and the Green LED stays lit its time to roll the scanner down your document to be scanned. When finished press the Scan button again to STOP the scan. If successful your Document count in the display will move from 000 to 001. That is the only indication that you now have a successful scan.
Next Press and hold the SCAN button until the display goes blank.
Now you can remove the memory card (by pushing in and it will release). Place this memory card into a memory card reader on your computer to transfer and view your scanned documents. Rinse and repeat.
BTW, I found a quick start guide for this Pandigital Handheld Wand Scanner Model PANSCN08 at:
http://www.qvc.com/footers/E167092_quick-start-guide.pdf
Good Luck!
May 04, 2012 | PANDIGITAL PANSCN Office Equipment &...
When i press the scan button , nothing happens at all ,, please help i need to scan photos
The scan button requires proper setting of the program on the computer that tracks the state of that button.
Reinstall drivers (full installation).
Why not open My Computer, find the icon of the scanner and scan using Microsoft scanner or camera wizard?
You can also open MS Paint and scan using File / From scanner or camera.
Aug 09, 2010 | Office Equipment & Supplies
Will not scan. Screen shows banks and scan up message.
Try this,press manual,turn squelch to silent,press scan. hope this helps..
Mar 20, 2010 | Radio Shack Pro-95 Handheld Scanner
HELP
If the weather band is working, the scanner should be working. To verify operation:
- Move the MODE switch to "Scanner" and power the unit ON.
- Press the SVC button (chrome button below display).
- Press POL (chrome button below display).
- Turn the SQUELCH knob towards the left until scanning stops and you hear a hissing noise.
- Turn the SQUELCH knob towards the right slowly until scanning resumes.
If the scanner stops on anything - even noise, it's working.
To Program:
- Slide the MODE key to "Scanner."
- Power the unit ON
- Turn the SQUELCH knob to the left until you hear a hissing noise, then turn it the right - slowly - until scanning resumes.
- Press HOLD.
- Press E (PGM).
- Press 0, 1.
- Press HOLD.
- Enter your first frequency, including the decimal point (EX: 156.055).
- Press the E (PGM) key.
- Press the UP arrow (above the SCAN key). Scanner will move to channel 02.
- Enter your second frequency, including the decimal point.
You should now have two frequencies programmed. Press the SCAN key . . .
If it still will not accept programming, let me know.
BillB
Nov 07, 2009 | Uniden BC340CRS Base Scanner
The start buttons are not working in scan mode. Press them and nothing happens. The other buttons work, such as the two buttons directly below the screen.
Scan from the scanner and camera wizard, the front scan button is useless. Go to My computer, open the scanner icon and scan from there, no need to use the button at all.
Nov 04, 2009 | Canon PIXMA MP600 all-In-One InkJet...
Scanner wont scan
Hi yendoe43701
Try uninstalling the printer/scanner completely, and the reinstalling the drivers again. Most problems is sorted out this way.
Sep 10, 2008 | Office Equipment & Supplies
Fujitsu FI-6670A MONO CLR DUPL 70PPM/ PERP140IPM ULTRA SCSI A3 600DPI TWAIN Logo
35 people viewed this question
Top Fujitsu Office Equipment & Supplies Experts
Tony
Jax Planet
Jax Planet
Are you a Fujitsu Office Equipment and Supply Expert? Answer questions, earn points and help others
